Coleman presidential My friend has a Coleman Presidential 2 Heater/Air Conditioner in her mobile home and when she runs her air conditioner for anything more than a few hours she finds about a quart of water in her ac floor vent in her bathroom. How can i fix this for her?
22yooper
  • 828 Answers
SOURCE: Coleman Evron CH/CA unit won't blow the air through the vents
Relay for fan operation in the cooling mode may be bad and not bringing on the blower for the air.
Posted on May 22, 2008
  • 306 Answers
SOURCE: A/C unit not blowing enough air.
Do you change the filter regularly? And if you haven't changed it but maybe every year that is the problem. Your a-coil is plugged up and full of the stuff the filter is suppose to catch.
That is one possibility the other is and I have seen this more then once the duct work under the mobile home has come loose and is just pouring the air under there. Let me know what you find. ken
Posted on Nov 30, 2008
  • 1033 Answers
SOURCE: i have a coleman evconn heater/air conditioner in
Hello, usually the coil will freeze up due to low airflow across the coil or a low refrigerant charge. The first the ing you can do is try cleaning the coil with some coil cleaner, they sell it at any heating and cooling store. Also if there is a filter make sure it is clean. If that does not solve the problem then the unit has a leak and is low on refrigerant, in this case a tech should come out and repair the leak and charge it back up.
Posted on Feb 16, 2011
  • 230 Answers
SOURCE: I would Like to obtain
You do not need a schematic, the large line under the house should be insulated, if not insulate it. If its not insulated, it will collect condensation, because the line is lower than dew point.
If you want to clean the indoor coil, remove the cover where the lines enter the unit, the coils if dirty will be on the side next to to the air filter, use a vacuum with a brush, and get the larger stuff off, then use 409 or something like it and spray the coil, on the dirty side and let it soak for a few minutes and then use water to rinse the coil, if the furnace is under the coil keep the water from dripping into it. Then put a good quality air filter in, and then the coil will stay clean.
Posted on Jul 07, 2011
SOURCE: Our coleman presidential II keeps freezing while
Turn the air con off then let it melt for a few minutes
Posted on May 19, 2012
Coleman presidential II water is going into vents how can i fix it, just sta
either the drain is stopped up or coil is freezing up fan is carrying the moisture into duct work.
May 28, 2014 | Coleman Heating & Cooling
Coleman Presidential Furnace 6806A842 heat switch pops then cool air
Make sure all vents are open and filters are clean. Likely an air flow issue but possibly, though unlikely, both switches are bad.
Jun 05, 2017 | Heating & Cooling
Coleman evcon presidential
If it's a blower motor, then the contacts on the relay is welded shut and has to be manually opened.
Sep 30, 2013 | Coleman Heating & Cooling
Air conditioning runs all the time
I assume this is a manufactured home, this is probably a two transformer system, either your contactor is welded in the on positon or wyou have control wiring issues, (could be the thermostat)
Jul 12, 2009 | Coleman Heating & Cooling
I HAVE A COLEMAN AC CANNOT FIND FILTERS TO FIT
yOU CAN PURCHASE FILTER MATTING AT ANY HARDWARE store and cut to size. Its cheaper anyway.. It comes in rolls.
Jun 05, 2009 | Coleman Propane Forced Air Heater...
Need replacement glass for pilot cover of Coleman Presidential II
the glass is there as a service tool to veiw pilot and flame or relite just get a peice of sheet metal and cover hole with it ,it will work short term or long term
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Coleman Presidential II Heater won't come on
You should have 3 wires going to the gas valve - MV(mainvalve), PV(pilot valve) and MV/PV (or Common). Make sure all of these are properly wired and tight.
You also may have a dirty FLAME SENSOR on your pilot/ignitor assembly. You may need to remove the pilot tube and the pilot assembly to clean the sensor with sandpaper.
Be careful not to damage any parts while cleaning them. Be careful not to crossthread the gas line when re-installing it.
Jan 03, 2009 | Coleman Propane Forced Air Heater...
Nov 30, 2008 | Heating & Cooling
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
