Question about Plumbing
Problem with counter depth.
Have a new counter that is 1.25" thick. Faucet only extends 1.25" into counter, nothing to tighten washer onto. Only suggestion so far is to grind down the counter underneath or send back the taps but surely someone else has purchased counter tops of this depth without having to resort to this. Is there not a nipple or inner neck that can be purchased that is longer than the 2.25" total length of this one? Please help.
  • 16,653 Answers
Get a nipple and a sleeve and put the nipple on one end of the sleeve and then scew the sleeve onto the shank.
Posted on May 19, 2013
4 Suggested Answers
  • 244 Answers
SOURCE: the counter is too thick for length of faucet stem
i good hardware store (not Home Depot) may have a coupler that will let you extend the two bolts on the faucet, add another bolt up into coupling, putting nut and crossbar on it.
Posted on May 09, 2009
snap101
  • 117 Answers
SOURCE: I have a Grohe Ladylux Plux kitchen faucet that
you can pull the faucet arm off, the part right on top of the base , if my memory serves me correct you can tighten it with a creset wrench and the neck will pop right back on after
Posted on Aug 04, 2009
packrat1948
  • 528 Answers
SOURCE: the shank of the faucet
A lot of the faucet manufactures have not kept up with the new counter top innovations out there so I would say you need to pick out a new faucet that has an extended shank. Short of counter sinking the hole from the bottom of the sink top the above is your only out.
Posted on Feb 08, 2011
The handle on my rohl kitchen faucet won't hold its position, how do you adjust or tighten the handle?
under the counter there is a nut that needs tightened . usually need a swivel head faucet wrench to get them tight .
Feb 14, 2015 | Rohl A3608LMPN Single Lever Country...
Not gating flam
follow this steps and fix it. God bless you
Service a compression faucet:
  1. Turn off the water supply and open the faucet handle to relieve water pressure.
  2. Carefully pry off the trim cap with a small screwdriver or putty knife.
  3. Remove the locknut with an adjustable wrench, then lift the spindle out of the faucet.
  4. As needed, remove and replace the O-ring. Before reinstalling, coat the stem lightly with plumber's grease.
  5. As needed, remove the retaining screw and pry out the washer. Install an exact-replacement washer and tighten it.
  6. As needed, inspect the seat and replace if damaged.
  7. Install the valve and tighten, then reinstall the handle and test.
Repair a reverse-compression faucet:
  2. Carefully pry off the trim cap with a small screwdriver and remove the handle screw. Unscrew the packing nut and lift out the stem assembly.
  3. As needed, pry out the washer under the packing nut and replace it.
  4. As needed, remove the seat washer and replace it with one that fits exactly. Rethread the spindle and washer back onto the stem, and reassemble the faucet.
Nov 30, 2013 | Plumbing
The shank of the faucet is an 1 1/4 inches long and the granite counter top is 1 1/4 inches thick. cannot tighten nut to hold faucet in place
Feb 08, 2011 | Fontaine Plumbing
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
How do I fix my kitchen sink faucet?
he steps to replace a faucet are easy and nearly always the same. Here's how it works:
  • Shut off the water supply to the faucet. Usually, there are shut off cocks near the faucet but if not, you may have to shut the water off near your main line.
  • Remove the water feed lines from the faucet. You may wish to tag the hot water line "hot left" to take the guess work out of reconnecting.
  • Remove the faucet hold down washers or spin nuts. These washers are under the counter top. They spin onto two studs that you will see by looking behind the sink from below the faucet. The stud and washer configurations come in different styles and types but they all do the same work of holding the faucet in place. Your job is to get them loosened up so you can remove the old faucet. The distance between those studs is your "center distance" as mentioned earlier.
  • Once you have the faucet loose, it will be much easier to remove a sprayer line if there is one attached.
  • Clean the area once the faucet is removed.
  • Put the new, plastic faucet base plate in position.
  • If there is a sprayer, replace the base for it (included in the kit) and feed the new line down through the sprayer base and back up through the center hole where the faucet will mount. Attach that line to the new faucet.
  • Insert and firmly yet gently tighten the mounting studs into the bottom of the faucet base if they're not already.
  • Insert the faucet into the appropriate location on your sink and install the faucet hold down washers or spin nuts.
  • Reattach your water lines. Begin by lightly cleaning all threads with a soft cloth and then apply Teflon plumber's tape to the male threads of your connections Be careful not to cross thread anything when putting the connections together.
  • Reestablish water pressure and check for leaks. It always helps to have a spotter / helper for this step.
A new kitchen faucet always gives me a special DIY feeling because a new faucet looks good, operates easier and can even save a little water by providing quick, positive shut off. Take your time and survey the entire job before you start. With a little time and patience, you too can have a bright new faucet in your home kitchen.
Jan 02, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Can I install a vessel sink on formica in my bathroom? The faucet will be installed on the formica counter. Will that work or will the counter eventually buckle? Thanks
This can be done. However, before doing this, just make sure you can get all the parts necessary for your faucet. With the faucet coming through the countertop, it will need to be extended to reach a height above your countertop. They make faucets special for this purpose, so just do your reasearch first. Also, before cutting the opening for the sink, get a rough idea where it is going and put the faucet in place (again no holes drilled yet) to see if it will function where you want it. Often times, the faucet has to be offset at an angle because the backsplash is too thick and creates an issue for you. Not to worry though, there is usually a solution for everything.
Nov 20, 2009 | Home
When water is on, faucet slowly moves to the back of the sink, where it can possibly flood the counter. This is a brand new faucet.
IF YOU ARE TELLING ME THE FAUCET ITSELF IS MOVING TO THE LEFT OR RIGHT THE FAUCET MAY NEED TIGHTENING
REMOVE THE SPOUT HANDLE, UNDER THE HANDLE YOU WILL SEE A PLASTIC NUT ASSEMBLY THAT YOU CAN TIGHTEN SEE IF THIS SOLVES THE PROBLEM
Aug 28, 2009 | Moen 7437 Chateau Single Hole Kitchen...
The counter is too thick for length of faucet stem
Apr 20, 2009 | Plumbing
Faucet is loose where it attaches to the counter
No; but they make a thing called a basin wrench which is not expensive that makes it fairly easy to tighten for the bottom.
Jan 31, 2009 | Plumbing
Plumbing Logo
37 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
