Question about Garden
Problem with lawnmower
Can't get it started easily then can.t keep it running. Seems like a fuel shortage but cleaned carb and still no joy. Any ideas on tuning these machines etc?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Check for low engine compression 99lb is bare min to start but not stay running
Posted on Jun 07, 2014
2strokeJim
  • 577 Answers
SOURCE: after the engine began hunting i cleaned out the
did you replace you diaphrams or just clean them, does it have a float bowl or just diaphram? sounds like during all you cleaning you did'nt adj the tab to the needle, therefore diaphram is not opening needle which is not giving gas to the carb. tab should be flush with carb body and when you push on it needle should move to open and let fuel in, good Luck
Posted on Apr 28, 2011
ImpalerCo
  • 13 Answers
SOURCE: Lawnmower starts but won't run-replaced airfilter and plug cleaned carb
If it is starting and not continuing to run it still sounds as though something is blocking the fuel flow. If the carb has been cleaned out, literally torn down and the needles cleaned so that no small debris is clogging them, check the fuel tank and lines for anything that could be restricting the flow to the engine. Remember that it's recommended that you replace the fuel line (cheap fix) when you dismantle the carb. Removing the line breaks off small pieces of the rubber in a worn line, which can re-block a freshly cleaned carb.
Posted on May 13, 2009
huffman49
  • 235 Answers
SOURCE: how do you tune the carb on a honda hr194 petrol lawnmower
most carbs just need to be rebuilt it's not a hard job but when your finished adjust the mixture screw out 1 full turn of the screwdriver. that will get it started then fine tune it from there....good luck
Posted on Apr 05, 2010
Knucklebstr
  • 222 Answers
SOURCE: On a Honda GV100 lawnmower
You need to clean or rebuild your carburetor. If you're so inclined to do it yourself, there are many great videos on youtube. Here's a good one that shows a Tecumseh carb, but they are all basically the same once you get them off the machine. The problem I have with the Honda's is aligning all the parts and gasket when putting them back on. Here's the link and you can search for more. As I said, there are plenty of videos, and once you do one, successfully, you'll get the hang of it. Otherwise, take it to a professional for a good cleaning. Best of luck.
http://www.youtube.com/watch?v=i0JfCPxY3po
Posted on Jul 02, 2011
Knucklebstr
  • 222 Answers
SOURCE: honda lawnmower GXV 140
I have a similar Honda (with the overhead valves) that someone gave me because it didn't run at all. Turns out it had a stuck open exhaust valve. I got it unstuck and changed the oil. After running it about an hour, the valve stuck again. I think this is an inherent problem with these engines. I cleaned up the valves really well and lubricated them. Then I put a high quality synthetic (actually motorcycle racing) oil in it and have been running it for a year now with no problems. Not sure what your issue is, but with stuff blowing out of the exhaust and loss of power, I'd pull the valve cover off (prop up the front of the mower and you can do this without losing any oil). Check your valves and give them a good cleaning. They may not be seating properly, which would cause the symptoms you describe. I'm just an amateur, but I'm learning every day! Hope this helps and best of luck to you Lou.
James
Posted on Nov 01, 2011
Lawnmower starting problems
Clean or replace air filter. Fill oil, 30w. Clean & gap plug or replace.
Remove carb bowl from bottom of carb & clean. If gas is 30 days or more old, use fresh gas with Stabile.
Jun 19, 2013 | Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Briggs & Stratton 4 cycle Lawnmower engine no fuel from carberator. Fuel is being supplied to carberator but only runs when starting fluid is used. Gas is new. What's clogged?
the float may be gummed up. or the needle is plugged up.
you need to clean the carburetor, old gas left in the carburetor turns
into shellac and gums up in side. you need to take it apart and clean it.
Jun 05, 2012 | Garden
After the engine began hunting i cleaned out the carb ,jets etc & replaced the carb diaphram & gasket correctly ,now it wont even start,there is a good spark but the plug is dry when removed...
Apr 27, 2011 | Briggs & Stratton Garden
My 2007 Toto recycler rear drive starts then stops after few seconds, has gas, seems like gas isn't gettin through .
Underneath the carb there shoul be a bowl screw head, usually 1/2in or 13-13mm. Loosen bowl screw a little, fuel should come out. If so, pinch off the fuel line to the carb from the gss tank or empty the gas tank. Remove the screw from the carb bowl. Inspect the hole inside the screw & the hole or holes thru the screw near the screw head for debris. Spray with carb cleaner & tap on hard suface to dislodge debris, you may have to use a small wire to clear these orfices. Make sure the float is free to fall down. You can remove the float, carefully as there is a spring & a needle valve at the back of the float in the middle where it is hinged. Ensure the needle valve is clean & the tube to the carb is cleam. After cleaning everything & clearing any clogs re-assemble carb & try to start.
May 13, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
My Troy Bilt Self Prop. Z-start won't keep running. I clean All, replace Filter and Plug, have clean gas and lubed all. It Starts for 2 seconds and then cuts off. What do you think it could be? Thanks....
I had the same problem, Tilt the lawnmower on it's side air filter facing up and remove air filter cover and air filter then remove the fuel bowl underneath the carb; then clean the fuel bowl with some gas and a clean rag. For the next step be sure to aim blower tip at target then look away before pressing trigger, this will prevent gasoline form getting into your eyes.Take an air compressor and carefully clean out the carb where the flap is and the tube where the fuel float that would rest inside fuel bowl is. Leave on side install everything back except for air filter and cover. Then pour a little gas in the carb to prime it, lay the lawnmower back on all 4 wheels and try to start.
Aug 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
5hp Briggs & Stratton lawnmower starts but stop running?
Try cleaning the air filter, and check fuel tank for any debris.
Replace fuel filter if there is, and give the fueltank a good cleanout.
Use fresh fuel to refill.
May 17, 2009 | Craftsman 16" High Garden Tractor Snow and...
May 12, 2009 | Garden
Petrol lawnmower cutting out.
try changing the spark plug. if that doesnt work check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal.
Aug 29, 2008 | Garden
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
