FixYa.com
Tags:
D-Link AirPlus Xtreme G DI-624 Wireless Router
DI-624 can't login as admin (by 4 users)
posted by Marinchik on Aug 08, 2007
I am trying to login as admin, to be able to change the default password and secure the signal, but the default username does not let me log in. I'm using 192.168.0.1, login-admin, password-(blank). How can I login as admin?
Thank you
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Apr 12, 2008
user name and pass is not correct why
Comment by Guest, posted on Mar 31, 2008
I am having the same problem with my DI-624. I cannot use "admin" to log in (with blank password). I held the reset button for 20 seconds hoping it'd reset it back to factory settings but that didn't help either.
Any other suggestions?
Comment by dag219, posted on Dec 10, 2007
I have the same problem with my DI-624. With just a connection between my desktop and the router, I type in http://192.168.0.1 in my web browser and it takes me to a login window for the router. I type in "admin" and leave the password field blank and hit "ok." But then it just refreshes the login screen. It does that twice before failing with a "not authorized" on my browser. What is going on?? How can I login to this router? If I type in "user", it lets me right in, but I can't run the wizard since it says I'm not the admin. Please help! :-)
Best Solution
posted on Aug 08, 2007
Helpful (85)
informatica
Rank:Guru Guru
Rating: 89%, 866 votes
Try connecting directly to the router with a cable as if there is a problem with the wireless connection then you won't be able to connect. If you are already connected directly then reset the unit to it's factory defaults:
Locate the Reset button on the back of the DI-624 (through a small hole next to the power cable).
Use a paper clip to press the Reset button
Hold for about 10 seconds and then release.
After the DI-624 reboots (this may take a few minutes) it will be reset to the factory Default settings.
Now try to login again directly via a cable.
Comment by informatica, posted on Aug 09, 2007
To give better answers I need some feedback! What did you try? Are you connected directly to the router? Can you "ping" the router? Can you telnet to the router?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Helpful (85)
pastorm
Rank:Wiz Wiz
Rating: 76%, 136 votes
Try a master reset, holding the reset button for 20 to 30 seconds. It will bring the router to the factory status.
Solution #3
posted on Apr 26, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
20 seconds, 30 seconds, 1 minute, 10 minutes...It WILL NOT reset no matter what...
Can you Help with these Routers problems?
Routers
broadband router range
We just moved into a new home... Answer This...
Routers
ps3 is on nat setting 3 strict
ive connected the router to my... Answer This...
Routers
Lan extender not working...
i have a one pair router... Answer This...
D-Link AirPlus Xtreme G DI-624 Wireless...
Can't seem to get it
Can't seem to get it downloaded Answer This...
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
