Question about Refrigerators
Frigidaire dgus2645LF3 Error Code 5b
2 Suggested Answers
iam6fan
  • 1614 Answers
SOURCE: Code. 5b 5b
Is this a refrigerator or washing machine. 5b in refrigerator means sabbath mode.
Posted on Nov 05, 2017
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Model EW23CS65GS. What does 5b error code indicate?
Hello Dwaine, thank you for your inquiry!
I understand that your Electrolux refrigerator is displaying an error code of 5b and you would like to know if this is a main board failure. I am not showing 5b as a valid error code; however, there is an error code of Sb. This means Sabbath mode and you can turn it off by pressing "-" on the freezer temp side and "+" on the fridge temp side. This should turn off the Sabbath mode.
I have also included a link to the manual for the refrigerator EW23CS65GS. On page 13 you will see Sabbath mode feature and the instructions on how to disable it. I hope this information is helpful to you. -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Anderson/241868900en.pdf
Mar 12, 2016 | Electrolux Refrigerators
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
Oct 19, 2015 | Washing Machines
The panel on the freezer side of my frigidaire gallery refrigerator Model No. DGUS2645LF3 shows "5b". What does this mean and how can I fix it. Nothing works on my refrigerator at the moment.
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
Sep 02, 2014 | Frigidaire Refrigerators
My frigidaire gallery refrigerator model number DGUS2645LF3 is showing an error code "5b" and nothing inside works.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are in the Sabbath Mode.
The Sabbath Mode is a feature that disables portions of the refrigerator and its controls in accordance with observance of the weekly Sabbath and religious holidays within the Orthodox Jewish community.
Sabbath Mode is turned ON and OFF by pressing and holding "?" on freezer temp and "?" on refrigerator temp for five seconds. The display shows "Sb" while in Sabbath mode.
In the Sabbath Mode, the High Temp alarm is active for health reasons. If a high temperature alarm is activated during this time, for example due to a door left ajar, the alarm will sound intermittently for about 10 minutes. The alarm will then silence on its own and a red high temperature icon will display. The high temp icon will continue to display, even if the door is closed, until the Sabbath mode is exited and the icon reset. The refrigerator will function normally once the door is closed, without any violation of the Sabbath/Holidays.
If this does not solve the problem you have a bad control board.
5b error code
Good Afternoon Friend,
I understand that your Frigidaire refrigerator displays an Sb on your panel. If the numbers are showing Sb, this tells me it is in the Sabbath mode. To get out of this mode you will need to press and hold the down arrow on the freezer side and the up arrow on the refrigerator side simultaneously for 5-10 seconds. If this does not work, I suggest resetting your appliance. You can do this by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and check the control panel as well as the ice dispenser and lights. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 31, 2014 | Frigidaire Refrigerators
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
5B Interface or Device(s) Error, System Halt
It could be Memory module problem which is fixed in 5B slot (or) 5B slot itself may have the problem,
Mar 14, 2009 | Acer Altos 1100 Server
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
