Question about HP Photosmart C6180 All-In-One InkJet Printer
Cannot print with wirelessly networked printer
Cannot print with vista (toshiba) laptop and hp wireless printer. Printer shows as ready, is favorite on this laptop, print goes to print queue, but never prints. Will occasionally print if I restart computer. I have uninstalled and reinstalled software 3 times including using ethernet cable once and still problem persists. This network works fine with 2 other computers, both with XP installed.
  • 8 more comments
  • coco309 Jul 15, 2008
    HAve not been able to setup bluetooth wireless and print from my C6180 printer. I use VISTA on and hp laptop.
    I set this up with my celphone and it works just not the printer. Please help.
    Michelle
  • Anonymous Jul 26, 2008
    Cannot print with vista (HP) laptop and hp wireless printer.
  • 1irnman Jul 26, 2008
    my printer is set up correctly but does not print
  • kewldudemeis Aug 09, 2008
    Hi there, I have exactly the same problem, I've uninstalled and re-installed the software a few times. When i reboot upon rebooting it will kick off whatever was stuck in the spool. The PC see's the printer on the network but it simply won't print. Firewall is completely disabled and no difference. Have just reset the printer to factory settings too, no difference. If I boot the PC with printer already turned on I can print and use printer features for a period and then it goes back to this condition.
  • Burgessnt Aug 25, 2008
    I have had the same problem since I switched to Vista. I even tried connecting directly to my computer with a USB but the printing still hangs on a regular basis. Sometimes even rebooting doesn't clear it; I have to go into Services and stop the print spooler and restart. I also cannot print multiple copies of a document from any application - I can tell it to print 5 or 6 or 30 and it only prints one. It also won't print graphics in Word/Office 2007. I think there is an incompatibility with Vista.
  • edwardsaimee Nov 02, 2008
    I have the same problem. I have been able to print before with this computer, but for some reason I can't now. The printer is Ready, when I print I get an error message.
  • Anonymous Dec 12, 2008
    I cannot print wirelessly on my hp photosmart 6180 printer. requests stay in queue.
  • dnrwasson Feb 12, 2009
    We had an electrical outage in our area last night. Since that happened my printer (HP Photosmart 3210 all in one) Will not read my computer Hp Pavillion with Vista. It says it is ready but will not print. Says it is pending. Thanks for any help.
  • Anonymous Mar 27, 2014
    I can't get my printer to print from my laptop with a wireless connection. it prints fine with my desktop that it is attached too
  • Anonymous Mar 30, 2014
    I HAVE UNPLUGGED THE PRINTER AND ROUTER AND RESTARTED NUMEROUS TIMES. I HAVE AN APPLE IPAD AND LAPTOP. NOTHING FROM EITHER WILL PRINT AND I CANNOT GET THE PRINTER TO RESUME.
    Novelist:
  • 106 Answers
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
  • Supabix
    Supabix Aug 09, 2014
    Thank you so much! I used the copy of the printer and it worked.
Open the printer view from "Printers & Faxes", can be found on your "Start Menu" or "Control Panel". When that view is open, where you see your print job listed; if the "status" column is empty, click the "file" menu, you will probably find a check mark next to the "work offline". If that is the case, click it once to uncheck it. Then, either reissue the print job or highlight it in the quoue list, right click and select restart.
Posted on Oct 14, 2008
    Sniper:
  • 95 Answers
Print a network configuration page and note down the IP address of the printer. Open the printers folder and check for the printer icon with a check mark on it and reads ready status. Right click on the printer icon and select properties. Select ports tab and click on configure port and enter the same IP address and try to print which would resolve the issue.
Posted on Dec 23, 2007
    President:
  • 317 Answers
Do you have a firewall installed? Try disabling the firewall while you print. I've seen software firewalls not allow you to print wirelessly before.
Posted on Aug 08, 2007
How to set up wireless printing with disc
Here are the minimum details needed to answer this kind of question:
1. Operating System :
Windows XP, Windows 7, Windows 8, Windows Vista?
2. Printer make/model:
(this is important to determine the wireless properties of printer)
3. Network Connection:
(is the laptop connected to the same network as the printer)
If you are working with a new printer (see item 2) and you have a network on which you have your notebook connected, there are so many possible ways to connect the printer to the network that it's hard to say.
If you are working with an established printer that has wireless services running, you may need to know either the Network Name of the printer or the IP Address of the printer.
Your best bet is to make use of hp's extensive Wireless Printing Center (see link below).
Wireless printing center
Feb 26, 2014 | HP Pavilion dv6000z Notebook
Vista driver
The print driver solution for this product is included with the Microsoft Windows Vista operating system and is already on the computer. No special driver download is necessary for this product.
Please follow the simple instructions below to easily get the product working with Microsoft Windows Vista Operating system.
Installation Instructions
Direct Connection (Parallel & USB connector)
  1. Verify that the printer is turned ON.
  2. Connect the Universal Serial Bus (USB)/ Parallel (IEEE 1284) cable to the printer and to the computer
  3. Click on the Close button when the message "Your devices are ready to use" is displayed in the screen.
  4. The printer is now ready to accept the print job.
Wired Network & Bluetooth Connection
NOTE:For Bluetooth connected printer, please ensure that the printer's access mode is set to public mode for detection.
  1. Verify that the printer is turned on.
  2. Click Start > Control Panel and then select Printers .
  3. Click on Add a printer .
  4. Click Add a network, wireless or Bluetooth printer . A list of detected wired network or Bluetooth printers will be displayed.
  5. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the printer driver installation.
Wireless Connection
  2. Ensure the printer's wireless network setting is set to the correct wireless profile matching the local wireless network/computer's wireless card setting.
    If you have previously configured the printer's wireless network setting, matching local wireless/computer's wireless card setting, please proceed to step 3.
    if you have NOT previously configured the printer's wireless network setting to match local wireless network/computer's wireless card setting, please follow the steps below.
    To set wireless network settings in an infrastructure network
    Connect the printer to the computer with the cross cable (included with the printer) or connect the printer to the network with a network cable.
    Press the configuration button once to print a configuration page.
    Open web browser, and type in the IP address that has been assigned to the printer.
    Configure the printer's wireless setting to match local wireless network/computer's wireless card setting.
    Unplug the cross cable/network cable.
    Activate the printer wireless network, activate the computer's wireless network profile.
    Proceed to step 3.
    To set wireless network settings in an ad hoc network
    Do the following to reset the printer's network settings:
    1. While pressing the Configuration Page button, press (Resume button) three times.
    2. Wait about 20 seconds, and then press (Power button) to turn off the printer.
    3. Disconnect the power cord from the printer.
    4. Wait about 20 seconds, and then reconnect the power cord.
    5. Press (Power button) to turn on the printer.
    6. Open the configuration utility for the computer's wireless network card, then create a new wireless profile with the following values.
      • Communication mode: ad hoc
      • Network name (SSID): hpsetup
      • Security (encryption): disabled
    7. Activate the wireless profile.
    8. Wait two minutes for the printer to obtain an IP address, then print a wireless configuration page to verify the following for the printer's network settings.
      • The IP address is NOT 0.0.0.0
    9. If one of the above conditions is not true then repeat the preceding steps. Proceed to steps 3 below.
  3. Click Start > Control Panel and then select Printers .
  4. Click on Add a printer .
  5. Click Add a network, wireless or Bluetooth printer , a list of detected printers will be displayed.
  6. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the print driver installation.
Dec 15, 2013 | HP DeskJet 450wbt InkJet Printer
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
Hp photosmart 7200 and hp laptop are not communicating. wierless signal strengh is excellent. cancelled , documents cancelled and error message appears.
Click on the link to resolve printing issue on wireless network -> Link
Click on the link to find out if the HP Printer is on wireless network on not -> Link
To Setup the printer on wireless network, follow the steps below
1. Press the SETUP Button printer front panel
2. Scroll to Network - Press OK
3. Scroll to Wireless Setup Wizard - Press Ok
The printer will start searching for wireless router.
Choose the SSID ( Network ) and enter SSID ( network key if setup ) and Press OK
You should get a message as Printer Wireless Setup complete.
Run the HP Printer Software Disk and Choose Add a printer and Choose Wireless Installation and follow the instructions on the screen to complete the setup
You are ready to Print and Scan
Oct 12, 2010 | HP Photosmart C4580 All-in-One InkJet...
Please what is the steps for correcting my wireless printing, my vista/laptop cannot see my printer to print wirelessly any more I have an hp 6310 all in one. There is another computer in the house that...
To be able to set up wireless printer configuration, there are three basic items that you need to have. They are a high-speed broadband Internet connection (with modem), a high speed wireless router and wireless network adaptors. These three items will be used in setting up the wireless printer. Assuming that there is already an existing network in the home or office space, then all that is needed to do to make the printer available in the network through the operating system’s networking wizard. If not, then the network must first be established, only then the printer will be made available through that network. get more information and help for Wireless Printer Configuration .
Apr 15, 2010 | HP Officejet 6310 All-In-One InkJet...
Do ineed a wireless router to have my printer wireless?
No there are some printer that came with wireless properties..........like HP 460C
Nov 02, 2009 | Epson Stylus NX400 InkJet Printer
Printing remotely from laptop -- can I?
I assume it's a Brother printer not your brother's printer right? I have an HP and it's a wireless printer which is accessible through my network, you have to install the printer driver and software on to the other laptop that is connected wirelessly to your network.
Mar 31, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wireless Printing problems Vista to 10.3.9 Mac to Brother Printer
I have a wireless Mac ,version osX.4.11. I have a Colorsmart HP Priner 4100. I have created documents in IWorks Pages. I can not print directly. I have to save the doc as a PDF email, email to myself, go to Safari, then the printer will print. What am I doing wrong?????
Feb 26, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Samsung Printing Trouble
make sure that when you go to print under propertys choose color tab and then color
Apr 07, 2008 | Samsung CLP 300 Laser Printer
Installing Vista A135 laptop in XP wireless network
I would reinstall using the Vista specific drivers from their website:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47754-1&lc=en&cc=us&dlc=en&product=439491&os=2093&lang=en
I have had a lot of problems with HP printers and Vista on our network, but this seems to fix it more times than not.
Dec 03, 2007 | Toshiba Satellite A135 Notebook
HP Photosmart C6180 All-In-One InkJet Printer Logo
2,997 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
