Question about Poulan Garden
Poulan chain saw dies when ran wide open
I am trying to get this poulan 16 inch 34 cc chain saw to run right. When running it wants to die out. It idles fine.
  •  Bill Catoire
    Bill Catoire May 03, 2013
    Sorry to the other man who posted to adjust the carb. If you adjust it right it will run. After rebuilding the carb, tearing into three or four times. It finally paid to adust the high and low. Also had to reajust the idol on it. Seems that small engins don't like the ethonoyl in the gas. It eats up everything.
  • Poulan Master
  • 7,482 Answers
Hi bcat913
Posted on May 03, 2013
2 Suggested Answers
  • 5603 Answers
SOURCE: poulan model 1800 gas chain saw will not stay
Likely needs carburetor rebuilt. The fuel is pumped by a diaphram that runs off the vacuum pulses.
Another thing to check is a plugged fuel filter or an air leak in the fuel finder hose in the tank.
Posted on Oct 23, 2009
Chainsaw runs then dies
Carburetor needs to be overhauled and replace all fuel lines and fuel filter.
May 06, 2014 | Poulan Pro Chain Saw. 18 in. 42 cc Gas...
Huaqvarna chainsaw 240 runs then quits
when ??? dies at wide open throttle ??? dies at idle ??? dies it restart right away or take an hour or more ??? did you put the right 2 cycle mix in the gas tank ???
Nov 27, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Poulan 16" saw, start fine, runs fine until it
A couple of ideas, it could be a fuel tank breather issue, when it starts to die just try loosening the fuel cap, if the saw picks up again you will need to change the breather, the only other thing i can think of is a bad ignition that is breaking down when hot, the only aswer to this is to replace the ignition unit
Apr 08, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan chain saw will not stay running after i start it. What are the carb settings ?
a good starting point is the low speed screw at 1 3/4 turns and the high side at 1 1/2 turns. Hope it helps
May 20, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Chain doesn't move / clutch
Starts then.... you hit the trigger... ba ba ba .... dies ?
Check fuel filter in tank, make sure air cleaner is clean.
Make sur your mix is correct.
Feb 04, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Dies when pressing the accelerator
If your chain brake is not engaged, which i am sure you have checked, look at the air breather filter or the exhaust muffler which could be blocked with carbon.
Jun 08, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Dies running wide open
Hi
Check the air and the gas filtetrs.Change the plug with a new one with the same heat range.Adjust the carb H and L.
High speed H=2 turns and low speed L=2 1/2 turns
best regards savumihai71
Jan 29, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
552 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
