Question about Toshiba Portege M100 Notebook
Battery or charger
When i tried to turn on my portege all i heard was beeping noises coming from the adapter it has a shorted out battery and the only way it would turn on as if it was plugged in so from then on it would turn on only by being plugged in then one day it didnt turn on when i plugged it in and i heard beeping noises coming from the adapter i dont know wheter if its the battery or the adapter or both
3 Suggested Answers
  • 1253 Answers
SOURCE: The AC Adapter makes a beeping noise and doesn't charge the batt.
I would verify that the battery will take a charge. If the battery is bad, the charger will tell you that it is not charged. It will not tell you why, just that it is not charged. If not plugged into the computor,again, battery is not charged. Hence, the beep.
Good Luck and hope this helps.
Posted on Mar 15, 2009
info2u
  • 596 Answers
SOURCE: I heard a "snap" noise and my laptop shut down
Most of the time when you hear that kind of noise and it was plugged into the AC adapter, a power surge hit your pc and it will need a new mainboard to power back on.
Sorry for the bad news.
C2Solutions
Posted on Feb 10, 2011
I have a Toshiba Portege M780. My AC is plugged in and with battery but indicator(Orange) blinks several times and pauses, and then does it again. It will not turn on. How can I fix this?
If your laptop won't turn on with the AC adapter plugged in, I'm afraid you've got some serious problem with your motherboard.
Of course, the problem might be your battery burned out, so to test, remove the battery and plug in directly your AC adapter. No problem to do that, people use laptops with onlt AC adapter, without battery, to save battery life.
Did it turn on? if it did, buy a new battery, that should solve the issue.
If not, you should check if your AC adapter works. You need an electronic voltimeter/amperimeter and you should check output rating. It it is the specified, your charger is ok and the problem is in your laptop, you should take if to repair service.
Once again, if the problem is with your charger, get a GOOD charger, and test if you can charge your battery. Also, with a good chager and no other problem, your computer should power on.
Oct 08, 2015 | Toshiba Computers & Internet
My Toshiba Portege Z10t will not turn on. No lights, I have tried to start it with and without the power chord connected, have held the on switch down for up to 10 seconds with out any response. The u
Try this:
Unplug the charger from the unit (but leave it plugged into the wall outlet) and remove the battery. Push the power button and hold it down as you plug in the charger. You may have heard of soft boots and hard boots...this is like a super hard boot. If it starts up, you can reinstall the battery. Good luck.
Jan 11, 2015 | Toshiba Computers & Internet
Toshiba Satellite U405-S2824 startup beep code error
The beep you hear is a BIOS Beep Code. The computer's way of telling you something is wrong, and a general area to look into for it.
A short repeated beep over a long period, usually indicates a Ram Memory problem.
Remove ALL power to the notebook. Remove the AC adapter (Charger), and Battery.
Suggest you remove all ram memory modules, and clean the gold plated contact pins at the bottom.
Use a pencil eraser. If using an eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band touch the contact pins. Reinstall the ram memory module/s.
Reinstall the Battery, then the AC adapter. WAIT 1 minute, then turn the notebook on.
Post back in a Comment as to the results.
Regards,
joecoolvette
Dec 31, 2011 | Toshiba Satellite U405-S2824 PC Notebook
AC adapter/charger is attached, but the battery will not charge. it doesnt even show that the battery is there
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Toshiba Portege M200-S838 Tablet PC
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
E6500 making a beeping noise
Does beeping noise happened before turning on laptop? If yes unplug the laptop from the AC Adapter. Just leave AC Adapter ON and connected to the power outlet. Check if AC Adapter is the one making beeping noise. Note: This is an issue with dell AC Adapter laptops
If no beeping noise in AC Adapter then proceed checking it from the laptop. Does beeping noise happened immediately when laptop is turned on? If yes then it might be laptop's hard drive creating the sound. Try to check the BIOS in your laptop under the category performance if the HDD Acoustic is ON either in Normal or Performance. Note: When laptop is in performance the hard drive makes noise due to its speed, this is normal if BIOS HDD Acoustic mode is ON to performance.
If the noise only happens when sometime while working on the laptop, this might be cause by the laptop fan. This also happens after turning on the laptop fan my have dirt and dust, please do check.
If fan was cleaned, HDD performance was checked and AC adapter was checked then, carefully sense if noise is coming from the internal speakers.
Download the latest BIOS update for your laptop then flash the BIOS. Make sure battery and AC adapter are connected when doing these.
Dec 11, 2009 | Dell Latitude E6500 Laptop
Mar 15, 2009 | Toshiba Portege R100 Notebook
When i plug my acer desktop in it only beeps and will not boot up. The monitor sill say no signal then turn black.
Check your RAM or Video Graphic Adapter..
Beep Codes
1 long, 2 short - Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
Any other beep(s) - RAM problem.
Sep 23, 2008 | Computers & Internet
The power cable light on my Toshiba Portege 2010 flashes yellow/orange when the plug is inserted. Computer will not turn on (green light on power button doesn't even come up). Have tried: 1) starting up...
One thing could be that your A/C adapter has failed resulting in your battery not being charged. This would explain why you're experiencing the same symptoms w/ or w/out the A/C adapter.
Apr 04, 2008 | Toshiba Portege 2010 Notebook
Toshiba Portege M100 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
