Question about Worldwide 1994 Ford F150 Pickup 4.9L Alternator - 130 Amps
Truck starts, engine runs well, but truck will not go pass 40mph and lower on an incline. What could cause this?
Truck recently tuned up including new plugs, wires, coil and distributor.
Did you unplug the spout connector on the driver side fender towards the rear before setting the timing at 10 degrees before top dead center? another cause could be the oxygen sensor .
Posted on Jul 07, 2013
98 chevy truck 350 engine 93K miles when starting sometimes the engine will backfire..could be cold or hot engine..but after it runs for a couple of minutes will run fine..
A backfire usually indicates a timing issue. I recommend a minor tune up, which will include new plugs and wires, as well as checking/setting the distributor timing. An oil change is also recommended after the issue is corrected, as offset timing can cause fuel to remain in cylinder, which then bleeds past the piston rings and ends up in the crankcase with the engine oil.
Apr 23, 2017 | Cars & Trucks
My 2000 Ford Ranger suddenly started idling really rough (like it wants to stall) and also shakes really bad at 40 mph. It also shakes the truck while driving, but not as bad as at idle or 40mph. No e
First question is - is the check engine light on ?
If so you need to start with the trouble codes in the computer.
Could be a faulty injector or coil among other things.
You should have a codes for which cylinder is not firing and other possible problems.
Sep 15, 2012 | Ford Ranger Cars & Trucks
What does the differential fluid do? Where is it in the truck and can i check the levels myself? My truck seems to chug and hard to pick up speed .... would this be due to a possible clogged fuel filter or...
Hi, differential fluid lubricates and cools the differential, some have friction modifiers to prevent clutch chatter in limited slip differentials. As for U joints. Improper installation could result in a vibration or drive line shudder, usually during acceleration but would not likely cause poor performance/acceleration or engine "chugging" and for the fuel smell you have you should return to the shop that installed your new fuel tanks and ask them to have a look at it.
Jul 23, 2011 | 1991 GMC C2500
My truck recently started severe vibrations coming from the engine when its going between 35-50 mph. I power down, turn it off and restart it and it runs fine. I recently had a dealer tune up and the...
check the bearings in the fan blade clutch
They can lock up at certain times & this did happen to me on two types of vehicles including a Ford truck
May 25, 2010 | 2004 Ford F150
FUEL PUMP REPLACED NOW THE TRUCK BOGGS AT 40 ABOVE
did you replace the filter that is in the fuel line not the one in the tank this one might be cloged with debrie of old pump
Nov 10, 2009 | 2003 Chevrolet Silverado 1500
Land Rover V8 Discovery shuddering while running on LPG.
Do you have a check engine light on and maybe flashing?
Apr 14, 2017 | 1998 Land Rover Discovery
2003 Ford Ranger starts hard.
That sounds like it could be one of many things. Have you ever given the truck a tune up? I suggest the following things first.
New Air Filter
New Spark Plugs
New Plug Wires
Oil Change (and filter)
These are the basic necessities of an engine. Having a dirty air filter, or plugs that are firing weak can surely cause this problem. Try giving the truck a good old tune up and see how it starts then.
Aug 20, 2008 | 2003 Ford Ranger Regular Cab
Worldwide 1994 Ford F150 Pickup 4.9L Alternator - 130 Amps Logo
Top Worldwide Electrical Supplies Experts
jhnolson
wadingriver
wadingriver
ka4iup
ka4iup
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
