How to charge massager without charger
Have a massager similar to panabrator ...windmere prelude 9301 wanted to know how to charge it without the adapter (charging wire/adapter is missing) also would appreciate if you provide details of where i could find the charging wire
  • 3,799 Answers
You cannot charge a battery without a charger. Why not just buy an adaptor that will do the job?
Posted on May 02, 2013
Testimonial: "well thanks or your help but i have no information about the volts/watts of the massager... not sure if going to an electronics store...would help me find the correct adaptor pl do suggest on how i could find voltage/watts for the product that has no information thanks"
  • 77 Answers
SOURCE: Acer 5050 screen blink...AC problem???
Very likely a problem with the connection between the power pack and the laptop itself. This is usually the weakest point, and often you need to wiggle the connection a little to get a good connection.
It is usually just a solder joint that breaks, but it is a lot of work to get fixed on most laptops so get it replaced under warranty.
Posted on Jan 13, 2008
zohail
  • 1223 Answers
SOURCE: My Samsung R40 will not charge. The cable/charger
it is called the AC power Wall Socket is that what u r talking about do u think u can replace it i think u should call some elec guy to fix it like maintenance guy it has nothing to do with ur notebook its just the pins inside the socket got loose and ur plug is unable to stand in there am i right pls vote if u find me helpful
Posted on Feb 23, 2009
SOURCE: Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Posted on Aug 25, 2009
atang1
  • 734 Answers
SOURCE: NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Posted on Feb 17, 2012
SOURCE: My battery will not charge on my dell studio 1749 laptop. I ordered (from Dell) a new battery and a new adapter plug in. Still won't charge - the light blinks amber several time and then once wh
Great story, but I feel your pain. There are so many times people think that just because they bought it new it works. Not true at all.
Posted on Apr 23, 2012
Testimonial: "Thank you so much for your comments. They did help me tremendously."
Input 120v 60hz 25w output 3VDC 1500 mA I need a new transformer for an Acuvibe plug in class 2 Model D3-15A
Buy a generic multi voltage charger or any cell phone charger (they run on 3 volts) from a local electronics store or cell phone accessory shop, then solder and shrink tube your charging adapter onto the leak on the charger. You most likely can't buy the original charger. When you install the old charger end on the new charger end that plugs into your device make sure you pay attention to the polarity, one lead is market with a white stripe, one with none.
Sep 13, 2016 | Brookstone Mini USB Personal Massager
I need a charger for my Panasonic Panabrator II. I have an Insignia AC adaptor model NS-AC1200. Have set it on #5 & plugged it in overnight but battery indicator is red. What can I do?
Double check your connections Make sure it is actually charging. Could be charging adaptor is bad? Are you sure polarity is right? Do you have a volt meter so you can measure the output voltage? or a way to use a bulb at the right voltage to see if it's actually working?
Mar 12, 2015 | Panasonic Televison & Video
How long do you charge battery on child 4x2 12 Volt gator
What battery charger are you using and is it the battery it came with or a different one. Also is it a new battery is it drained or does it still have a good charge. All those things are factors. I have something similar and when the kids have drained the batter so that it wont move anymore then I have it charging for probably around 20 hours with the charger I use. I have a trickle charger and battery maintainer so it will charge it to full then turn off until it drains sufficiently to charge again, therefore maintaining the charge. If you dont have a battery maintainer I would suggest getting one your batteries will last longer and you can leave it on the battery for how ever long you want without worrying about it ruining the battery
Jun 23, 2012 | Peg Perego John Deere Gator HPX Ride on...
The charger is broken how can i get a replacement I see no url for the company, its for the brookstone theraspa massager
It might be cheapest and quickest to take your old charging cord to a Radio Shack (or other electronics store) and see if they can match you up with a generic replacement. As long as the voltage, amperage, polarity and plug size are correct, it should work fine. They are good about knowing what to give you in the store.
Mar 31, 2012 | Brookstone Theraspa Turbo Massager
My Toshiba Satellite L645D - S4056 Laptop is not charging. When I remove the Battery to try charge it directly the lapop will still not pick charge. Right now i dont know if its the Charger or the laptop...
From what you I can understand the issue is the charger. Without the Battery the Laptop will not work as the Charger is not giving power to the laptop.
If this is the case you require a new charger. I would suggest testing with a similar charger if a friend has a similar model or taking it to you local shop before you spend money on buying a replacement.
Feb 02, 2012 | Toshiba Satellite L645D-S4056 laptop
I need a replacement cord for the brookstone thera spa cordless massager
HELLO MEAD
I had a Theraspa cordless turbo massager that eventually stopped working but I kept the charger. It still works because I've used it for my replacement massager.
If you're still interested, would $10 be reasonable (plus shipping cost)?
I have an e-bay account and I can sell it to you through there if you want.
Let me know if/how you'd like to proceed.
JK
Nov 21, 2011 | Brookstone Theraspa Turbo Massager
Hi there, i want to know is the honda prelude si1988 and honda prelude si 1990 both has the same motor. like 2.0L. thanks.
very similar can definetly bolt in there were some differences in the water temp sensor and the speedo sensor but it can work as a parts or swap engine
Feb 25, 2011 | 1990 Honda Prelude
Have a brookstone thera spa CORDLESS massager older model, precurser to the turbo massager ... the charging unit that came with the corless massager is missing (lost) can i purchase a replacement
I have a similar Brookstone model, cordless with heat and cold options. I gave up finding the cord and purchased a dual model charger from Amazon that allows me to chose the voltage of the charge to the item. It appears to be working find now. I did have to play with the input voltage until I found the correct amount in spite of what the charger said. The unit I bought is a Hosa Technology power charger. Number ACD-377. Hope this helps you too.
Jan 02, 2011 | Brookstone Theraspa Turbo Massager
My phone will not hold a charge at all. I've taken the battery out, let it set, put it back in for a few minutes and still no charge. The longest the phone lasts without dying is 10 minutes
Hello
Remove the battery and test it with a similar phone to ee if it will hold charges, if it does, it means the battery is good, but if otherwise change the battery.
Next place to look at is the charging port, check with a similar battery and charger to see if it will charge, if it doesnt, change the charging port.
Also test your charger with another similar phone to see if it will charge, if it does, it means the charger is good.
Best regards.
Feb 07, 2010 | Samsung Exclaim M550 Cell Phone
Battery go dry automatically when we remove the charger,,
I am facing similar problem, i use USB charging then it works fine else the elctric charger is pretty useless
Jun 09, 2009 | HTC Touch P3452 Smartphone
Computers & Internet Logo
David Payne
David Payne
