Question about Dell Inspiron Computers & Internet
Spacebar problem on dell laptop
The space bar acts like it sticks, but i clicks just fine and the only way it will stop is if i hit the arrow key.
  • Dell Master
  • 5,660 Answers
Suggest replace Keyboard
Really
Need guidance with that post the Model Series Number
It's on the Bottom of the laptop
Example;
Aspire 5535-5315
Acer = Manufacturer
Aspire = Model Series name
5535 = Model Series Number
5315 = Model Number
Post back in a Comment
Regards,
joecoolvette
Posted on May 02, 2013
Carriage does not advance when pressing the space bar or pressing a key. Does advance when depressing tab.
If you press a key does it type or try to correct? The escapement mechanism that allows it to move from space to space may be sticking and causing your problem. That mechanism just may need a flushing and lubrication. You will see a shaft that runs through the carriage. Try to turn it top to rear until it stops. if you hear a click then it has been turned the right amount. If it doesn't turn, then it is as far as it goes. Try hitting the spacebar and see if the carriage moves. If it moves, hit any key and see if it moves. if it moves, hit another key. If it doesn't move then your escapement mechanism needs to either be flushed and lubed or adjusted.
Nov 20, 2015 | IBM Correcting Selectric II
When.I.hit.the.space.bar.a.menu.pops.up.and.no.space.is.inserted
That seems strange- try restarting your computer, or if that doesn't work, check your browser settings and make sure you don't have a weird key-bind set to the space bar. If all else fails, it might be easier to just reinstall your browser. I recommend Firefox, but Chrome is a strong browser as well.
Feb 24, 2014 | Dell Computers & Internet
Space bar keeps going but not pressed
might be dirty, get a can of air, from like home depot, office max, etc. turn off laptop, take out battery, turn upside down and blow the air underneath the spacebar, this should fix your problem. If not you need a new space bar.
Chad
Apr 12, 2013 | Toshiba Satellite Computers & Internet
Problem with spacebar key
I don't quite understand why this would happen after pluggin in a USB mouse - but I've seen it numerous times after a liquid has been spilled on a keyboard.
Sounds like you need to replace the keyboard. Best way to test this is to plug in an external usb keyboard and see if you can type normally on it.
If the laptop keyboard exhibits this behavior, and the external keyboard doesn't - you should replace the laptop keyboard.
Dec 30, 2012 | Dell Computers & Internet
My Dell Latitude D630 spacebar came off. Nothing looks broken, but I can't get it back on.
If the hinge parts are not broken and are still in place then place the space bar over these parts, align it so it is in the correct position then press the space bar down until the hinges click into the space bar.
Dec 15, 2012 | Dell Latitude D630 Notebook
Dell Inspiron 1545 space bar, ''n'' and ''b'' keys suddnly don't work
There isn't any "Known Issues" that I am aware of with that model. Try re-seating the keyboard cable, see if there is any difference:
http://support.dell.com/support/edocs/systems/ins1545/en/SM/keyboard.htm#wp1179891
If no difference, contact Dell if under warranty. If not new keyboards are about $20 on EBay
Jan 14, 2010 | Dell Inspiron 1545 Notebook
My spacebar issticking.
Yup! you can do that.. carefully... i repeat, carefully pry-upward the space bar using a hard plastic card (I.D cards are best). Clean the hinge with a brush. Press down till you hear a click to return the key back to its position.
Mar 15, 2009 | Dell Latitude D600 Notebook
Space bar on Latitude D-600 Dell is sticking
There may be something under the spacebar key preventing its contact with the base. If you gently pull up the key it will come off and you can check.
It's a bit tricky to put it back on, gently push it back on rocking it from top to bottom.
Failing this, you can buy a new keyboard quite cheaply on the web.
Jan 05, 2009 | Dell Latitude D600 Notebook
Keyboard spacebar sticking
Just solved it, after a bit of tinkering...
the prongs of the floating plastic frame need to sit inside the clips of the spacebar key, you can't just clip it back on with the prongs either up or down. It's fiddly, you need a paperclip or thin screwdriver to do it, but it's stopped the sticking problem.
Oct 25, 2008 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Keyboard space bar
only two possibilities, first is the rocker springs at each end or the bar are causingit to not make contact. or the bubble switches under the keyboard. I had a similar problem on an inspiron 6400 and I had to VERY CAREFULLY remove the keyboard,then the button to reach the bubble switch which had lost the plastic bushing that covered the shorting contact, good luck given the insane price that dell wanted for a new keyboard fixing it myself was the option.
Jan 04, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
Alun Cox
