Question about Carrera Watches
Adjust chronograph cant work the chronograph
  • Carrera Master
  • 18,411 Answers
This video may help you
Posted on May 03, 2013
Lady's Omega De Ville Chronometer - has 3 small dials: what are they and how do I adjust them? Can I download a manual?
Hello Larry,
The push button at 2 o'clock is to start or stop the chronograph function and the push button at 4 o'clock is for resetting the chronograph.
The middle knob is used to adjust the time.
Dec 16, 2011 | Omega Speedmaster 3520 wristwatch
Heuer chronograph second hands will not reset to 12 after I reset chronograph . It's a quartz watch with mechanical chronograph movement. Any one know how to do this, I know there's a way but I don't know...
Pull out crown and then push the upper button and hold it. The chrono hand should start move and you should be able to adjust it. If this doesn't work, try the same with lower button. When adjusted - push the crown back in. In fact there are very many variations how to reset chrono hand, but exact advise can be given if the movement caliber of particular watch is known.
Rate me, plz.
Jan 28, 2010 | Tag Heuer Watches
Mens Versace leather strap. How do I adjust the band ? The watch has a cream face, square in shape, chronograph with a brown elather strap. Clip requires adjusting and cant work out how to adjust..
Well i am going to roll the dice and assume you have one of the ez clasps but if I am wrong you can send the model number and we will figure it out.
To adjust the ez clasp pull up on the front of the clasp loop while pushing down on the band. Rather than the traditional buckle and prong set up, the prong here is underneath the clasp loop.
Hope this helps. Thanks!
Sep 20, 2009 | Versace Watches
Reset chronograph minute and hour hands to zero
pul crown all they way out
press top right button to set the minute hand
& bottom right button to set the hour
if not work then puch back crown to 1st click and do it same function ,, if still not working then pull crown again and push and hold both button for 5 sec. its reset ,, and try to adjust it again by pressing top & bottom button
hope that will help if not and you are in chicago
bring it to us
at
Amfix Jewelry & Watch Repair
203 N. LaSalle St
Chicago, IL 60601
312 641 7000
Aug 27, 2009 | Pulsar 100 Meter Alarm Chronograph PF3277
Seiko premier chronograph constantly stop working
take watch to a jeweler, or pawn shop and have it cleaned and oiled.
Aug 04, 2009 | Seiko Premier SKP085
I can't figure out how to adjust the offset chronograph
This is to adjust the seconds hand or minutes hand for the chronograph. Pull the crown out either one click or two ... depending on the models. Squeeze and hold the top and bottom buttons at the same time (timer stop and reset buttons). Hold down together for 2+ seconds. The chronograph hands should reset by spinning around and stopping at 0. If the don't stop right at zero, you can now adjust where they stop. Leave the crown where it is in that same position out. Press the top chronograph button and hold it down for fast movement or short presses for fine movement to adjust til it stops at the top. This will adjust where the seconds hand stops. Then click the bottom chrono button once. Repeat what you did with the top chrono button and it should allow you to fine tune the position for the next dial, and so on. When you are done, press the crown back in all the way to the normal position.
May 21, 2009 | Invicta Dragon Lupah 2093 Wrist Watch
Aqualite Alarm Chronograph 4 button watch
good after noon ! press the adjust button hold it up to 3 second when the digit is blinking thats time to set press the mode to select the digit that you want to change after that press the stert or reset button to change no digit ! thank you ! god bless !
Aug 28, 2008 | Watches
Adjusting the chronograph
good after noon!use the crown and the button of chronografh watch to set the time and date,thank you ! god bless!.....
Nov 14, 2007 | Versace Gianni Atelier Chronograph
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Watches Logo
46 people viewed this question
Top Carrera Watches Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Carrera Watch Expert? Answer questions, earn points and help others
