Question about Vehicle Parts & Accessories
Missing Instrument Light
Is there a light behind this on off switch that lights up at night when the dashboard lights come on?
    New Friend:
  • 28 Answers
There should be. It's not a big problem if there isn't. It probably just blew. It's a simple repair for a trained technician. (I wouldn't recommend trying it yourself unless you're familiar with this type of work.)
Posted on May 02, 2013
  • 1 more comment
  • john gambardella May 02, 2013
    Sara,
    Mercedes told me there is no light behind this which I find hard to believe
  • Sara Sheppard May 02, 2013
    Me too. Even my Pontiac has one.
    Thanks for your help Sara...anyone else have a Mercedes with a similar problem?
I need to know how to access light bulbs in the center panel where the heater controls are. Initially only one control backlight was out. Now light behind the rear control switch is out. Thanks
Dodge Caravan (01-03) Instrument Panel light replacement ...
? 12:25
https://www.youtube.com/watch?v=d9qi78IAPF0
Mar 4, 2013 - Uploaded by ryanthiusjunk
A common issue with the Dodge Caravan (and Chrysler Town ... I just bought a Dodge Grand Caravan (2002) and noticed that the entire dash board didn't light up at night. Needless to say I needto replace all of those bulbs and after ... do you know how to fix the 2009 caravan instrument panel lights going ...
DIY Dashboard Light Bulb Replacement - YouTube
? 8:07
https://www.youtube.com/watch?v=_bf5w3AZR_0
Jan 7, 2013 - Uploaded by Chris Punt
How to replace dashboard lights on a Dodge grand Caravan. ...Most just want to get the bad bulb out and put new one in. it seems to me the ... pull the dash panel out far enough to turn it upside down on the column and ... Bought mine at Advance Auto, but I know it is not a hard bulb to find and can be ...
2001-2007 Dodge Grand Caravan/Chrysler Town and ...
Dec 13, 2015 | 2005 Dodge Grand Caravan
Dash, dome, map lights flicker. Even when keys are not in the truck. mirrors, pwr locks and gages not working. Checked fuses, battery cables/connection. Guessing its wiring. No clue where to start..
Do you have a 'dimmer switch' on your dashboard?
A dimmer switch allows you to reduce the power /light to the instrument gauges for night driving. A faulty dimmer switch can cause those problems you describe (I'm in the UK and drive a 1998 Jeep which has an identical problem...)
If you don't have a dimmer switch the fault is likely to be a loose bulb in the instrument cluster- the gauges, or a wiring problem in the dashboard.
Nov 07, 2015 | Cars & Trucks
My dials on the dashboard don't light up
Check all the fuses for the instrument panel lighting.
Check all the light bulbs behind the instrument panel.
Replace all burnt fuses and light bulbs.
Oct 09, 2014 | 1996 Mitsubishi Montero
Where is the fuse for dashboard lights on 1995 suburban
Do you have the dash light dimmer turned off?
May 17, 2014 | 1996 GMC Suburban
Dash lights and running lights dont work
At the instrument panel fuse block, check 15A fuse 10 (indicators). In the relay center, check 10A fuse 8 (speedometer).
For "back lights" problem: At the left underhood fuse block, check the 20A HEADLAMP BREAKER. At the instrument panel fuse block, check 15A fuse 6C. Both of these supply power to the lamp control module. If you set the park lamp switch to the on position, the tail part of the tail/stop/turn lamps should light, the separate tail lamps should light, the license lamps should light, and the rear marker lamps should light. If any of these don't light check for burned out lamps, bad sockests, and bad wiring or missing grounds (black wires)
Sep 23, 2012 | 1994 Buick LeSabre
My dashboard lights are not working can not drive at night
Power for the instrument cluster passes through fuse 6 in the battery junction box and is applied to the main light switch. When that switch is set to park, 12V power passes through 5A fuse 18 in the central junction box and is applied to the dimmer module which is part of the main light switch. The dimmer output goes to the instrument cluster as well as a bunch of other stuff. If you have to troubleshoot, just work your way through the circuit as I described it, checking fuses etc. until you find the problem.
Sep 15, 2012 | 2000 Ford F150 Flareside SuperCab
The dashboard light is very dim and the light is out by the gear shift, where can I locate the switch if there is any to brighten the lights?
The is an adjuster light that lightens or darkens your instrument cluster. As for the gear shift light, that is a bulb that is located behind your instrument cluster.
Dec 15, 2010 | 2001 Ford Escape
Lights in the dashboard
Check operation & wiring at light control rheostat (left side of dash) & If everything else with electrical is OK, sounds like the bulbs may have simply blown. You will have to pull out instrument cluster to get at the bulbs.
Apr 21, 2009 | 1989 Toyota Corolla 2 Door
My dashboard light does not come up.
may need a new dimmer switch (rheostat)
Jun 11, 2017 | 1999 Jeep Cherokee
Vehicle Parts & Accessories Logo
392 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
