Question about Building Materials
1/2 hp garage opener
Hi I just boaught a new 1/2hp chain driven garage opener, My question is that I repaced it with a almost identical 10 year unit all was similar and just mounted it to my existing hardware. It works perfect! I thought that my old remote openers would work; I cannot get them to work by programming it. Are they a different freguncy?
    Champion:
    New Friend:
  • 217 Answers
You have to get a new remote for the new door
Posted on May 07, 2013
3 Suggested Answers
  • 217 Answers
SOURCE: craftsman 3/4 hp garage door opener
not sure, but see the users manual here:
http://www.manualslib.com/manual/32293/Craftsman-139-5399.html
Posted on Mar 10, 2013
  • 31 Answers
SOURCE: How do i program my garage ope
Take your old remote and point it at the new remote while pressing 'learn' (or you might only press learn and then shoot the old signal into the new remote). Almost impossible without the old remote though. Hope this works.
Posted on Apr 22, 2013
Motor runs but door won't open. checked chain, seems to be ok
The problem is not the chain, it is the plastic gear in the unit of the liftmaster Garage Door 1/2 Hp.The plastic gear is not engaging, although it sounds like it is working.
You will have to replace it with a new one, then the liftmaster Garage Door 1/2 Hp will be able to open up once again.
Once you open and remove the old gear, Be sure to thread the screws in all the parts before you install them. Pre-threading them once would really help. Secondly, label the wires on the back of the opener before lowering it to the ladder, so you can put them back in their proper place.
Hope this was helpful.
Goodluck
Elect_Comp
Jun 27, 2011 | liftmaster Garage Door 1/2 Hp
I have a 1/2 hp craftsman opener, it has the premium wall console, keyless entry and two remotes, chain driven. I installed it about a year and a half ago, it's worked fine since. Just recently, it would...
I would pull the logic board and check for loose or missing connections/traces on the printed circuit board. You can also foll the 110v line and make sure it has not worked loose.
Nov 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't open or close door
The drive gear is stripped. Remove the cover and you can see it just in front of the motor. It is white nylon and the part number is 41A2817. Available from Sears or any good door opener service company. It will come with instructions.
Jun 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door doesn't open or close
You should check the gears inside the box, After years , the gears get dry and die, you can by online or from Sears the kit and replace the old gears. I just changed mine...not too difficult :) .
Mar 11, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door opener motor will not open garage door
It sounds like you did a really good job! My Craftsman 1/2 hp gar. dr. opener has a red reset button on it on the l/h side as you are looking at the light/motor from the garage door opening. You have to take the light cover off to be able to see it. My reset button is on the same side as the ground wire. You might check the ground wire while you're there. I really hope that this fixes it for you (and me). I'm quite sure it will as you know your way around the garage door opener already. Good Luck and Let me Know (Please) if it fixed it or not. If I think of anything else, I'll let you know. Have a Good Day!
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Do I need to replace everything, if I buy a new garage door open.
My 15 year old system broke down due to a worn screw drive. While parts like this can be replaced, it takes a bit of guts to work inside the motor, and the circuit board. I chose to buy a new unit. New units come with all the parts ... so you don't really save much, Depending on how old the system is, the old accessories may or may not work. Even though my old 1/2 H.P. motor was a chain drive, when I bought a new screw drive the mounting parts on the ceiling and on the wall above the door were compatable. So while you get the new parts in the box, you can use the old parts if it saves you time. I was not able to save the electic eye components as the number of wire leads was slightly different in the new model. It took me and my son about 2 hours to get the old one down and the new on up. Hope that helps. (by the way, the new chain drive is quicker and quieter)
Jan 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENER
Refer to your owners manual to adjust the travel limits to stop the door opening too high
Apr 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
44 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
