Question about Canon EOS 600D Rebel T3i Digital Camera with 1855mm and 75300mm lenses
Canon Rebel Freezes when transfering photos to computer
We use several Rebel t3i for work. We have had them for some time now and everything was fine. Now recently when we transfer photos over to the same computer as always the computer freezes up and the only way to resolve the issue is to shut the unit down. This happens when transferring even 5 photos at a time. They are only a few MB big so it is not a huge data transfer. We use card readers, are other Rebel cameras, make sure no other programs are running, xfer straight from the camera, even transfer one photo at a time. This is an intermit issue but happens so often now, that it is becoming a huge issue for us. Nothing has changed in the process of the way we transfer and nothing has changed on the computer itself. Thanks in advance.
    Novelist:
  • Canon Expert
  • 357 Answers
Well, without access to your equipment, I can only guess. However, you could have three main causes for this problem.
1) Camera(s) If it only does it with a couple of cameras then it is a camera problem, If it only does it with the same camera over and over again it is definitely the camera. If it does it with all your cameras it is probably not the cameras.
2) Card reader. I don't know how to check this (I don't know any that are repairable), but the easiest solution would be to replace it. If the problem continues after you replace it, with any camera, then you are left with:
3) Computer. First off try the card reader on another USB port on the computer - the one your are using may be damaged in some way. If that doesn't solve the problem, then you are looking at a computer repair/replacement.
Posted on May 05, 2013
SOURCE: Transfering photos to computer
Did you ever find a solution to this? I'm having the same exact problem.
Posted on Jan 08, 2007
SOURCE: Can't load photos to computer
Also if the computer's file management system successfully allowed you to retrieve the pictures, then the whole computer and camera systems are working. Perhaps you could then reload the camera's software. Sometimes camera software drivers get corrupted. Your camera manufacturer probably has a site to download the latest software with enhancements and fixes.
Posted on May 04, 2007
Code
  • 33 Answers
SOURCE: Canon Powershot A75 digital camera
Definitely sounds like you have a bad CCD. There is good news for you though. Canon recognized this particular model's CCD as faulty, and it is under recall! This means they will repair or replace your camera free of charge.
From Canon website: "U.S. residents are kindly directed to contact the Canon Customer Support Center for further assistance at 1-800-828-4040. Support hours are Monday thru Friday - 8:00 AM to 12:00 midnight; and Saturday 10:00 AM to 8:00 PM (all times EST). Alternatively, if electronic support is preferred, please send your email to carecenter@cits.canon.com"
Explain to them you have a Canon PowerShot A75 digital camera with a bad CCD and you were looking to get it serviced by them under the recall.
Good luck from darntoothysam.com
Posted on May 13, 2008
  • 62 Answers
SOURCE: EOS Utility does not recoganize Canon Rebel Xti
I believe there are 2 modes of usb transfer that you can pick in the camera. They are set somewhere in the menu in the options. If you go through the menus thoroughly you'll find it. One option is for connecting the camera directly to a printer and the other is for computer transfer (there might also be an Auto setting but I don't remember for sure). Make sure that setting is set for computer transfer. If that doesn't fix your problem, re-install or update EOS Utility / ZoomBrowser.
Posted on Aug 28, 2008
  • 23 Answers
SOURCE: Canon EOS 400D not transferring photos to computer
Try installing or reinstalling the software on the CD ROM that came with the camera.
Posted on Dec 05, 2008
Does this camera have internal memory? Cannon EOS 600D Rebel T3i
It has some internal memory, for keeping track of things like the date and time. It does NOT have internal memory for storing photos.
May 17, 2014 | Canon EOS 600D Rebel T3i Digital Camera
When taking photos, the image is not captured when using liveview...
You should consult your owner's manual, but here's a helpful link
http://www.imaging-resource.com/PRODS/T3I/T3ILIVEVIEW.HTM
Nov 28, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Brand New Canon Rebel T3i not reading SD cards.
It looks like the camera is faulty.
Take it back to the shop for a warranty repair or replacement.
Apr 20, 2013 | Canon EOS 600D Rebel T3i Digital Camera
How to mount q-ray 70-210mm lens on canon t3i body
Quantaray makes lenses with a variety of lens mounts. Assuming the lens has a Canon EF mount, it will fit onto the T3i just like any Canon lens. If it has a different mount, you'll need an appropriate lens mount adapter.
Feb 28, 2013 | Canon EOS 600D Rebel T3i Digital Camera...
Date stamp on canon T3i
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Aug 13, 2012 | Canon EOS 600D Rebel T3i Digital Camera
Canon EOS 600D Rebel T3i Digital Camera - Transfer computer issues Photos being transferred to computer (Mac OS X) with help of USB cable and EOS Utility but Only part of the photos got transferred. Now...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Dec 08, 2011 | Canon EOS 600D Rebel T3i Digital Camera
Accidentally deleted video from Cannon EOS 600D Rebel T3i
It should be no problem getting it back with recovery software. Just try to stop taking any more photos or videos to lessen the chance of overwriting your lost video. See this article for instructions on how to recover deleted/formatted videos/photos.
Oct 30, 2011 | Canon EOS 600D Rebel T3i Digital Camera
Canon EOS 600D Rebel T3i Digital Camera with 1855mm and 75300mm lenses Logo
83 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
