Question about GE JKP90SPSS 27" Microwave Combination Wall Oven with 3.8 cu. ft. Thermal Oven, TrueTemp Oven System, 1.6 cu. ft. Microwave Capacity, Sensor Cooking and Turntable
Jkp86soh3ss microwave not heating up
What is causing my ge single wall oven with built-in microwave oven not heating, only the fan runs?
Is it the microwave or the oven that is not heating? If the microwave is not heating it is more tan likely the magnetron. If the oven is not heating it could be the element or the control board.
Sep 01, 2014 | GE JKP86 Electric Double Oven
Microwave tray does not turn therefore microwave does not heat. When it turns it heats properly.
Hola Carlos,
See below a tutorial that shows how to diagnose a microwave:
http://www.desmontalo.com/index.php/como-se-desmonta-un-microondas-lg/
May 11, 2012 | GE JKP85 Electric Double Oven
Microwave work but will not heat
If will does not heat or boil water, then your microwave is defective even if it appears to turn on.
If you do not hear the 'usual' humming noise that the microwave normally makes when heating, then the Magnetron is most probably defective: if the unit is out of warranty, it will not be worth replacing as it is quite expensive.
Hope it helps!
Dec 17, 2010 | Ovens
Model KEMS308sss microwave not heating - light comes on, turntable works but no heating. Unit is 4 months old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 13, 2010 | KitchenAid Architect II KEMS308SSS...
Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Jul 19, 2010 | GE JKP86 Electric Double Oven
My microwave is working but not generating heat.
Hi well you didn't give the name of the microwave so i cant send you links but from my knowledge when that happens the heating coil burned out my microwave did that a few months ago and i had it replaced and it is regular for it to work its just not generating the heat.
Hope I Helped Please Rate Hight Cause It Helps me
Thanks.... Nick
Apr 26, 2010 | GE Monogram® ZMC1095BFBB /...
GE Je1590 microwave oven turns on nut not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gf
Mar 01, 2010 | GE JE1590 Electric Single Oven
Convection works but Microwave does not heat
heatman101
duid
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
Goldstar ma-1012W microwave oven doesn't heat food
Sounds like a bad magnetron (the device that produces the microwaves) - if the microwave is over 6-8 years old, it's usually not worth fixing.
Mar 17, 2009 | Ovens
Sparking when microwaving
heatman101
gfgh
Mar 08, 2008 | GE Profile Advantium SCB2001KSS Stainless...
GE JKP90SPSS 27" Microwave Combination Wall Oven with 3.8 cu. ft. Thermal Oven, TrueTemp Oven System, 1.6 cu. ft. Microwave Capacity, Sensor Cooking and Turntable Logo
41 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
