Question about CP International WAP-6011 Wireless Access Point - 300Mbps - IEEE 802.11n (draft) - 1 x 10/100Base-TX Network - (WAP6011)
NO CONNECTION WITH LEVELONE WAP 6011 - CP International WAP-6011 Wireless Access Point - 300Mbps - IEEE 802.11n (draft) - 1 x 10/100Base-TX Network - (WAP6011)
Why i cannot factory reset username, password and ssid ap? and i just can factory reset ip ap
What are you connecting the wap-1001 to? An existing network . Does the subnet mask match it defaults to 255.255.0.0
if the p.c you plug directly into the ethernet connection of the ap has a different subnet mask it can't talk to the router. how does your p.c get its ip address is it static or dynamic via dhcp server . ip is default of 192.168.1.20 also is anything assigned 192.168.1.20 .
http://download.level1.com/level1/manual/WAP-1001v1.02_UM.pdf
the default password and user name is in the user manual
Jun 17, 2015 | Levelone Level One FreeCon 802.11G Outdoor...
Software to rest wap 1001 to default
"Its easy but you have to open the unit. Undo the 6 screws holding the base one
Slide out the internals
You will see spot on the board labels SW for switch but no switch soldered to it.
While the power is on, use a wire to short the 2 contacts of the switch that stand out alone. IE. not the 3 together. Hold this short on for about 5 seconds then the led should blink
Presto!
Its now back to factory default 192,168.1.20, User name is "Admin" and leave password blank as per the manual." -fixyaMarkoa34a5098-f669-488f-a6a9-3f02c825de75.jpg
Nov 11, 2011 | Levelone Level One FreeCon 802.11G Outdoor...
Default password changed, how to restore it
Reset it..... It should restore itself to the normal default password :) Good Luck and God Bless :)
Jan 03, 2011 | Levelone Level One FreeCon 802.11G Outdoor...
Cannot connect my WAP-0005 Access point to my router
Use AP mode ; but may really have some compatiblity issues though... Good Luck*
Mar 11, 2010 | Levelone WAP-0005 (DHWAP0005) 802.11b/g...
Hi am trying to get the ip of a radio levelone wap-1001 so that i can configure. how do i do this
radio levelone wap-100 I googled that and got manual for that device.... so do that, type in that phrase, above, into Google search... and take your pick.
Jan 28, 2010 | Levelone Level One FreeCon 802.11G Outdoor...
Very slow connection!!!
my acsses level one wap-1001 not wourk after firmwer i do four it
from wep sit orgenal
she is tern on 15 sac and of anther tin
i ned th eprom in sed the acsses to sheg th flash in sid it
ples kan yow help me pless>>>>>>>>>>>
Jul 04, 2008 | Levelone Level One FreeCon 802.11G Outdoor...
CP International WAP-6011 Wireless Access Point - 300Mbps - IEEE 802.11n (draft) - 1 x 10/100Base-TX Network - (WAP6011) Logo
Top CP International Computers & Internet Experts
David Payne
David Payne
Are you a CP International Computer and Internet Expert? Answer questions, earn points and help others
