Question about GE VG4250 VHS VCR
VHS PROBLEMS Hello I have my wedding video on a vhs and the **** that taped it didnt turn the light on and my wedding was at night outside. You can hear everything and see a street light but that is it. does anyone know if this can be fixed.
  • GE Master
  • 12,061 Answers
Hi how unfortunate.. It think it maybe possible to indeed recover something worthwhile if you take it along to a professional video processing Lab. Find a reputable one and explain ya problem.. they may be able to render it to another medium like say a DVD.. and perhaps can adjust settings so that the images are resolved.. I wouldn't expect too much though.. but these days ya just never know, as some of the software and expertise is amazing..so G L.
Posted on Aug 09, 2007
SOURCE:
Hello! I have a RCA VHS-C camcorder that has a malfunctioning viewfinder.
Interesting that it has worked so long. You might want to consider a better camera since even the cheapest digital video camera today will have better video than a VHS-C camcorder. With the VHS tape it only recorded analog signals and each copy of the tape would degrade. Most cellphones today will take video that is orders of magnitude better than a VHS-C unit . . .
Aug 17, 2017 | RCA Cameras
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
I have copied a personal wedding DVD onto a VHS
I contacted Panasonic direct by phone & they were extremly helpful.
Many thanks ,
Your's, J W Firth
Jan 12, 2010 | Panasonic Televison & Video
I video taped a wedding and am trying to copy from my camcorder "VHSC" to VHS RECORDER - PROBLEM IS I AM GETTING AUDIO BUT NO VIDEO when i try to replay from vhs tape on VCR
I can only believe that you did not connect everything (the yellow video cable) correctly.
Tape to tape copies are normal and typical. Please consider retrying - and just do a few minutes of test video to confirm that it is working.
If you were doing a digital translation, I could understand a problem - but VHS to VHS should be a straight copy.....
Let us know how the test works. (BTW, I had a bad quality video cable - and had to replace it with another - which worked (and everything would display on my TV but would not copy onto another tape. My expert said that a copy protection thing in the record mode of the VHS recorder was the issue - ONLY a strong signal will be copied.
Oct 14, 2009 | Quasar VM-L153 VHS-C Camcorder
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
EP to LP problem on VHS tape playback
The problem is dirt, dust or even mould on the VHS tape. You should look on youtube for video's about cleaning a VHS tape. However if it's really bad there is nothing you can do about it. Commercial VHS were only recorded on SP so the quality of the tape means more signal, so less of a problem keeping the video tracked, even if the tape has patches of mould, likely if kept in a basement!
Aug 09, 2017 | JVC HR-XVC33U DVD Player/VCR
Transferring VHS-C tapes from a Panasonic NV-RX14B to my PC
Search Ebay for peripherals to transfer tape to PC - they come with all leads and software.
Mar 28, 2017 | Panasonic NV-VZ14 VHS-C Analog Camcorder
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
GE VG4250 VHS VCR Logo
507 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
