Thr128 oregon My husband bought an THR128 Oregon Scientific meter. He passed away and i cannot find the instructions. The outdoor temperature will not read indoors. We changed the batteries on the outdoor pad but still won't work
bobotfel
  • 236 Answers
SOURCE: blinking indicate at indoor unit
reset your unit by disconnecting the power supply for 10sec. and "on " the unit for testing. if error persist you need to replace your thermistor.
Posted on Jan 26, 2009
  • 68 Answers
SOURCE: indoor an outdoor unit wiring diagram
have you tryed to look it up on the net.a lot of the time you can get that sort of info off the web
Posted on May 02, 2009
  • 1250 Answers
SOURCE: indoor unit does not function -outdoor unit works
These units have circuit boards inside that have lights on them. These lights come on and tell you what the problem is. I have had 4 units do the same thing that yours is doing. The result has been that the compressor has gone bad. You have to get access to the control board to see the lights. There will either be one inside the inside unit or one inside the outside unit depending on exact manufacturer date.
Good luck and hope this helps.
Posted on Aug 23, 2009
kb8dns
  • 494 Answers
SOURCE: dashes in my outdoor weather reading of Oregon Scientific station
The signals are not being received by the main unit. Try to reposition the unit or move it to a different location. Also make sure the antenna is in the clear and not next to any thing like a cordess phone or charger as these can make RF noise that can block or cover the needed signals.
Posted on Feb 11, 2010
  • 81 Answers
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
How do I get the -- away and get the outdoor temperature to work?
You may have to "reset" it by removing both indoor and outdoor unit batteries, waiting briefly, then reinstalling batteries in the outdoor unit followed by the indoor unit. After awhile, the outdoor unit should begin sending information to the indoor unit.
Nov 20, 2014 | Oregon Scientific Wireless Weather Station...
The putdoor temperature will not come in
Check batteries in outdoor unit and try moving to closer to the base station.
Apr 08, 2014 | Oregon Scientific Wireless IndoorOutdoor...
Oregon scientific model no rar186 how to set up outdoors sensor
I have had this Oregon Scientific model RAR186 unit for years and it works great. The only issue I ever have is when the batteries need to be changed in the remote sensor unit (Oregon scientific model #THN122). It never fails that once I change the batteries that the unit does not send a signal to the base unit. I will often hit the reset button and change the channels on the remote sensor before I finally remember that you need to do the following to get the sensor to talk to the RAR186 base unit:
On the base unit (RAR186), hold down the CHANNEL and MEM buttons for at least two seconds.
You will then see a graphic appear above the channel number that shows that it is searching for the sensor.
Within a minute, you will then see the temperature displayed for the sensor showing that they are communicating.
This is buried in the manual that you probably discarded as did I.
Apparently, if your sensor is broken, you can either search to find a new sensor of the same model or also use the following sensors: THC138, THGR122NX, or THN132N
I have not needed to replace the sensor as once I found the instructions to reset the communication between the sensor and base unit, all was fine. Hope this helps someone. I wrote this instruction using a Sharpie on the inside cover of the sensor since you have to remove 3 screws to replace the AAA batteries (2) in hopes I will remember next time and not waste my time searching the internet and not find the answer. Good luck!
Apr 02, 2013 | Oregon Scientific Measuring Tools &...
Model no 217s31 does not display outdoor temperature reading.
As much as it sucks to do, you have to reset the base and the temperature sensor. When you do it, keep the temp sensor next to the base until the base recognizes it.
Mar 11, 2013 | Oregon Scientific BAR386 Wireless Weather...
I See my Outdoor temp. Nothing
What do you mean nothing? How are the batteries? What channels are you using?
Feb 22, 2013 | Oregon Scientific BAR386 Wireless Weather...
ONLY SHOWS INDOOR TEMPERATURE DOES NOT SHOW OUTDOOR TEMPERATURE
I have a similar device and the instructions say to remove batteries from both units and wait for 10 minutes without pressing any buttons before installing batteries first in the remote unit then the indoor unit. The outdoor and indoor units have to "talk" to each other before getting in the mood to display temperatures.
Feb 03, 2013 | Oregon Scientific Wireless IndoorOutdoor...
Dashes in my outdoor weather reading of Oregon Scientific station
Feb 07, 2010 | Oregon Scientific Audio Players &...
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
