Question about Vehicle Parts & Accessories
99 honda passport dash light
Dash board lights won't come on when I turn my lights on.
Check your fuse or either your dash unit lights are out.
Posted on May 03, 2013
4 Suggested Answers
  • 368 Answers
SOURCE: my car died on the
The first thing I would check is the battery and the battery connectors. If the battery or connections are defective or discharged it could have this problem. Unfortunately other things could cause this. If the battery is discharged it could be caused by other components like the alternator.
I hope this helps.
Posted on Sep 07, 2011
anthony_ayen
  • 22 Answers
SOURCE: Tail lights dont come on or my running board lights but headlights work
first check the bulbs if they are busted. if not check the connection. headlights park lights and tail lights are on the same circuit so it seems that there is no problem in your relay. also check the switch if its working properly.
Posted on Mar 31, 2012
  • 34759 Answers
SOURCE: battery light came on the dash board and shorty after lights dims
Your battery is discharging, either because it is in need of replacement or your alternator cannot recharge it
Posted on Nov 19, 2012
Dash lights and tail lights do not work in my 99 honda accord
My dash light doesn't work either, I lose lights in dash at night when I have the headlights on. As for your car, thats kinda weird your fronts work but not the back. Have you already checked the fuse boxes? they are on the driver and passenger sides almost under the dash in front of the doors. If all your fuse are good and in the right spots, then I would check the bulbs out back to make sure they are not rusted inside or cut or something like that.
Apr 06, 2013 | 1999 Honda Accord
1999 lincoln navigator turns over won't start dash board lights stay on with key out.
sounds like antitheft system is acting up..needs reprogramed maybe..pull the negative cable with the key on....kills everything..then shut the key off..reconnect the negative.. turn the key to run position for a few seconds(resets all factory presets) see if it will start..
Feb 10, 2013 | 1999 Lincoln Navigator
Rear running lights and dash lights do not work in my 1996 Honda Passport
it's the relay behind the kick panel. Drivers side near the floorboard. To the left of your left foot there is a plastic cover, pop that off and there will be 3 or 4 relay fuses there. Swap em out with eachother until you figure out which one it is. When you go to purchase another one, get the fuel pump relay (they're the same) and it's ALOT cheaper! lol
Oct 14, 2012 | 1996 Honda Passport
Honda odyssey parking lights won't go off
Most likely ignition wire in steering coloumn needs replaced.
Sep 20, 2012 | 2003 Honda Odyssey
How to replace 1998 Honda Accord Dash Board Lights
1998 honda accord v6 fully loaded 191 k on it and my dash lights stop working and the lights where my ac control as well stoped too ,, i turn on the head lights an there no lights in the dash nor the ac contrlos what is it
Apr 01, 2012 | 1998 Honda Accord
Please help......!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Dash lights don't work anymore after installation of a new cd player. I have a 1999 honda passport. There are two 'extra'...
Sure about the connection,you are supposed to use audio fuse circuit 2 and or audio fuse 19. the color out are Red/yell, Red/white. This comes from the dash box fuse
Mar 14, 2012 | 1999 Honda Passport
Dash board lights
Check the fuses. Under the steering wheel. If the fuse for the dash lights is blown, replace it. If it blows again, replace it again and look into what could cause the short.
The lights may also need to be changed in the dash.
The switch to turn on dash lights might be bad. If this is so, outside running lights won't work either.
Sep 07, 2011 | 1995 Eagle Talon
Dash lights wont work
Some Honda vehicles illumation wire (orange wire)is switched ground. Once connected, turning your lights on will blow your 'small lights' fuse which is a constant power fuse that should be located under the hood. you should just cap off (do not connect) the orange wire and replace the fuse.
May 20, 2009 | Pioneer AVH-P5700DVD Car DVD Player
New radio installed - now dash lights don't work
Most factory stereos are wired to the dash dimmer switch. Usually if the dash lights go out after an after market stereo installation, it is because the wire that originally went to the factory stereo is not used for after market stereos. Double check the fuses and ensure the wire that controlled the lights on the factory stereo is not grounding out on something.
Nov 11, 2008 | 1998 Honda Passport
Vehicle Parts & Accessories Logo
60 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
