Question about Sharp Z50 - Z88 Toner
Need set of 3 feed tires for sharp z 52 - Sharp Z50 - Z88 Toner
    Sergeant:
    Champion:
  • Sharp Expert
  • 363 Answers
I would check with precision roller at www.precisionroller.com
Good luck
Posted on Nov 22, 2013
Get a misfeed has occurred but there is no missfeed
Your paper may not be feeding, try your bypass tray. If that works you may need new feed tires for your cassette.
May 23, 2014 | Sharp AR-M237 Copier
Can't get top feed to sense paper and copy, it will copy from bottom
the reason for this could be that you have run the feed tires and seperation tires bald by only using the upper paper tray. i would suggest getting the feed tires replaced and that should fix the problem. you might also check behind the paper drawer to make sure that a piece of paper did jam and get shoved up behind the drawer and is keeping it from working
Jun 11, 2010 | Sharp Office Equipment & Supplies
Sharp AL-1631 bottom paper feed will not pick up paper.
A few things could be the problem.
  1. The paper in tray could be damaged
  2. The drawer separator pawls (metal taps on the right side of tray where paper touches)
  3. Paper backstop not in or in wrong spot (green plastic piece at back of paper)
  4. Feed tires are worn or dirty
Does the copier try and feed from tray 2? If it tries but the paper doesn't leave the try look and see if there is a dark mark on the page (top middle towards the right). If so then most likely the feed tire is worn.
Oct 12, 2009 | Sharp AL 1631 Copier
We have a Sharp 1641CS copier will not feed or copy
Well one reason the Cartirdge is spilling is due to the cartridge backing up with toner everytime it tries to print, it misfeeds cause the paper feed tires need to be replaced,
May 29, 2009 | Sharp AL-1641CS Copier
Sharp 1661cs
Hi, Sounds like what you have is that the feed tires need to be cleaned or replaced. When it fails to feed a paper into the copier it thinks it is out of paper and will display out of paper.
Hope that helps...
Lbcoaster
Mar 30, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp AL1631- Paper will not feed through
First off I seen these problems so many many times as an sharp dealer, I think I may drop the support however, the reason why your are getting the misfeed is beacuse your paper feed tires are worn and need replacing, r u in Ct f so we can helpif not call your indepenant dealer , remember Staples will not support this machine, and tell him your paper feed tires are bad and needs replacing
the Noise could be anything let's fix one problem at a time ok.
Mar 06, 2009 | Sharp AL 1631 Copier
Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Feb 17, 2009 | Sharp EL-1801P Calculator
AL-800 cannot make copies jam light remains on with no jams
First, is the paper being fed at all? If the paper is being fed and jams at the same location then a senor, actuator or switch is bad, out of place or broken. If the device will not clear the jam light, completely power down the device, unplug from wall, let set about 30 sec. to 1 min. and then replug in and see if it reset. If the device did not reset then again a senor, actuator, or switch is out of position ( being held up in the paper path). If the paper does not feed at all then the feed section is the problem. Clean the feed tire (s) the rubber restorer or a high alcohol base cleaner. Listen to hear if the feed tire (s) are even turning. If feed is not turning then it could be clutch, motor or board problem.
Jan 04, 2009 | Sharp AL-800L Copier
This 1631 has clip on (Green) pickup tires - Any sources???
You could try, or failing that take the tyres off the wheels and swap them.
Aug 27, 2007 | Sharp AL 1631 Copier
Sharp Z50 - Z88 Toner Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
