Canon faxphone l190
The fax machine stopped working and the read out says: set paper again, set toner again. What do I do?
SOURCE: Canon FAXPHONE L80 confirmation
First print out your user data.
Press Function, then Report, then arrow down to User Data List and press Set. This gives you a printout of your present menu set.
Now press Function, press Data Registration, press Set. Arrow down to Report settings, press Set.
Select TX Report, select yes.
You can also select that the first page of the document sent shows up on the confirmation report.
Posted on Feb 23, 2008
SOURCE: Error message on Canon Fax Machine 2050P check cover/cart
there are a couple of things did you buy genuine or reman cartridges and check if they are seated properly.
some remans dont work properly so you have to be sure and always get a money back guarantee from the seller
Posted on Jun 08, 2008
SOURCE: not feeding paper all the way
Never use Alcohol on rubber feed rollers. I am not sure what the fix is for your problem, but if you use alcohol on your feed rollers you will have another problem. Alcohol removes moisture from rubber, over time the rollers harden and will need to be replaced. DO NOT USE ALCOHOL ON RUBBER.
Posted on Jun 16, 2008
iservice
  • 318 Answers
SOURCE: retrieval of faxes in memory
Press the stop key and it will resume printing
Posted on Apr 09, 2009
iservice
  • 318 Answers
SOURCE: We have a Canon Faxphone L170. Someone sent a fax
On the controll panel there is a diamond shape picture with a eye in it.press that bottom and clear the fax that you received.There is no other way.You will have to phone the sender and ask them to change the papersize settings on the fax machine.
Posted on Dec 08, 2009
Memory if full message on Canon L190
I am sure a 'Memory Reset' would fix this.
As to 'how', I can only suggest you check out the precise way to do this in your CD manual.
Dec 18, 2013 | Canon Lasers FAXPHONE L190 Wireless...
How to get a fax confirmation on a canon faxphone L190
There should be a button on the front of the fax 'Reports'. Push that. Then go to 'Report settings'. Select that option. For confirmation reports that a fax was sent 'TX Result Report'. Turn this 'On'. You should be set. We just figured this out on our faxphone.
Nov 29, 2012 | Canon Office Equipment & Supplies
How do I set up the faxphone to get a receipt for a fax I have sent?
if u lift the flap on the right side where your speed dails are you will se a data registration button!Press it and press set,use the arrow down and scroll to report settings,press set and it will say tx report,press set and use the arrows again to scroll to output yes!Press set and press stop!Good luck!
Apr 08, 2010 | Canon FaxPhone L75 Plain Paper Laser
Dec 08, 2009 | Canon FAXPHONE L170 Plain Paper Laser
My canon faxphone l80 can not be loaded paper, once I load paper in the tray, the monitor still shown load paper
Please shut down the unit and remove all paper. Wait ten seconds turn the fax backon without paper. mAKE SURE THE FAX IS ONLINE. hAVE SOMEONE SEND YOU A FAX SO THE MACHINE DEMANDS THE PAPER. SEE IF THIS WORKS
Jan 19, 2009 | Canon FAXPHONE L80 Laser
Fax says Paper Jam but there isn't one!
After what operation does the machine report the jam. If it is trying to print something and the paper doesn't pull, then it will report a paper jam, even though the paper didn't move. If this is the case then the paper feed tire behind the toner is dirty. Cleaned with rag and rubbing alcohol.
Apr 08, 2008 | Canon FAXPHONE L80 Laser
Canon faxphone l75
what does it say on the display
Thank You,
Mikey
Mar 20, 2008 | Canon FaxPhone L75 Plain Paper Laser
62 people viewed this question
k24674
jasbo
jasbo
