Question about Vehicle Parts & Accessories
Fuel honda gx620
I have a fuel problem the vacuum line that goes to the fuel pump is blowing puffs of air rather than sucking. What does that mean or is that normal?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 45 Answers
Valve sticking open
Posted on Oct 03, 2013
Location of fuel pressure regulator on 2006 dodge caravan 3.3
Replace fuel pump and filter that is not a regulator problem.
Bad fuel regulator will cause vehicle to surge at cruise speed or they leak and cause engine to suck excessive fuel into intake if vacuum control then blows black smoke.
Jan 24, 2015 | Dodge Cars & Trucks
I can only get more then 150 kmh out of my bike
Fuel starvation? Check fuel tap/tank for blockages, nipped/trapped fuel line? If it has a fuel pump? check trhu put of that eg litres/minute, also check fule cap is venting and not causing a vacuum. Make sure no air getting sucked into engine around inlet manifolds between airbox and cylinders
Aug 15, 2014 | Honda VT 750 CD Shadow A.C.E. Deluxe...
How to adjust valves on honda gx370
remove valve cover and spark plug, set piston on TDC compression stroke. adjust valves .004-.006
as for fuel pump not pumping, valves wont have an issue with this but blow-by, bad piston cylinder wall will
Dec 20, 2013 | Air Tools & Compressors
Ecm failure causes
no year?, hopeless.
my wild guess, cell; phone?
and 1983 Accord, with ECM flash code 13?
did you look here first then ask questions.
http://www.troublecodes.net/honda/
this is a Carb car right?
if car is EFI
13 means bad baro sensor, in non science terms
that means a bad MAP sensor.
the MAP is used to calculate all air flowing in to the engine
and this allows the ECU to inject a perfect fuel mix.
if 13 happens the eCu goes to limphome and sucks fuel like crazy.
13, means bad wires to MAP or bad MAP or bad vacuum line to MAP.
a tech, checks all 3, and then tests the MAP and the problem is solved. the FSM is free, ask.
really a 1983? very very old.... tjhat...
Oct 02, 2013 | Honda Accord Cars & Trucks
I have 1988 Honda Shadow motorcycle vt600c balls out at high RPM's and sputters when revving engine in neutral loses power at 45 mph when I take air filter off loses power at 65 mph could this be fuel...
This sounds like a flooding carb due to a broken float, or it could be a faulty fuel pump, or a blocked fuel line, Start from where the fuel leaves the tank up to the carburettor checking the fuel hose for leaks(maybe also sucking air on pumping. Or could also be dirt in the jets thats why it goes faster when you remove the air filter. The spitting of fuel is because the motor is turning eratically thus slowing down the pumping or sucking (it's relative to the amount of revolutions the motor is turning) This should be an easy one.
Apr 14, 2013 | Cars & Trucks
Honda gx620 dies on idle
After checking oil and clearing any obstructions in the blower, remove and clean carburetor with special attention the the idle and low-speed circuits.
Feb 11, 2013 | V-Twin Horizontal OHV Engine with Electric...
Feels like it wont get no fuel
1) no fuel discharged into manifold
2) test fuel pump output
3) carburettor clogged
4) test fuel line by sucking
5) air sucked up.
6) line obstructed vacuum lock in tank
7) fuel pump defective.
God bless you
Jul 10, 2012 | 2000 Chevrolet Malibu
Saturn sl 1992 no fuel to injectors
1(test pump fuel
2)fuel line test by sucking .3)air sucked up 4) no fuel in tank air leak in line 5) line obstructed vacuum lock in tank 6) fuel pump defective.
God bless you
Jul 09, 2012 | 1992 Saturn SL
It was running after a carb re-build. now my bulb isn't pulling gas when i pump it
The bulb and/or fuel lines could have a small hole in them, losing vacuum, introducing air into the fuel system and causing problem. First off, check inside the fuel tank and make sure the fuel filter is attatched to fuel line. This is a common place for the line to break and if it does, it floats, introducing LOTS of air and a malfunctioning purge/primer bulb. When you depress the bulb, the vacuum created actually allows gas to Flow to the carburetor as it is pushing any air/old gas back to the fuel tank. So, in summary. Carefully check the condition of ALL of the fuel lines ,fuel filter and the bulb itself. If they are dry, non-flexible, or cracked, they need to be replaced.
Sep 16, 2011 | Poulan Garden
Our dirt devil vacuum is blowing out air instead of pulling in air.
my dirt devil is blowing out air instead of sucking up.Tried new bag.any other solution to fix
Aug 29, 2009 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vehicle Parts & Accessories Logo
81 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
