Question about Vehicle Parts & Accessories
Brake Fluid Need to know if this is the brake fluid resevoir
    New Friend:
  • 28 Answers
I believe it is. Brake fluid caps usually have the word "Dot" followed by a letter, like "Dot 4 or Dot 3".
What make and model is it? I might be able to say conclusively if I look it up.
Posted on May 02, 2013
  • gary simmonds May 03, 2013
    It's a Chrysler Voyager
  • Sara Sheppard May 05, 2013
    Ok, Yes. I looked up some schematics and that's your cap. I still recommend getting your hands on a repair manual for your Chrysler Voyager, as it will contain all this information and is much more reliable than anything one can find on the internet.
3 Suggested Answers
bigguy810
  • 448 Answers
SOURCE: im pretty sure that i
yes the small cylinder next to the master brake cylinder is for the clutch
yes it does take dot3 brake fluid and you must bleed the slave cylinder
1 fill the clutch cylinder and put the top on it DO NOT GET IT ON THE
(PAINT) this stuff makes a great paint remover but it WONT let you
paint over it once it gets on the metal so be careful
2 have some one pump the clutch and then hold the pedal down
loosen the bleeder on the slave cylinder once the air comes out
close the bleeder and pump again and do step 2 un till you see
no more air just fluid and keep an eye on the clutch cylinder so
it doesn't run out once you see clear fluid you will have a full
pedal and have a clutch again hope this helps you bob
Posted on May 04, 2011
hepcars
  • 1249 Answers
SOURCE: Brake help needed
I cannot see the leaking line in the video, however the brake line has a 10-inch connecting line from the caliper to the body. This line can be matched, and purchased.Soak both ends with PB Blaster before trying to take apart. You will need to bleed the four brake lines after switching out the defective line. Always start at the farthest wheel away from the master cylinder. Not a major problem. Hope this helps.
Posted on Apr 29, 2013
2005 chevy duramax 4x4 brake pedal goes all the way to the floor, ABS light on
You need to add BRAKE fluid. After that, blead your brakes. You need to find out where the brake fluid went. If there are no leaks, you need to check the remaining life on all four brake sets. If you have no leaks, chances are pretty good that you need new brakes.
Dec 14, 2012 | 2005 Chevrolet Silverado 2500HD 2WD
I need to know where to put the brake fluid
In the brake master cylinder resevoir located under the hood directly over your steering shaft. You should see a rectangular shaped plastic cap. If you need to add brake fluid you need to have your brake system checked. You should never have to add brake fluid.
Mar 13, 2011 | Lincoln Town Car Cars & Trucks
Why does the brake light keep coming on when hit a bump
your brake light is probably coming on because the fluid is to low in the resevoir. ther is a sensor in the brake fluid resevoir that is on a float. if the fluid gets to low the sensor tells thebrake light to come on . so if the fluid is just high enough to keep the light off, everytime you hit a bump the fluid sloshes around causing the float to drop and the sensor to turn the brake light on. also when your brake fluid level is low it tells you that you will either need new brakes soon or you might have a leak.
Dec 08, 2010 | 2000 Chevrolet Malibu
Brake light keeps coming on
have the brake fluid level checked in the master cylinder reservoir, low fluid level will cause the light to come on and then go off at ramdom
Oct 25, 2010 | 1999 Nissan Altima
Brake Fluid RESEVOIR
THIS SHOULD BE ON THE LEFT OF THE CAR,OFF THE FIRE WALL,LOOK UP CLOSE,YOU WILL SEE THE AMOUNT OF FLUID THAT IT NEEDS, FROM THE SIDE OF THE UNIT
Oct 30, 2009 | Cars & Trucks
Power steering
NO, DOT 4 fluid is brake fluid, not power steering fluid. The power steering fluid resevoir is black with a green cap.
Apr 20, 2009 | 2003 Audi TT
BRAKE FLUID RESEVOIR. WHAT IS THE SMALL RECESSED CAP FOR?
HMM, I WANTED SOMETHING FROM YOU BUT HAD TO PAY FOR IT.
YOU WANT SOMETHING FROM ME NOW?
WELL, I WOULD TELL YOU WITHOUT HESITATION OR A REQUIRED PAYMENT.
BUT I JUST ASKED WHAT THE SMALL RECESSED SLOTTED CAP IS FOR, THAT IS TO THE LEFT OF THE MAIN FILLER CAP ON THE BRAKE FLUID RESEVOIR. 2001 S4 AUDI.
IF YOU KNOW PLEASE BE KIND ENOUGH TO ENLIGHTEN ME.BOB
Apr 13, 2009 | 2001 Audi S4
Clutch fluid resevoir
Clutch fluid and brake fluid are the same thing. It's usually only sold with the label "Brake Fluid", but it is used in the clutch system as well. In fact, a lot of vehicles only have the one reservoir for both brake and clutch systems. You should use DOT 4 or higher grade. Cheers.
Oct 25, 2008 | 1991 Toyota MR2
1991 Acura Legend No Brakes
The only common issue I know if is the master cylinder leaking, but if you changed the booster you would have found your leak.
Check for fluid at the brake pedal under the dash.
Sep 19, 2008 | 1991 Acura Legend
Vehicle Parts & Accessories Logo
32 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
