Question about Whirlpool RF368LXKS Electric Kitchen Range
My oven will not heat to desired temp - Whirlpool RF368LXKS Electric Kitchen Range
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Check the temperature sensor with a multimeter. It should read around 1100 Ohms at room temperature. If you get a reading a lot higher or lower (by 500 Ohms or so) replace the sensor. Here is that part to order.
Posted on May 03, 2013
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
Oven not heating up to desired temp.. Keeps clicking
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 ]
Jul 18, 2011 | GE Spectra JBP78 Electric Kitchen Range
Oven does not heat to desired temp. It is a GE spectra
heatman101
Jan 04, 2011 | GE Profile JT912 Electric Single Oven
My GE oven heating element heats red hot no matter what temp I put the oven on
Something is probobly wrong with the thermostat, it gets hot to warm up, but should lessen as it reaches your desired temp. If the thermostat is bad it will just keep going.
Nov 20, 2009 | GE Profile JTP18 Electric Single Oven
The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
Nov 09, 2009 | Thermador SMW272 Electric Double Oven
After temp is set bottom oven will not heat up to desired temp
you probably have a burnt out or shorted out lower bake element in you r lower oven. it sometimes will actually break apart or look like it sparked thru the black tubular section. it is common and will cause no heat during the bake cycle.
you could try to do a broil and see if it gets hot and that would let you know the control is ok and just needs the lower bake element.
Jan 28, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
Nov 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool RF368LXKS Electric Kitchen Range Logo
48 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
