Question about Yamaha Audio Players & Recorders
How to connect a yamaha MG82CX mixer to a yamaha RX-2092 receiver
Which input port of the yamaha RX-2092 receiver that i can connect the mixer board to ...using for karaoke
  • 236 Answers
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Posted on May 03, 2008
  • 1894 Answers
SOURCE: Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
Posted on May 22, 2008
Ajkill
  • 2035 Answers
SOURCE: Strange Flicker with HDMI components
Reset the yamaha player to factory sttings and check if the issue still exists ,unplug all the cables and replug the cables if the issues still exists its the problem with the Yamaha receiver, please get it changed as its a new player................................
Posted on Jun 10, 2008
  • 127 Answers
SOURCE: Ipod connection to a Yamaha RX v363 receiver
Fortunately you are wrong :)
On yamaha site you can see that RX-V363 has a DOCK connector, which supports both iPod docking station YDS-11 and Bluetooth Wireless Audio Receiver YBA-10.
Posted on Mar 02, 2010
  • 127 Answers
SOURCE: Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
How to connect cd player to my Yamaha RX-V733
If the RX-733 is similar to the RX-773 then the Audio 1 and Audio 2 ports are audio inputs on the AV receiver. The AV 5 and AV 6 ports are for composite audio/video connections.
I hope this helps.
Feb 21, 2017 | Yamaha Audio Players & Recorders
Main speakers do not work on yamaha 2092
is the speaker select button pushed in?
Jan 08, 2014 | Yamaha RX-V2090 Receiver
How can I connect a microphone to yamaha rx v692
If your trying to have a PA sytem with these unit, you need to have a
separate mic mixer.
But if your trying to setup a Videoke Sing-along System , just connect
the Mic to the player Mic Input.
But if you need and feel to DIY, there is another option
and only if you can.
Oct 20, 2012 | Yamaha RX-V692 Receiver
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
Where can I purchase a European compatible power adapter for a Yamaha MG82CX mixer?
what is the voltage/current/wattage of the unit this info should be on the back/underside of the unit, Also what type of power supply plug does it take? Maplin electronics throughout the uk or any good electronics parts supplier should be able to help you? Have you tried ebay etc?
Jul 14, 2009 | Yamaha Mg82cx Stereo Mixer
Hooking up Electronic drum kit to mider
sorry ...you haven't enough channels to mix all the kit ... you will have to run a stereo pair from the td8 to mg82 and mix it from the td8
Feb 01, 2009 | Yamaha Mg82cx Stereo Mixer
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Jan 12, 2009 | Yamaha RX-V661 Receiver
I have a yamaha mg82cx mixer and my bar lights dont really light up
hehehe sounds like a good party... mixers... bar lights... balloons..lol can you describe to me again what is happening? Is it the master VU that is not coming up or not glowing brightly, or just not enough level coming through the mixer to light up the VU?
regards
Graeme
Apr 09, 2008 | Audio Players & Recorders
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
