Question about Refrigerators
Ge gsr23vgta bb diagram
I have GE GSR23VGTA side by side refegirator which does not defrost after 2 weeks and everything gets frozen in the freezer part (evaporator is completely in ice). I have to defrost manually and after that it only works properly for an other 2 wekks or so.
  • 184 Answers
SOURCE: GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Posted on Apr 10, 2008
SOURCE: GE GSL22JFPH BS refrigerator, coils icing up
I'm in the process of fixing the same problem on a GSS22JEPDWW right now. There are several parts in the defrost circuit that I can tell:
1) Defrost Heater
2) DefrostThermostat
3) Temp Sensor (Thermistor)
4) Main Control Board
I've replaced the Defrost Heater (remove back panel of freezer section - it's a stainless steel bracket that has a glass bulb in it) and it still doesn't work. The main control card provides power to the heater 4 times every 24 hrs for 25 minutes or so to defrost the evaporator coils. If all items are working, you'll see water in the drip catch at the bottom inside of the freezer compartment. Better yet, pull the refer away from the wall for 24 hrs and check if water is gathering below the plastic drain on the right rear of the refer in the pan. The water drips into a pan and the fan for the condensor coil evaporates it. Go to the www.ge.com website and look in the service section to find the parts diagram for your refer. You can then get a part number to buy the parts you need from a local parts store or the Internet.
I just bought the thermostat a few minutes ago and will try that next. Heater was $37, thermostat was $15. Sensor is about $20 and the control card is $140 (you can find on line for $95). I'm going down that path. If none of this works, it'll be in the dump in a week.
I've learned on-line GE refers are bad news. The control cards can fail repeartedly, althoough mine has worked for over 4 years. But, I won't ever buy another one since refers should last at least 15 years in my book. After $200, it doesn't pay to throw more good money after bad. I'll keep you posted on my results.
TM
Posted on Jun 25, 2008
  • 1122 Answers
SOURCE: Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Posted on Nov 13, 2008
  • 56 Answers
SOURCE: GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
Posted on May 30, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Posted on Jun 12, 2009
GE model GSS22JERF BB keep hearing loud howling noise coming from the freezer size. Don't know the cause
Uh-huh... Ivy Joseph,
Well ...
unless your cat is missing that characterization is going to need some EXPANSION... clarification... definition.
The door is open/closed has no impact on "howling"...??
The unit is OTHERWISE WORKING... (????)
or some issues have accumulated to attract your attention.
Your diagram shows a pretty standard side x side configuration...
a "WORKING" refrigerator won't be howling. An iced up refrigerator can encase the EVAPORATOR FAN... and the howling will be that fan shaft spinning in a FROZEN FAN.
The noise should stop on OPENING the door...
Iced up... can come from several sources
- huge air intrusion
- Defrost circuit failure
Go to the location below to get an idea of how our machine fits together...
The part depicted is the second LEAST LIKELY
failure point (defrost thermostat)... First least likely
is the defrost heater element...
Most likely... DEFROST TIMER (or PCB)
Hope this helps... comment me back with progress questions (I'm usually here daily)
appliance parts
Search Over 2 1 Million Appliance Parts
defrost-limiter-thermostat (and video)
http://www.appliancepartspros.com/ge-defrost-limiter-thermostat-wr50x10068-ap3884317.html
Partsselect
PartSelect Appliance Parts and Repair Help
Jan 05, 2017 | GE Refrigerators
How do I fix my GE refrigerator?
Ge uses a glass heater and it is common for the heater to go out replace the heater and it should cure your trouble
Dec 27, 2015 | GE Refrigerators
My freezer defrosts too often
replace defrost timer
Oct 12, 2009 | Refrigerators
Top section not cooling on GE Side by Side
IF the evaporator is frozen then the defrost is not occuring. Probably the heater or the defrost thermostat.
Sep 10, 2009 | GE GSH22JFT Side by Side Refrigerator
Evaporator coil freezes up. i have to manually defrost unit every 2 weeks or so.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check
, defrost heater, defrost thermostat.
. If the heater and thermostat are ok it’ll be the motherboard.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Your motherboard is part 801 on this diagram. http://www.appliancepartspros.com/sect/w/y/2/wy2lkbjgmo.gif
Aug 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Side by side is not cooling. I believe it is the defrost heater, how do you replace this?
The defrost thermostat is located behind the freezeer firewall, on top of the evaporator.
It is part 240 on the diagram below:
Regards.
G.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
May 30, 2009 | Refrigerators
My GE Profile fridge periodically (eve other n) leaks water
Thaw out the defrost drain in the freezer. It has frozen over and the defrost water has nowhere else to go except on your floor.
Apr 08, 2009 | GE Refrigerators
Freezer works fridge does not on a GE GSS22QGMC BB
you need to take freezer evaperator cover off , then turn it to defrost and test the supply voltage across the defrost element. if no volts then test the round disk looking thing with 2 wirers comming out of it . with the supply power removed from the power point, the coil frozen up , disconnect these wirers and use a continuity checker such as a multy meter on diode check or buzzer mode, you should have a closed circuit through the defrost termination thermostat (round disk with 2 wirers) , it is in series with the defrost element thus cutting the power to the element if the coil temp gets too high and terminates the element , the timer will time out after it's time duration is reached. A good way to test the motor in the timer is to put a texta mark on the dial of the timer and check it in 1/2 hr, to see if it has moved.AFTER YOU HAVE PUT THE ELECTRICAL CONNECTIONS BACK AFTER TESTING THE TERMINATIN THERMOSTAT AND MADE IT SAFE, YOU WOULD PLUG IT BACK IN.
The defrost timer needs to be connected to power of the fridge to opperate.
regards
****. let me know your progress pls.
Mar 31, 2009 | GE Refrigerators
Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Nov 30, 2008 | GE GTH18KBR Top Freezer Refrigerator
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
