Question about Health & Beauty
Throttle pot how to access throttle pot on revo SC 64
My 65 mustang stalls whenever i stop then it starts right back up
Hello Larry,
Without the car running... You should be able to open
the throttle.. and literally DROP it back to idle...
Observe the action of the THROTTLE RETURN
DASH-POT
T should visibly SLOW the RETURN
of the throttle linkage like a door closer...
If you do not SEE the slowess... the dashpot
should be replaced (they are getting SCARCE).
SIX CYLINDER (EXAMPLE (only))
http://www.ebay.com/itm/NORS-65-67-MUSTANG-64-67-MERCURY-COMET-FORD-FAIRLANE-FALCON-DASH-POT-C2DZ9B549A-/142309387430?hash=item21224ceca6:g:kE8AAOSwo4pYmKnd&vxp=mtr
You will need to have the THROTTLE RETURN DASH-POT
on your (unspecified) carburetor
tested and adjusted... and the IDLE SPEED correctly set.
Idle Speed and a slow rate of RPM reduction is
critical to the proper function...
Some LESSOR "mechanics" will attempt to raise the
IDLE SPEED to compensate for a malfunctioning
DASHPOT... This will PROFOUNDLY exacerbate
the problem.
Throttle return dashpot (various pictures)
Go to Bing homepage
example DASHPOT (six cylinder)
NORS 65 67 MUSTANG 64 67 MERCURY COMET FORD FAIRLANE FALCON DASH POT...
example 1968 302/5.0L: Falcon, Mustang 2BBL carb
Carter 202 737 Carburetor Dashpot Ford 2 BBL Carburetors Replaces D7ZZ...
Hope this helps
Carnac the Magnificent
Jul 09, 2017 | Ford Mustang Cars & Trucks
The manual freewheel lever will not go into gear
hi, 7 flashes implies the throttle lever (speed pot etc) is not in the correct position, other words not dead center, (PGDrives S -Drive Controller)
Let me explain , the pot in question is a 5K value and the throttle lever rests in the center of that about 2.5k give and take
If you can see the bottom of the metal stem in with the throttle lever is mounted there should be a cross head slot now that should be dead center, the slot facing you as you sit on the scooter, slightly off center will cause the fault reported.
Regards
www.gewizrepairs.co.uk
Please rate my assistance.
Jan 01, 2013 | Pride Value Line Revo Scooter 3 Wheel
Can the foward and reverse be switched from left hand to right hand
hi, you have to expose the throttle pot that attached to the throttle lever , looking at the pot you see three wire connects, swap over the outside ones but leave the middle one alone. Regards GeWiz.
May 13, 2012 | Pride Value Line Revo Scooter 3 Wheel
Even on a full charge my classic xl8 slows down and speeds up again any sugestions please
Pride scooters are known for this problem, as I found out when it happened to mine.
You need to replace the Throttle Pot. Either take it to a mobility shop and let them do it or buy the part and do it yourself. It simply involves unscrewing the old one and screwing the new one into place, and there are diagrams to help you on the internet.
This throttle pot problem has happened to my Pride scooter three times already.
Jun 20, 2011 | Pride Mobility Products Revo (3wheel)
MY PRIDE REVO MOBILITY SCOOTER IS 3 YEARS OLD AND IS STARTING TO HAVE A INTERMITTENT FAULT OF GOING SLOW AND THEN FAST LIKE HAVE DIRTY PETROL IN A CARBURETTER IN A CAR
I know what the problem is as I have had it no less than 3 times with my own Revo. The Throttle Pot needs replacing. Luckily they aren't very expensive and you can fit it yourself if you are a handy sort of person. It just involves turning a screw to take out the old one and put in a new one. You can find diagrams on how to do it on the Internet. If you call a mobility company to come out and do it for you, they usually charge about £50 as a Call Out Fee.
The Revos seem prone to this throttle pot problem. Hope you get it fixed soon.
May 13, 2011 | Pride Mobility Products Revo (3wheel)
Can the throttle be switched to left thumb for forward
No Well maybe If you remove the console cover and see how the throttle is mounted to the tiller. If the throttle pot and handle are screwed to the tiller with two screws you might be able to unscrew the throttle assembly and flip it upside down letting you use your left thumb to push on the throttle. Unique problem because if you can't flip it then you are stuck pulling the throttle reverse side outward to make it go forward. Hope this helps you might even have to flip the throttle lever ( take it off the throttle pot and flip it and reattach to the pot stem) so it will fit back under the console cover. I dunno for certain but you can try
Oct 21, 2010 | Pride Revo 4 Wheel Scooter
Scooter shows "speed pot error". How do I fix that?
You will more than likely need a new speed pot but some are connected to the throttle pot as well so it could be that which is at fault. Could also be wiring or worst case, control box but this is unlikely.
Feb 20, 2010 | Pride Value Line Revo Scooter 3 Wheel
Revo 3 wheel: will not hold constant speed; batteries recently replaced but did not fix problem
hi, there could be a number of issues,
First check the speed pot, try moving the throttle lever in the upwards or downwards direction while going forward, if the scooter starts to pick up again then the speed pot is worn and needs replacing.
if the motor has brushes check them, make sure they can move freely, some times they stick and cause intermittant speed problems, check the battery conections and make sure they are tight.
If this helps please vote.
Regards
GeWiz.
Jan 05, 2010 | Pride Value Line Revo Scooter 3 Wheel
I just bought a revo three wheel scooter and it stopped going in reverse.
hi, the first thing to look at is the speed pot (wigwam), sounds like either it come loose so the pot is in the incorrect position or the track inside the pot is damaged or the wire for the reserse side has broken or come away.
Jul 25, 2009 | Pride Value Line Revo Scooter 3 Wheel
Health & Beauty Logo
18 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
