Question about Car Audio & Video
1994 saturn I don't know what fuse I need to change to get my radio to work.
  • 1,975 Answers
1994 saturn - cc586a3b-2b8a-4401-8de1-6433fe458f03.jpgActually the yellow wire is the key on (ACC) power. Above in the first picture is the wiring diagram which as you can see the wire I marked with the yellow arrow (the yellow wire) goes through the ignition switch and only supplies power with the key on. The constant power wire is going to be the orange wire (I marked that wire with a orange arrow). I continued to the next picture below the first picture marking the same wires and colors from the first picture to the radio. The fuse for the yellow wire is in the fuse panel inside the vehicle (see location in the 3rd picture and marked the fuse panel with a red arrow). and will be the one marked radio either on the cover or the panel itself but should be a 7.5 amp fuse. Now the fuse for the orange or the wire that should be constant power is a 5 amp fuse and will be marked "Chime". Now in the last picture (bottom right) is the wiring diagram for the lighter which is kind of a separate circuit. It does have one fuse in common but that fuse feeds power to the fuse panel inside but if that one was out you wouldn't have tail lights, parking lights and a number of other things so I doubt its the main 30 amp maxi fuse in the fuse panel under the hood. The fuse for the lighter as far as a dedicated fuse for the lighter is in the fuse panel inside the vehicle and will be marked "lock" and is a 20 amp fuse. Sorry I don't have a fuse panel diagram as far as the fuse layout but I hope this helps you.
Posted on May 03, 2013
I have a 2008 Saturn Aura. The signals work outside and on the dash, but no sound. The radio doesn't have sound. The alarms (like when I leave the key in the ignition) don't sound. Is this
I HAVE A 2007 AURA DOING THE EXACT SAME THING..TAKING IT INN THE MORNING..HAVE SERVICES PAYING FOR AND CANT HEAR...JUST GOING IN FOR THE DIAGNOSTIC FOR SATURN CARS..BUT I KNOW ITS NOT MY FUSE THIS TIME...HAD THIS PROBLEM BEFORE AND IT WAS THAT SIMPLE. FUSE BOX IN THE TRUNK WAS THE SOLUTION AT THAT TIME. THIS TIME ALL FUSES WERE GOOD...SO THINKING IT MAY BE MY RELAY SWITCHES...JUST HOPE IT DOESNT COST AN ARM AND LEG....JUST MISS MY XM AND ONSTAR....
Feb 05, 2013 | 2008 Saturn Aura XE
I have a 2000 Vauxhall Astra Estate and the fuse for the radio has blown but I don't know which fuse it is. Does anyone know which it is?
is the cigarette lighter working if so it may be the one on the radio its self. can blow the radio fuse and not the main fuse. radio fuse is less think it is 5amp as main fuse can be 15-20amp fuse.
Jan 02, 2013 | Vauxhall Cars & Trucks
Where is the power windows fuse located at on a 1994 saturnsl2
In the underhood junction block. It's the 30A WINDOWS fuse.
Oct 02, 2012 | 1994 Saturn Sl
1994 volvo 940 brake lights don't work
check the fuse .and all of the bulbs are working.if ok then change the brake switch.
Feb 01, 2012 | 1994 Volvo 940
Okay here's my problem I have no manual and I have
If you cant find pic online (neither could I) try pulling each fuse out individually and looking at it... check this pic if you don't know how to visually inspect a fuse. Replace blown fuses with ones of the same amp value.. i.e. 15 w/ a 15, and 20 w/ a 20. You may lose the time in your dash or reset radio station presets by doing it this way, but its better than not having wipers or brake lights
Nov 18, 2011 | 1994 Suzuki Swift
I just changed the oil in my vue and don't know how to reset the change oil light
If you open the hood and pull the fuse panel cover. With the ignition switched on (key on, engine off), press the red button in the underhood fuse panel for at least 5 whole seconds. The may flash a few times but then go off. Now you're reset.
Jun 18, 2011 | 2003 Saturn VUE
Where is the radio fuse in the fuse box in my 1994 saturn SL
On my 97 SL2 it's on the passenger front side near where your left foot would go. You remove the panel as part of the center console and it's behind it
In my 1994 Saturn SL1, there is a grey one under the hood on the driver's side AND one inside the car on the passenger side where the left foot would go
On the passenger side, on the side of the instrument panel, there is another fuse box, the radio fuse is number 10 on mine. The problem is I changed it and the radio still doesn't work.
On a 93 sl2 its in the same fuse box, but is number 19
Dec 12, 2010 | 1994 Saturn Sl
Radio not working
Make sure you are checking the fuses in the panel on the left side of the passenger's seat. These are the fuses for the radio, not the ones under the car hood.
Oct 05, 2009 | 1994 Saturn Sl
Car Audio & Video Logo
147 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
