Why wont my hitachi telly turn on? - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 45,018 Answers
If it is plugged in to a working outlet and the front panel power indicator is on but it still does not turn on, it is likely that there is a problem with the internal power supply
Posted on May 02, 2013
I have a PENTUS 27" LCD TV and when I turn on the
Hi this is a very common problem, the problem is to do with the inverter board inside the telly this board will need replacing before the telly will work again, its not something you can do yourself as the inverter board requires the whole telly to be taken apart and the screen coming out of the case just to get to the inverter, shop around some of the tv repair shops and see what prices you can get,
if the telly is less than a year old then have a word with the shop you bought it from as you may be covered by warranty as you usually get 12months warranty.
if its older than 3 years then you would be better off replacing the telly as it wont be long before something else starts failing on it.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts.
im sorry i couldnt give you an easy fix but without getting this inverter board changed it just wont work, the board itself is not that expensive to buy but its the hourly rate that costs so shop around and see what quotes you can get on the cost of repair, check any warranty first as this fault will be covered
Nov 13, 2010 | ViewSonic 27 in. LCD TV
Blue haze in center of screen yellowish circle
hi you see alot of these types of tellys with your problem or similar problem and they all lead to the same fault i dont think the problem will be the optic filter the problem is more likely going to be the convergence ic it is best to replace both of them as replacing one usually means youll come across problems with the other sooner or later getting these replaced will put your telly back how it was and youll find that you wont have this problem again for a good while.
Most tv repair shops will have ample experiance in this fault and if you ask them they will tell you the same as i have.
Now if you have the equipment to do this repair yourself then you will need to get the schematics for your telly and any part numbers youll need.
It is also worth checking any resistors as well as often these will go when the convergence ic go this will need testing and replace any as needed.
If you are going to get someone else to do the repair then the cheapest way is for you to take the telly to them as you will get charged for call out and for transporting your telly so to avoid this unecessary charge take it their yourself.
Let me know if you need further assistance ok
Jan 15, 2008 | Hitachi 50V720 Television
Panasonic CT32SF wont turn on
Dont know spec of this model but if it has a CRT (glass tube) display rather than a LCD one, clicking at switch on is idicative of a power supply overload which, 99 times out of a hundred on a CRT telly is down to a fault in the power supply itself or the line output stage (the bit that generates the very high voltages in CRT tellys and also makes the picture scan left to right).
In short, not a DIY fix - take it to a repair shop.
Sep 07, 2009 | Panasonic CT-32SL14 32" TV
HDMI conneection wont override tv picture
I am a sky engineer (not a subby)
the reason this does not come on straight away is because a Scart lead send power upto your telly when it is turned on. Telling the telly that this is what you want.
Unfortunately HDMI does not send power upto the telly. There are ways around this. ON Samsung, Panasonic and Lg tellys you can go into a secret menu and apply something called HOTEL MODE this allows you to change the av input so it would automatically come on your hdmi 1,2,3, etc
In your case follow my instructions below
go to the hdmi you are using for your Hd
on the sky remote
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice. what this mean is when you press your Sky button, tv guide, services or interactive button to turn the sky on this will automatically change your av/source on your telly to the sky HD for you
You owe me a pint
Have a good one
Little Dish Fitter
Jul 19, 2009 | Microsoft Xbox 360 Console
Green light flashing under standby light and wont turn on
hthis is either a power peoblem or another board if it is still underwarrenty you can get it fixed with no charge
Jan 18, 2009 | Toshiba 28N33 28" TV
Tv wont come on
Sounds like you have the tv set to the wrong input.
Dec 18, 2008 | 321studios DVD X Copy Platinum (200000)...
No picture or sound
the same thing happened to mine.turns out it was the bulb in the back of the telly had blown.if i hadnt been insured it would of cost me £200 to repair.
Aug 02, 2008 | Hitachi 57F500 57" Rear Projection...
Hitachi 42PD8700 U
switch on the dvd player so it's playing, then do a new master tune. press the dtt/tv button so you are watching the internal freeview system, then press menu, then go to installation, and re-install all channels. the tv will then detect your dvd player in the intial set up/tune mode.
hope this helps..
Oct 17, 2007 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
