Question about Sega Rome: Total War Gold Edition for Windows
Install errorError Code: -5005 : 0x80070002 - Sega Rome: Total War Gold Edition for Windows
Need activation code for corel x6
You can try this activation code:BC23-800D-394A-0ACF-89DA
Mar 06, 2014 | Corel Computers & Internet
Ink system failure message errorerror
Have you tried unplugging it and plugging it in again?
Nov 19, 2013 | Canon PIXMA iP5300 InkJet Photo Printer
Chime
power cycle the system then hold star and pound that is a back door into programming hit #20 that will tell you the installer code then hit *99
once you have the installer code hit (Installer Code + 5 + 0) if you want to change the master code hit installer code + 8+02+new code + new code to create a new code
May 16, 2013 | Honeywell Ademco Alarm 6150rf Keypad Lk
Error -209 abd A-17 what do I do
Error A17: Cutter errorError Point 209: Cupper HP switch is OFF when master-making starts or when the master material is set in the master making unit.
Try this: Take out master and then close master making unit cover
Sep 20, 2012 | Riso RZ310 Duplicator
Rizo ez200E p12-309
Error type P12: System ErrorError point 309: Master-compression-motor encoder sensor count did not change as the master compression motor activated in the compress direction and moved out from the home position.
Try this: Press reset-key. If recovery fails you machine needs service.
Sep 19, 2012 | Riso RZ220 Duplicator
I need installation code for coreldraw x5...for serial no. DR15R68CHAURV8B24TTKDNXJF8NJHTJUS
All follow these steps to get installation code:
1. Start Corel Draw
2. Click on Activate Now or Other Activation Option
3. Now click on Phone Corel
Now from here you will get your Installation Code
4. Use this installation Code and Serial number in Keygen.exe to get your Activation code
100 % working . Enjoy guys solution by Pawan Soni (ZF)
Mar 01, 2011 | CorelDRAW Graphics Suite X4 for PC...
MY ALARM SYSTEM KEEP BEEPING UNCONTROLABLY..ADEMCO ALARM
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions ' eHow.com http://www.ehow.com/way_5752912_ademco-alarm-resetting-instructions.html#ixzz3pC2j96jl
Feb 04, 2011 | Audio Players & Recorders
I NEED serial number and activation code
nstallation code- XD7YIXV9RN29PWGYKM47
Key code- DR14N4V-76PD3E9-5X7JSFL-YF6AMS4-9YG3J
Activation code - F4BF-7684-01F6-E71A-6AC0
urchase serial number: DR14N22-JKPLHYP-LP8FA8Z-BDZGFKZ-CNS56
Activation Code:B4B2-6C89-6673-E411-CC50
Serial number: DR14B98-NMPMSL9-MM7WT66-8D884F8-TBVHS
Installation code: XRRX-IXV9-RN55-7M6Y-8WC7
Activation code: 702D-92F5-40A2-1F65-E2B2
Plz try this activation code :
6E67-5CCB-B6A9-8B8F-938Bs
serial no. : DR14T22-FKTH7SJ-KN3CTHP-5BED2VW
installation code: XRP4-IXV9-RN55-QTQU-P4K7
installation code: XRRF-IXV9-RN55-3MJ4-3Y47
serial number: DR14T22-FKTH7SJ-KN3CTHP-5BED2VW
instalation code: XRPE-IXV9-RN55-JBJD-QGU8
DR14NU8-9ZLA4A8-NBD74YQ-BPC82XN-F7NVE OR DR14T22-FKTH7SJ-KN3CTHP-5BED2VW OR DR14B57HCPUL7RBXGAS2ZJH4ART388452 OR Purchase serial number: DR14N22-JKPLHYP-LP8FA8Z-BDZGFKZ-CNS56
DR14T22-FKTH7SJ-KN3CTHP-5BED2VW OR instllation Code:XQUJIXV9RN5WUNW9DFU7 Serial number:DR14N22-JKPLHYP-LP8FA8Z-BDZGFKZ-CNS56 Activation COde:0DC8-72D8-B0D8-99DB-66BF OR Purchase serial number: DR14N22-JKPLHYP-LP8FA8Z-BDZGFKZ-CNS56 Activation Code:DEFA-94A8-7270-FD9C-FFB4
Codes that worked for me,
Installation Code: XQTJIXV9RN5WKP26D8K7 (It
Sep 10, 2010 | CorelDRAW Graphics Suite X4 for PC...
What is installation code
i have lost my cd cover in which there was the code for running cricket 07......now what should i do????
Apr 10, 2009 | EA Sports Cricket 07 for Windows
I cannot get internet connection on my wireless computer
Biggest problem I've seen here is that users will install a WEP security code when they install their router. Years later when they install their new laptop they've forgotten about that code and can't understand why their laptop won't connect. Go through the installation instructions for your router and you'll either see the code or be able to reinstall the code. Then put the code into your laptop.
Nov 08, 2008 | Computers & Internet
Sega Rome: Total War Gold Edition for Windows Logo
88 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
