Question about HP LaserJet 3390 All-in-One Multifunction Printer
Where is the fuser - HP LaserJet 3390 All-in-One Multifunction Printer
  • HP Master
  • 2,072 Answers
It will be on the back close to where the paper comes out. Most HP's you will need to remove the back door/panel and a few screws later it should pop right out. Fusers are generally designed to be easy to replace since they are part of the maintenance kit.
Posted on May 03, 2013
New Fuser is not being recognized by machine . . .
There are no mechanical sensors to detect that the fuser is installed, only the connector on the fuser that plugs into the main board.The fusers in this model are not the most reliable, I would try another fuser if you have it.
Dec 17, 2015 | HP lj ent 600 m602n 52ppm ntwk mono...
I got the error 50.9 on my hp colorlaser jet 3600 and i've what it said on the screen of the printer and the error it still there. please help me, i need this, my job is in the line. what can i do to make...
Hi hope this helps
the error looks to be low temperature on the fuser
as a repairer of machine I would normally recommend a new fuser unit if you use the machine a lot don't go for a refurbished unit as they just dint last as long but they cost more
hope this helps Ian
50.X FUSER ERROR
alternates with
For help press
A fuser error has occurred.
X Description
1 - low fuser temperature
2 - fuser warmup service
3 - high fuser temperature
4 - faulty fuser
8 - low fuser temperature
(subthermistor
9 - high fuser temperature
(subthermistor)
WARNING: The fuser is HOT. Turn the
printer off and allow it to cool for
approximately 10 minutes before removing
the fuser.
50.1 error - Fuser failure (Abnormally Low
Temperature Main Thermistor), perform the
following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
printer off and remove the fuser. Measure
the resistance between the fuser
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Faulty DC controller PCB. Replace the
DC controller PCB.
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
it if damaged.
3. Break in the fuser heater. Measure the
resistance between the fuser connectors
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
Table 7-3. Numerical printer messages (continued)
338
Mar 24, 2011 | HP LaserJet 3600n Printer
Laserjet4 50 intervenire
X FUSER ERROR A fuser error has occurred. 1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Apr 07, 2010 | HP LaserJet 4 plus Printer
When printing making loud noise
fuser gears. replace the fuser. part number rm1-3740-030cn
Nov 16, 2009 | HP LaserJet P3005n Printer
I want to fix my Hp laserjet 2840 (Fuser error 50.2)
Oct 30, 2009 | HP Office Equipment & Supplies
How do i fix a fuser error?
Oct 22, 2009 | HP Color LaserJet 3500 Printer
User error
FUSER ERROR:
Mar 27, 2009 | HP Color LaserJet 5550hdn Printer
Fuser Error 50.1 Fuser is hot. What is a fuser?
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Aug 17, 2008 | HP Color LaserJet 2600n Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
HP LaserJet 3390 All-in-One Multifunction Printer Logo
Seeker5211
Seeker5211
