Question about Oregon Scientific Measuring Tools & Sensors
How to reset the thgn132n weather sensor - Oregon Scientific Measuring Tools & Sensors
My Smart Gear STG-6007-BB weather station won't pick up the outdoor temperature from the remote sensor. I changed the batteries and reset the unit, but it still doesn't work. Any suggestions?
  • Remove all batteries
  • Install batteries in remote sensor. Allow time for it to begin sending temperature information
  • Install batteries in indoor unit. You should see temperature displayed
Cold weather can cause loss of temperature information
Dec 17, 2016 | Measuring Tools & Sensors
How do I reset the time on my smartgear weather station
I have two of these and they lose the signal occasionally. Per the manual: Make sure all batteries are good and then press the TX button on the remote sensor for 3 seconds so it sends a wireless signal to the weather station. It should beep. Then on the weather station hold the CH button for 5 seconds to make it search for the transmitter until the outside temp appears. Just removing batteries and reinstalling them in various orders doesn't work. You must re-establish the wireless connection between the outdoor sensor and weather station.
Mar 08, 2015 | Measuring Tools & Sensors
Unable to cancel min. wind chill reading wnen current display reads NA; thus 5C still shows from a day in April!
There is a reset button on each sensor unit and there is a reset on the base display. The NA means that the signal is not being sensed from the remote. If you use the reset button on the base you will lose all the historical data. The problem may be related to strong interference from something else nearby, You can bring the sensor inside to see if the base picks it up. IF it does not it may need to be replaced. I have dealt with Oregon Scientific before and they are very good with their support. http://www.oregonscientificstore.com/WMR86A-Oregon-Scientific-Backyard-Pro-Wireless-Weather-Station.product
Jun 27, 2014 | Oregon Scientific WMR86A Backyard Pro...
My remote sensor Tx14TH-LCD-B started flashing several days ago and I have gone thru the factory reset new batteries and decided to buy a new sensor then discovered they have been discontinued along with...
I assume you have tried removing the batteries at both ends, reinstalling batteries at the sensor end then the indoor end, waiting without touching anything until the outdoor temp registers and heaving a sigh of relief as things are back to normal. I also assume since the word atomic is in the header that you have an atomic clock function. If nothing works or doesn't work right you probably need to replace the system.
I have a much simpler LaCrosse system which, at this moment, is showing an outside temp of 56 degrees BUT the clock doesn't work and failed early on. I share your frustration.
Nov 04, 2013 | La Crosse Technology La Crosse S98642...
Sensot does not work on outside temperature
You need to pull the batteries out on the sensor, reset the main unit and then have it check for sensors again. If it does not find any, replace the sensor.
Aug 17, 2013 | Oregon Scientific BAR208S - Silver...
Model no 217s31 does not display outdoor temperature reading.
As much as it sucks to do, you have to reset the base and the temperature sensor. When you do it, keep the temp sensor next to the base until the base recognizes it.
Mar 11, 2013 | Oregon Scientific BAR386 Wireless Weather...
I have inherited a IT-915 MHz wireless temp. station--the batteries in outside sensor were taken out but still in box-can i put them back in at this time to reset the sensor and how to set them ?
You shoud use new batteries because you dont know how old the ones that are present are. You should also use lithium battteries in the weather station sensors because they last longer and have better low temp response. The batteries should have marks on them that correspond with the marks inside the sensors.
Feb 23, 2013 | Weather Channel It 915 Mhz Solar Powered...
WMR928NX battery replacement
I have an Oregon WMR928NX weather station. I have replaced the alkaline batteries in the wind and rain sensors. These did not communicate with the main unit, so I reset both units but only the wind sensor communicates. I have checked both battery voltages on the cuircuit board and both are correct, I don't know a solution. Thanks Rob
Nov 23, 2010 | Oregon Scientific Cable Free Weather...
The weather Forecast Icons don't change on my honeywell weather station model # TE852W
This problem could arise due to various reasons
1)Replace the batteries in remote sensors
When the batteries are properly installed, the remote weather sensor will resume sending signals to the main unit.To enforce an immediate remote signals search, press and hold
DOWN on the main unit.
2)Remote thermo-hygrometer sensor could be weak in sending the signal about weather Forecast.Test it properly.
3)Reset the unit and check
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 11, 2010 | Honeywell TE852W Weather Forecaster With...
Measuring Tools & Sensors Logo
85 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Lawrence Oravetz
Timllfixit
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
