Question about Garden
Mower wont run
Bought this second hand so don't have book to tell me how to tune or troubleshoot. Have difficulties starting and then can't keep it running. Cleaned carb to no avail. Anyone help?
  • 23 Answers
Make/model/year of your mower
Posted on May 11, 2013
  • 27 Answers
SOURCE: 99 kawasaki kx 125 2-stroke wont start or stay
I would check the compression of the piston, the rings could be stuck and not have good compression. It should show 120 psi or more. Also can pull off the exhaust and look in the exhaust port to see the rings, piston, and cylinder walls. If the motor has a power valve make sure that is not gummed up or stuck. Mark C
Posted on Jun 02, 2011
Testimonial: "It was good advise, I still have not fixed the problem, but we are working on a solution as we speak. trying to narrow it down and we are close"
SOURCE: my 1971 ts250 wont idle
i fixed the problem simply by adjustingthe screws on th side of the carb. my dad had messed with it for an hour or so the day before... the next day he left town and after i spent 15 minutes or so dinking aroud it ran and idled fine. (of course if u ask him he got it close for me.) ( ;
Posted on Mar 27, 2009
  • 3567 Answers
SOURCE: wont run...
Any water in the gas? Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Drain a cup of gas from the tank. Any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Get a fresh set of stock NGK spark plugs. Clean or replace the air filter. You seem to be pretty thorough in what you have done, but since plugs and filter weren't mentioned I had to ask.
Assuming you are getting air, gas and spark, and the timing is correct then it should run. Right? Not necessarily. Can the bike breathe? If pressure cant get out of the tailpipe the bike won't run. Mufflers can sometimes collapse internally. This restricts the flow of burned gasses. causing backpressure. If nothing goes out of the cylinder then nothing goes in.
Try removing the exhaust pipes. Now see if it will run. Get back to me because I would like to know what you find.
Posted on Mar 29, 2009
bozcro
  • 867 Answers
SOURCE: 99 CBR will start but wont run
did you check the fuel filter and fuel supply?
Posted on Jun 14, 2009
  • 47 Answers
SOURCE: bike turns over but wont start
check needle setting and flote setting in carb
hope this helps
Posted on Jun 17, 2009
Mower starts and runs but won't move forward or reverse and brakes don't work.
If your transmission is automatic on the drive axle, look for a small lever inside the frame and below the seat. It can be hard to find the first time. This lever disengages the drive inside the auto gearbox so the mower can be pushed by hand. If the lever is not not moved, pushing the mower also tries to turn over the engine making it impossible to move. With the lever moved accidentally the drive is disengaged and the mower won't move in either direction. The lever operates a flexible cable that comes out from the auto transmission.
Dec 12, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Please stop telling people Rolex watches don't tick.
Yes, absolutely correct , all automatic watches tick and the fake Rolexes just tick a bit slower so it is more visible.
Oct 08, 2012 | Rolex Watches
Bell & Ross automatic chronograph seconds hand problem
You might want to post this question in a different section. This is the computer section...
Jul 13, 2012 | Computers & Internet
Replaced key and reset cam and crank timing on briggs & stratton, still wont start
i you don't have a blade on it they will not run either
Jun 02, 2012 | Garden
Craftsman 6.75hp 22 mower starts for a few seconds and concks out
If the carbeurator is pitted or corroded in any way you need a new carbeurator
Steve's Small engine repair & Blade sharpening
Jacksonville. Fl
Feb 08, 2012 | Craftsman Garden
My brother Se 400 which is only a few months old just started running really slow. When I disconnect the foot petal and do the manual botton "the arrow button" it still runs slow. I don't...
have you checked to make sure the power cord is pushed in correctly?
if the power cord isn't the problem then it may need to be checked by a service tech, because it's not suppose to be running slow just a few months after you bought it.
I would call the people you bought it from & tell them what it's doing & see if they'll give you another one, I've been sewing for 30+ years & I wouldn't keep the machine.
good luck
Sep 22, 2011 | Brother Sewing Machines
Hi I'm planning to buy a second hand Honda CB400
Hi, E-mail Honda themselves with this question & details they will be able to tell you very quickly. Please leave me feedback, best wishes, Malcolm Campbell.
Sep 04, 2017 | Honda Cb 400 F Motorcycles
Submariner 16610 M Model has 40 seconds faster
I don't know if I can help you out, but I can tell you that even a low quality Daytona, or Submariner copy can be adjusted. My 1992 Daytona copy is at about 10 sec a month fast. I read a **** load about the movement, and did the adjustment myself. Any watch shop that tunes watches can do it.
I don't know what year your Submariner is, but today Rolex is using a new main spring (it is now blue). I would think a replacement spring would be the most you might need, but a good tune-up should do the trick. If it is real, I would think about sending it to Rolex for cleaning and a tune-up ($$$).
Jan 27, 2009 | Rolex Daytona 116520 Wrist Watch
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
