Question about Sharp Z50 - Z88 Toner
Need a set of 3 feed tires for z52 - Sharp Z50 - Z88 Toner
    Sergeant:
    Champion:
  • Sharp Expert
  • 351 Answers
Go to www.precisionroller.com They may still carry these rollers.
Posted on Apr 15, 2014
Can lexmark z52 color jetprinter work with laptop window 7?
I'm sorry to inform you that the Lexmark Z52 printer is not compatible with Windows 7. If you'd like some other options, please contact Lexmark technical support for assistance.
Jun 18, 2011 | Lexmark Color JetPrinter Z52 InkJet
Scanner has been used for a few years, and is frequently pulling multiple items through at the same time. We have cleaned the rollers with alcohol wipes, and fed the waffle papers through to clean.
If this is a Canon CR-180 or 180II machine then the feed tires need to be replaced. Often if you are using the grey feed tires, the middle one will come loose from the platic hub and cause this problem no matter how much you tighten the tension wheel. The part numbers of the seperatrion roller assembly and the feed tire assembly are as follows.
MG1-3530-000 Seperation roller (has 3 tires)
MF1-4210-000 Feed roller (has 2 tires)
You can also replace the two in the hopper area, they are:
MF1-4352-000
MF1-4353-000
That is a common problem on older machines; hopefully that helps
Feb 24, 2011 | Canon CR-180
Replaced ink cartridges in Lexmark Z52. Noe ink
There should be a clean program that you can run.
First restart windows, then run the clean program,
see if this helps, try and print. If you need more help
re-post what you did and still have a problem.
Feb 05, 2010 | Lexmark Color JetPrinter Z52 InkJet
Lexmark Z52 printer does not show ink level
The pdfs you quote apply to Windows 95 and Windows NT. What Windows version are you running? You need the appropriate pdf for that version.
Jun 27, 2009 | Lexmark Color JetPrinter Z52 InkJet
I have Lexmark z52 which doesn't print. The light flashes. I unplug and plug it back. It still doesn't work.
try to unplug the printer and wait a few second and plug it again..
if the problem still persist
May 18, 2009 | Lexmark Color JetPrinter Z52 InkJet
Does anyone know the difference between a canon ****** roller and an exchanger roller on a canon dr-2080c scanner? I am looking to replace the rollers that are ageing and now "picking" up more than one...
The exchange roller kit has all the tires that pick up the paper in the kit (feed, separation, and pick up tires). I think the other tire you are talking about is just one tire not the set.
Also check to see a switch on the scanner that is used for single feed or multiple feed. If its on single feed it will multi feed all the time. You can clean the tire with rubbing alcohol too, to see if your double feeding goes away.
Jan 25, 2009 | Canon DR 2080C Path-Through Scanner
Lexmark Z52 won't feed paper
You can try to clean it by using a blower maybe there are some debris stuck on the paper feeder assembly. But if its evident that the rubber of the paper feeder is worn out already then probably needs a replacement. but this parts are sold as one assembly it might cost you a lot.
May 23, 2017 | Lexmark Color JetPrinter Z52 InkJet
Z52 driver
Driver is here
If helped rate Fixya
Apr 15, 2008 | Lexmark Color JetPrinter Z52 InkJet
Sharp Z50 - Z88 Toner Logo
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
