Technics sl dl1
The needle arm does not advance. I can hear the hum of the motor but it will not respond while the record does spin.
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
Posted on May 21, 2008
djproaudio
  • 515 Answers
SOURCE: techniques SL-D1 Turntable anti skid...
Actually, this sounds like the needle is damaged. Make sure there is a tip on there. Just because it's new, does not mean it is not damaged. Sometimes end-users improperly handle the stylus/needle when installing.
If you are 100% certain that the stylus is ok, then the anti-skate needs to be set correctly. Generally, leaving it on 0 (zero) is ok to start. Then try and balance your tonearm according to THESE INSTRUCTIONS. These instructions apply to most turntables. The fundamentals are the same for all turntables in that you need to balance (float) your tonearm for optimal use.
Hope this helps some.
- Davis.
Digital Analog Therapy
Electronic Repairs
www.repairny.com
Posted on Nov 04, 2008
SOURCE: Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Posted on Nov 09, 2008
  • 11 Answers
SOURCE: Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Posted on Apr 13, 2009
SOURCE: Technics SL-BD22 ground wire does not reduce hum. Any solutions?
I have found out that the female phono plugs on the turntable are sensative and have to have a solid connection and often adjusted from time to time to eliminate the 60 cycle hum.
Posted on Nov 04, 2010
Technics sl 1200 dragging
almost often a wrong set table/arm weight and a dirty needle. . i gues the last. Cleanen record
May 13, 2014 | Technics SL-1200 Turntable
Why douen't my technics turntable spin?
Take off the rubber mat and see if the belt is off the aluminum platter the record sits on you should be able to see the rubber belt when the mat is removed. If it is not there or broke it will need replaced.
Apr 23, 2013 | Technics SL-BD20D Turntable
I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Feb 20, 2012 | Technics Audio Players & Recorders
I have a Technics SL-QL1 direct drive turntable that works perfectly for about 5 seconds, then it suddenly repeats itself over and over... the record never advances beyond that point. It happens with any...
I don't think it's the direct drive as that just makes the platter spin around. Since the stylus sits in a record which moves it forward, if it gets stuck then it's going to be something to do with the arm of the record player that can't move beyond that point. Check around the piviot of the arm for problems and look at the anti-skating control. If you can move the platter by hand that will prove it's not the drive if the stylus gets stuck.
May 25, 2011 | Technics Audio Players & Recorders
I bought a very nice toshiba record player arm won't move
I am not familiar with that particular model, but the hum is probably the motor. I would check to see if the belt has slipped off or even exists. I'll look it up tonight and update this if I find out more.
Dan
Sep 10, 2009 | Audio Players & Recorders
Needle skipping & not pushing down
There should be an "anti-skate" adjustment to control the arm moving across the record. It is possible that lubrication has stiffened up as well. This unit may need a general overhaul/cleaning.
Dan
Jul 20, 2009 | Technics SL-1210MK5 Turntable
Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Mar 10, 2009 | Technics SL-BD22 Turntable
Tone arm is hard to move and when it's placed on a record the needle sticks at on spot on the record. the same needle and record plays fine on other technics 1200 mk5. seems like the arm has resistance in...
You have a bad tone arm. I have the same tables. You need to get it repaired if under warrenty. Or there is a service manaul online you can get from ebay. Service center for our tables is Panasonic.
I had the same problem on mine. But while it is in the shop they recalibarte it
Feb 13, 2008 | Technics SL-1200 Turntable
29 people viewed this question
 Grubhead
Grubhead
