Question about Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White
I have an Alexis Dual flush toilet from Sams Club that is 1 month old. Used to flush fine, but now when flushing the tank fills up, stops and just gurgles down. I have plunged it and still does not flush properly. Also had the main line cleaned out before installing the toilet. Help, i like the toilet but I need one that flushes.
  • Caroma Master
  • 16,981 Answers
5 Year warranty on that. Get it replaced.
Posted on May 13, 2013
bloues
  • 56 Answers
SOURCE: I have an old Caroma Dual flush ( 15-20 years) and
Well luckly the velve can be replaced by a modern 1. iets not exspensive and dosent take long to do, u will get a step by step apon perches.
Plz rate my advice
Posted on Jul 12, 2010
  • 30 Answers
SOURCE: I need a tank LID for the 270 Caravelle dual flush
Toilet seats are standard and fully interchangable. You should be able to pick one up at your local hardware store. The only thing you need to know is if you have a round or elongated bowl.
Posted on Sep 18, 2009
faceofftech
  • 185 Answers
SOURCE: water fills tank slowly
Check your angle stop ==valve underneath close to the wall see if it's open all the way if it is and you still have the same problem then go ahead and shut it off, disconnect it from the toilet and the valve and see if there is anything stuck in the hose (a gasket maybe) if nothing blocks the hose then. Reconnect the hose starting from the valve put a bucket on the other side to catch the water and open the valve as if to clean the hose. After you do that reconnect the hose and try again if still does not work properly then you have to replace the fill valve (the tower looking stuff inside the tank)
if it works for you, don't forget to rate me
thx
Posted on May 27, 2010
  • 760 Answers
SOURCE: Caroma dual flush toilet is only 2 years old and
Try this link for adjustment instsructions:
http://www.caromausa.com/site_assets/www.caromausa.com/images/dynamic/pdf/QuietFlow%202%20Service%20Guide.pdf
Posted on Jul 17, 2010
  • 6 Answers
SOURCE: how do I adjust the
By moving the float
Posted on Oct 25, 2010
Toilet flushes but bowl won't fill up
Adjust the level in the tank. It should be filled to the level mark on the rear of the tank. Adjustment is by the screw on the float, or lever depending on which country you are. Some tanks are Dual Flush, small flush for waste water (short press), long flush for solids (press and hold). See the link.
Google
Dec 27, 2016 | Home
Roca dual push button Toilet will only flush when holding the push button continuously down until the cistern is empty. It won't completely flush like it should when pressing the button once.
allow tank to fill a little more by adjusting fill valve. When there's not enough water flowing from tank the stopper can over-power the water flow and cause the flush to stop by re-sealing.
Feb 28, 2015 | Home
My geberit model number 131.028 dual flush won't shut off with water and leaks into the toilet bowl
How old? Who installed? Any warranty? I'd follow that route first.
If not warranty I'd try to get the installer to be interested. Perhaps he will have a "red face" an help out.
Feb 27, 2015 | Geberit 131.028.SJ.1 Black Glass Monolith...
Koehler one piece toilet trickling water into tank
The flapper at the bottom of the tank is leaking and needs replacement.
Feb 08, 2014 | Kohler SAILE ELONGATED ONE-PIECE TOILET...
Jabsco electric toilet won't flush
Check the power source to toilet and all wiring conversed.
Sep 07, 2017 | Jabsco Home
Howdy, the tank on my Baden dual flush toilet out of blue eill not refill after being flushed. The water is not filling the tank. Can you help me, this toilet is not even one year old. Thank you. Sue
We have replied that it sounds as if your internal flush kit button is stuck in the down position. If you continue to have problems please contact us for a replacement flush kit for free. Thank you.
Aug 20, 2011 | Dmm Baden Bath One-piece Toilet
I have a dual flush corona and there is a stream of water leaking into the bowl. It periodically has to continue to fill when it gets low. I have replaced the round seal inside the tank at the very bottom....
There should be a float inside the tank of the toilet. Be sure that when the tank fills that the float is not getting stuck, or not floating all the way up and not sealing the flush valve at the bottom of the tank.
Apr 05, 2011 | Caroma CARAVELLE270ADAW-EL Caravelle...
How can we stop our 1.5 year old pegasus dual flush toilet from continually running?
Remove the lid from the tank. Verify that the tank is full. Shut off the water to the tank, at the wall. Wait 5 minutes. If the level has fallen in the tank, the flapper valve in the bottom of the tank is the culprit. If the tank remained full, the issue is with either the fill valve assembly or the overflow tube.
--W/D--
Jan 16, 2011 | Foremost Pegasus Series 1940 1-Pc White...
Toilet flushes fine but when the tank has filled it seems like the float ball keeps bobbing up and down letting more water or air into the tank. it will do this 5/6 times then quits. its almost like it is...
The ball float follows the tank water level, and repeated cycles of the float dropping and opening the fill valve would likely reflect a leak in the flush valve. You could try adjusting the float arm downward so that it will respond to a lower water level. Try turning off the supply valve, flushing it and listen for water leaking past the flush valve after it closes. If it does, replace the flapper or adjust the chain.
Nov 13, 2010 | Toto Aquia II Dual Flush Toilet
Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White Logo
852 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Caroma Home Expert? Answer questions, earn points and help others
