Question about Probasics Rite Neb #8005 Mini Compressor Nebulizer
Stopped running Stopped working as if no power. Used diferent outlets with same results. Filter looks good.
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Jul 10, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
GE Profile Harmony washer won't power up and trips gfi
Did you replace the inverter board?? It is inside the tan plastic box in the bottom of the control panel I think on the right side. That controls the power supply to a good part of the machine and drive system. Has to be a direct short somewhere to trip the breaker.
Mar 31, 2015 | GE Washing Machines
The screen stopped working, not responding to any touch
look got the tiny reset button.. usually a pin hole, somewhere near one of your outlets or power buttons, (mine is under the cover where the external drive is located) use a paper clip , insert it gently, you should feel a soft resistance. press that. it should restart your tablet. I find my tablet does that too. look in your apps to see if you have alot of them running in the back ground, turn off what you dont need running, it will help with how slow it works and how much power is being used unnecessarily.
Jun 23, 2013 | Tablets & eReaders
Device appears to have no power. Power cord looks good, it was working the day before then suddenly stopped working... no lights indication of any power making it to the device.
This unit will not operate if it is plugged into a power strip - it must be plugged directly into the wall outlet. An extension cord may be used.
Aug 16, 2011 | Honeywell (18155) Air Purifier
NO POWER TO FRONT AUXILIARY OUTLETS IN A 2002 YUKON, THE FUSES THAT ARE SUPOSED TO BE FOR IT ARE GOOD
Look for a loose or open cable,probably has a open fuse link cable,this ones are fuses but in cables,the color and the consistency is diferent from the other cables,orange is the most common.
Oct 26, 2010 | GMC Yukon Cars & Trucks
My Lasko 42" Wind Curve fan when I plug it don't power up. Pluged at diferents outlets, same results Thank you
Check out the cord, (frayed or broken) usually right where it enters the unit, and the switch.... if these check out then the motor has gone bad...
heatman101
Aug 18, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
125PSI 3 Gal 1 HP ceased up I think.
try plugging it in to a diferent outlet, and plug it directley in witthout using any exstension cords. It sounds to me that it may be pulling more amps than the outlet can handle.
Mar 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My mouse stopped working
hi, ok remove the netgear and boot the system, then go in control panel and adjust the power options to always on. if the netgear device is pci try it in a diferent slot on the motherboard, and reboot. if you have not fixed it by now( i keep forgeting to look at the date of post) good luck@!
Oct 21, 2008 | Microsoft Wireless Optical Mouse
Probasics Rite Neb #8005 Mini Compressor Nebulizer Logo
23 people viewed this question
Top Probasics Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Probasics Health and Beauty Expert? Answer questions, earn points and help others
