Question about Mitsubishi MSZ-GE24NA Mr. Slim Wall Mounted Indoor Unit Air Handler
Mr slim air conditioner leaking water
The inside unit is leaking water when the air conditioning is on
Wall unit keeps frosting up, will not heat
Clogged air filter or a loose belt between the fan motor and fan wheel will cause a frost up.
Nov 19, 2015 | Mitsubishi MSZ-GE15NA Mr. Slim Wall...
How does one access the drain pan in a Mr. Slim? I think I have stagnant water (minimally), mildew or mold somewhere and nee to make sure.
POUR some strong bleach water in it where you saw the second guy put water in . that should kill any bacteria if there is any
Aug 06, 2015 | Mitsubishi 9000 Btu Mr.slim Ductless Mini...
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
Indoor unit fan blows, then stops etc. every 1-2 minutes
At least it is cooling properly. U might just want to call Mitsubishi and ask them if it is operating normally based on your observations.
Apr 30, 2017 | Mitsubishi 18000 Btu Mr.slim Ductless Mini...
How do I clean Mr Slim MSZ 24NA
usa.mylinkdrive.com/.../MSZ-MSY-A09-24NA_GA24NA_Service_OB
Sep 19, 2014 | Mitsubishi MSZ-GE24NA Mr. Slim Wall...
Why is my Mitsubishi mr slim is blowing black particles into room?
Area where "fresh" air is being pulled in is dirty, filter needs replacement, heat exchanger is old, a seal is old/torn, or mold is shooting out!
http://www.ehow.com/info_12016541_particles-blow-out-fan-air-conditioner.html
May 27, 2014 | MR SLIM Split-ductless: Mitsubishi...
I have a terrible smell coming out of my Mitsubishi air-con.
after making sure it will drain properly the best way to permanently remove smells is to use a "ozone machine" or a ionizer this attacks the odor causing molecules and breaks them down. 30-60 minutes from a powerful unit will do the trick , most carpet cleaning companies that also do water repairs have these machines and their rates vary. alpine air also makes a home unit and these are good to use in the home 24/7 as well
Jun 05, 2012 | Mitsubishi MSZ-GE24NA Mr. Slim Wall...
Our carrier reverse cycle airconditioner is leaking inside the house after a hour of use. how can we fix this? we have cleaned the filters in the inside unit and it still leaks,it works fine as a heater...
Did you blow out the drain? If so pull the front off of the air handler unit. Ckean out drain pan. This drain pan had small holes on either side that run from the sode drain clean those out. Also if your coil is dirty it will pull water back and cause it to leak. Try cleaning coil and dain pan plus blow out drain. Rus
Dec 13, 2009 | Air Purifiers
CENTRAL AIR UNIT IS NOT BLOWING INSIDE BUT THE COMPRESSOR OUTSIDE IS RUNNING. WHEN I GO DOWN TO THE BASEMENT TO CHECK THE FILTER-THE BOTTOM OF THE UNIT AND THE FILTER IS WATER LOGGED. ORIGINALLY IT WAS...
There may be a leak. You might try shutting it down and taking a look inside. On the other end, there may be something wrong with your components inside. The compressor outside is to provide coolant. Inside, the fans actually cool the air. Make sure all doors are on the blower downstairs, and if all else fails, call a technician. Good luck!
Jun 19, 2009 | Ecoquest Flair Air Purifier
Mitsubishi MSZ-GE24NA Mr. Slim Wall Mounted Indoor Unit Air Handler Logo
113 people viewed this question
Top Mitsubishi Air Purifiers Experts
Andrew Taylor
Andrew Taylor
richie46
Rob
Rob
Are you a Mitsubishi Air Purifier Expert? Answer questions, earn points and help others
