Question about Motorola MC9500-K Handheld Mobile Computer - P/N MC9596-KDABAC00000 Portable Terminal
Mc9590 locks up after suspend mode,have to pop the battery to make it work again
  • Official Brand Answer
  • 3,100 Answers
Anees
The manufacturer of this device doesn't provide support on FixYa.
Contact Motorola Solutions Get Support or Zebra Technologies Support Downloads .
Mark
Motorola Mobility Support
Posted on Jan 17, 2015
How do I do a factory reset on a MC9590
Howdy,
You did not specify if the phone can start up or not. If the phone can start up, its very easy to perform a hard reset from the SETTINGS MENU
Open Main Menu -> Settings ->Security.
To open Security options type in lock code. (Default code is 0000 or 1234)
Select Erase/Reset afterwards go to Reset Phone.
Read the disclaimer, pressing Yes will confirm operation.
Success! After restart handset will be ready to work on.
PLEASE BE AWARE THAT THESE STEPS WILL MAKE YOUR PHONE GO BACK TO THE WAY IT WAS PURCHASED.
Dec 09, 2014 | Zebra Symbol MC9590 Barcode Scanner
What hearing impaired headset works with the Motorola MC9590?
It is best you contact Motorola Solutions http://www.motorolasolutions.com/support for your accessibility question.
mark
motorola mobility
Jul 30, 2014 | Zebra Symbol MC9590 Barcode Scanner
Where is the Serial Number on a Motorola MC9590
Hi
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Feb 11, 2014 | Motorola MC9500-K Handheld Mobile Computer
My Motorola MC9590-K keeps telling me the USB device is not recognized when I connect with the cradle. The unit does it even when I use a different cradle.
Is it the right cradle to connect. Sometimes the cradles look alike but actually are different. You can check the back and the bottom and see whether all the ports are the same between those cradles. Replace the battery and see if you suspect that is a battery issue. Some of those batteries are not really endurable.
Sep 10, 2012 | Motorola MC9500-K Handheld Mobile Computer...
I have an aqualink RS6, when i press the waterfall button, the display reads locked out. how do I remove the locked out
If your trying to turn on from a inside or spa side controller, then most likely the main control panel is either in time-out, or service mode. When the main controller is in either of these modes it locks out the other controllers. This is designed so if a service tech is working on the system, a user cannot turn something on. Try looking at the main controller and look for a mode button. It will toggle between, auto, time-out, and service. auto is normal operation, time-out should suspend the system for about 3 hours, and service mode suspends the system indefinitely until the mode is changed.
Sep 19, 2010 | Pool & Spa
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
The comp switches on but theres no display
take the RAM out of the slot then insert it again, then check
Nov 27, 2008 | Computers & Internet
Window resume loader
Windows Vista doesn't shut down the machine by default when you press the power button. Additionally, if you look at the bottom of the start menu you'll see this:
The button on the left, highlighted here in bronze, does NOT turn the machine off in Windows - it suspends it, which requires power. When the battery runs down, the power goes out and you get this message the next time you start up.
Some laptops also indicate suspend mode by flashing the power light.
Happily, if you click on the little right facing arrow a menu pops up, one of the options of which is "Shut down" and this will bring Windows down properly and fully.
You can also change the function of the power switch (which defaults to suspend, NOT shut down) by going into the power options from Control Panel:
Selecting one of the above options will allow you to set the power button and closing the lid to turn the machine off fully, not suspend it.
May 27, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
It won't turn on!
Flashing green battery means it is in suspend mode. Pushing the power button should bring it out of suspension, however, one of the reasons I deactivate both suspend and hibernate mode is because the seldom work right. I would disconnect your A/C power cord and remove your battery from the laptop. After about 30 seconds plug them back in and your commuter should start again. Let us know how things go.
Dec 31, 2006 | Averatec 3200 Notebook
Motorola MC9500-K Handheld Mobile Computer - P/N MC9596-KDABAC00000 Portable Terminal Logo
81 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
