Question about Health & Beauty
Norelco cam 880 CLEAN AIR SYSTEM - Health & Beauty
The norelco Smart clean system wont fill with solution
Most likely, the pump is bad. Parts for these units are not available. If you need to replace the unit, you will find at shaver outlet.com. You will need your shavers model number to select the correct type
ShaverOutlet com ShaverOutlet com Cords Chargers Stands Shaver Replacement...
Aug 30, 2016 | Norelco Health & Beauty
Where can I buy just the Phillips Norelco jet clean system?
There are several types of these. You will need to know the model number of your shaver to select the correct type. You will find them at shaveroutlet.com
http://shaveroutlet.com/catalogsearch/result/index/?cat=99&manufacturer=4&q=clean+and+charge&submit=
Jan 09, 2016 | Norelco Health & Beauty
880 alpine air (2) on upper level one in kitchen and one in laundry room. Question: I clean the purifiers about once per month and the problem is that there is no clean air smell any longer. They are...
The transformer may be burned out. This supplies the power to the contact points which send current through the plates. You can try ordering new plates, just to see if yours are just plain worn out! You're doing the right thing, by using ammonia/water, but they aren't made to last forever! Call Vollara (new name for EcoQuest) at 800-989-2299. Use #16618 if you're no longer in touch with the registered distributor who sold you the machines. If you still detect no clean air amell, the machines need a part which the company no longer handles. And they no longer manufacture the 880 or Breeze, which was its upgrade. Customer service will explain your options.
Jan 21, 2011 | Ecoquest Living Air Classic Air Purifier
Can the arm of the jet clean system be retracted into base for travel or storage
Yes, after you push the start button on the unit, pull the plug out of the wall socket when the arm gets to its bottom position. It will stop at this lowered position. When you plug it in again, it will go back to its upright position. Norelco ships the new cleaning units in this contracted position. When you plug it in presto! You are ready to go.
Jan 03, 2011 | Norelco Arcitec Electric Shaver with Jet...
How much Jet clean solution do i use in the Norelco Jet clean system? Is it straight solution to the line or a mix of solution and water?
The solution should not be deluted. You should fill the basin to the 'fill line' with the Jet Clean solution.
Jet Clean solution can be purchased at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-hq200-smart-touch-jet-clean-solution-p-258.html
If you do not know where th fill line is on your cleaning station, refer to your user manual. I would offer a link to the user manual but you did not state the specific model number of your shaver/
Apr 08, 2010 | Norelco Health & Beauty
Dirty razor heads
can of compressed air that you use on your computer and electronics
Apr 01, 2010 | Norelco Arcitec Electric Shaver with Jet...
Jet clean system will not clean.
I had the exact same problem. Then I put more solution in so that it was just above the MAX line and it worked fine. So make sure you have enough cleaning solution in the system and it should work great.
May 20, 2007 | Norelco 8160XLCC Electric Shaver
PC-CAM 880 - remember Webcam mode
Uninstall all reference drivers to camera, reboot then install drivers again AFTER you hook the camera up to your computer.
Drivers can be found by clicking HERE.
Sep 12, 2005 | Creative Labs PC-Cam 880 Digital Camera
Health & Beauty Logo
101 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
