Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
Replace igniter how does the top cover lift up to replace igniter
Igniters on my Bosch gas cooktop not working. I guess it needs cleaning. How do I do it?
You can try to clean the two pins with degreaser and then soap and water using a skrubby sponge for delicate surfaces However, my Bosch cooktop has had problems with the igniters (particularly on two burners) which required the replacement of the control unit. This requires opening the unit completely and replacing the white plastic box and connections to each burner. It is easy enough to do, but it is a bit scary to lift off the glass as there is probably an adhesive which one has to lift the top off of. Another thing you can try is to adjust the two screws that are uderneath the removable cover of the burner. Sometimes just tightening or loosening them a bit can solve the problem
Dec 08, 2016 | Bosch Cooktops
Replacing stove top ignitor
Remove the burner cap and lift the burner the igniter is fitted through the burner and held with a circlip underneath you will probably need to lift the top to access the wiring back to the igniter pack.
May 26, 2014 | DCS Cooktops
How to replace ignition electrical contact switch
remove the kick cover over the drivers you need a torch working under the there you pull off the electrical plug then remove the two screws holding it on and lift out .when you replace it it must fit in a slot before you replace each screw .then fit your wiring plug. for those with your ignition in front of the steering wheel you remove the top and bottom cover to do the above.
Dec 19, 2013 | 2002 Nissan Altima
1996 previa wher is fuse box
on the previa, the main fuse box is located in the top of the dash board, the panel above the heater switches comes off to reveal it. There is a little level/clip just above the heater switches hidden by the curve of the panel, push and lift. Turn the ignition switch to the "Off" position. Insure the component with the suspected blown fuse is turned off. Reach under the central instrument panel cover, located above the air conditioning controls in the center of the dashboard, and press upward on the panel cover release latch. This is where most of the fuses are located in a Toyota Previa. Lift the panel cover up and off. Observe the underside of the control panel cover. It will have a schematic diagram along with the name of each circuit controlled by the corresponding fuse. Determine the location of the fuse that controls the affected component. The Toyota Previa makes use of three different types of fuses: type A, which are thin and elongated, type B fuses that resemble a box with a window in the top to reveal the fuse link, and type C, which also resemble a box with a clear plastic top. Grasp the suspected fuse and pull straight up and out. Look down through the clear top of the fuse. If the metal connector is broken and not connected, the fuse is blown. Insert a replacement fuse of the same type and amperage rating into the vacant slot. Replace the instrument control panel and press down until it snaps closed. Turn the ignition switch to the "On" position. Activate the suspected component. If replacing the fuse did not solve the problem, troubleshoot further or take the car to a qualified technician for repairs.
Read more: How to Replace Fuses on a Toyota Previa ' eHow.com http://www.ehow.com/how_4558504_replace-fuses-toyota-previa.html#ixzz1LmKZ6Zqn
May 08, 2011 | 1996 Toyota Previa
How to replace the ignition spark ignitor for Maytag MDG9700AWW - Thanks.
Access to the igniter (part #35001100) requires the removal of the top cover, console, and the front panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the top cover by removing the two 10-mm screws attaching it to the rear of the dryer then slide the cover rearward and lift it off the dryer cabinet. Take note of the notch in the top cover engaging the screw on the cabinet during reassembly.
Remove the two screws mounting the heater PCB board to the cabinet then disconnect the black and white connectors from the board.
Remove the four screws securing the console to the cabinet then rotate the console down and remove it from the dryer.
Remove the four screws securing the top of the front panel to the cabinet and the two screws at the lower portion of the door opening. Once the screws are removed, lean forward the top of the front panel and disconnect the interior light harness. Lift the panel to disengage the three tabs securing its bottom to the base of the dryer and move the panel away.
Disconnect the igniter harness and remove the single screw attaching the igniter to the burner assembly. Slide the igniter back and remove it.
Install and secure the new igniter then make sure to reconnect the harness. Reassemble the front panel, console, and the top cover by reversing the given removal steps above.
Mar 26, 2010 | LG DLEX3001P Dryer
My horn will not work and my driver airbag light is on. 2005 Saturn ION 2
sounds like some loose conectors remove the columb cover
there are 2 - 4 screws on the botom of it they are usually star or philips screws cover should fall off or may requier a tug check the wiring conectors top and botom just lift top cover up it will flex remember to keep the ignition turned off
Jan 28, 2010 | 2005 Saturn ION
How to remove the ignition switch on 2002 h-d ultra claassic
remove nut above switch retaining top cover.lift off cover switch is held by 4 screws to dash frame
Sep 21, 2009 | 2002 Harley Davidson FLHT Electra Glide...
I need to replace an ignition switch on my 1999 Chrysler Sebring convertible, how do I remove the dashboard
This is for the ignition switch like you are asking for:
Ignition Switch REMOVAL & INSTALLATION Cirrus, Stratus, Sebring Convertible and Breeze CAUTION
The Supplemental Inflatable Restraint (SIR) system must be disarmed before working around the steering column. Failure to do so may cause accidental deployment of the air bags, resulting in unnecessary SIR system repairs and/or personal injury.
  1. Disarm the air bag system, as described in Section 6.
  2. Remove the left end instrument panel cover/fuse panel and remove the retaining screw holding the end of the instrument panel top cover.
  3. Remove the instrument panel center bezel.
  4. Remove the screws that secure the instrument panel top cover to the center of the instrument panel.
  5. Lift the instrument panel top cover enough to gain access to the knee bolster attaching screws.
  6. Remove the lower knee bolster attaching screws and knee bolster from the vehicle.
  7. Remove the lower steering column cover attaching screws. Pull down on the lower cover to clear the ignition key cylinder and key release (if equipped).
  8. Remove the lower steering column cover, sliding the cover forward while holding down the steering wheel tilt lever.
  9. Tilt the steering wheel down to the fully lowered position and remove the upper steering column cover.
  10. Remove the screws that hold the combination switch to the ignition lock housing.
  11. Place the ignition lock cylinder in the RUN position.
  12. Insert a small prying tool into the hole in the lower cover and depress the cylinder release tab.
  13. Remove the ignition lock cylinder from the steering column.
  14. Unfasten the electrical connectors from the switch.
  15. Using a No. 10 Torx® bit, remove the ignition switch mounting screw.
  16. Depress the retaining tabs and remove the switch. To install:
  17. Place the ignition switch in the RUN position. Be sure the actuator shaft in the lock housing is also in the RUN position.
  18. Install the switch, making sure the switch snaps over the retaining tabs.
  19. Install the retaining screw.
  20. Connect the wiring to the ignition switch.
  21. Install the ignition lock cylinder.
  22. Install the 2 combination switch mounting screws.
  23. Install the lower and upper shrouds.
  24. Install the knee bolster to the lower dashboard panel and tighten the lower knee bolster attaching screws.
  25. Install the screws that secure the instrument panel top cover to the center of the instrument panel.
  26. Install the instrument panel center bezel.
  27. Install and tighten the screw holding the end of the instrument panel top cover. Install the left side instrument panel/fuse panel cover.
More coming.....
Jun 26, 2009 | 1999 Chrysler Sebring
1997 bmw 328 convertible top deck lid strut replacement
NEED YOUR EMAIL TO SEND SOME IMAGES.
HERE ARE THE STEPS TO FOLLOW.
REPLACING LEFT AND RIGHT GAS STRUTS FOR SOFT TOP COMPARTMENT COVER :
  • Remove soft top compartment cover.
  • Lift soft top out of soft top compartment.
  • Lift gas strut out downwards, insert in available bore and lower the linkages.
  • Remove tab washer, raise gas strut upwards and lift out.
HOPE THIS HELPS
May 29, 2008 | 1997 BMW 328
Change spark plugs
My 2004 Verona had factory installed "NGK BKUR6ETB" regular spark plugs which I replaced at 30,000 miles. The 2005 model year is supposed to have Iridium spark plugs. To replace the spark plugs: 1. Remove plastic top engine cover. 5 nuts 10mm socket. 2. Unplug connector from each ignition coil. qty 6. 3. remove 2 hold down bolts per ignition coil. 10mm socket. 4. remove ignition coil, lifting straight up. 5. Spark plug is now accessible, use deep well 5/8 spark plug socket to remove.
May 15, 2008 | 2004 Suzuki Verona
Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
16 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
