Question about Panasonic SC-HT65 System
Reset without remote control
I lost the remote control of my home theater and I need to reset so I can use all the speakers, becouse by now it's stereo but I need surround
SOURCE: Poor Surround Sound
There is a setting in the dvd player to up the rear speakers to a + setting you have to dig deeep somewhere in the speaker settings. mine did the same thing till I found it.
Posted on Apr 25, 2007
  • 142 Answers
SOURCE: speaker wire
Use the same gauge that is supplied for the rear. Probably 24 gauge.Do it with the power off. If the wires touch with the power on the rear output IC will blow. Good Luck
Posted on Dec 11, 2008
SOURCE: i want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Posted on Dec 17, 2008
SOURCE: i have Panasonic home theater
I have a Panasonic HT80 dvd system which plays 5 discs, bought in 2000.
If u have the same or similar he way to get the sound through the recorder is to put the audio output phono leads from the tv to the back of the dvd. On the remote (on mine) there is a button for dvd/tv/ext, oput this to tv it should allow the sound to be transferred from the tv set.
Paul 07956 150 240
SOURCE: static noise panasonic home theater
Simply unplug the machine for more than one minute. Then plug it back in again. That makes the system reset and the problem went away.
Posted on Sep 07, 2009
Greetings, i'm looking for a rca rt2770 remote or replacement. any ideas? can i change the speaker levels without it? thanks
You can purchase one here http://www.replacementremotes.com/RCA/Buy-RT2760-RCR192AB1-273471-Home-Theater-system-Remote-Control.html
Sep 23, 2011 | RCA RT2770 Theater System
Bose Cinemate wont turn on. I believe the remote control is not communicating with the unit. How can we reset the remote control?
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Aug 26, 2011 | Bose Cinemate Digital Home Theater System...
How do i program panasonic home theather system universal remote control and where do i get codes
If you lost the programing manual for your remote check the manufacturer of the remote's website and look for either a download of the code book or a list of codes for your remote model. You may need to look at small print or a back label of the remote for a model number.
Aug 17, 2011 | Bose Cinemate Digital Home Theater System...
I need a new remote control and one speaker for a fidek fav 615
you can probably use any home style speaker to replace broken or lost one asfor remote u may try a common unniversal
Apr 23, 2010 | Insignia NS-H2002 Theater System
Remote control
Has the remote been dropped on any hard or wet surface?ie. on the floor or a bucket with water.
If it felt on the floor, maybe some wire has unplugged / unwelded.
if felt in a wet surface it needs to be open and dry without the batteries on.
Sometimes the old batteries expel a very corrosive fluid. Verify that the old batteries had no rusted the contact leads of the remote.
if they did, clean the leads, do not damp them.
Good luck!!!
Mar 02, 2009 | Durabrand 5.1 Surround Sound Computer...
Rca rt2390 lost remote 5 years later lost electricity reciever reset and no optical input designated cannot designate optical to input source without remote...help
I found somewhere called newremotecontrol.com they have the remote for less then $20 bucks ... I lost my remote 3 years ago
Feb 19, 2009 | RCA RT2390 System
Swa3000
  1. With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
    Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
  2. With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
Feb 14, 2007 | Samsung HT-Q70 Home Theater System System
Panasonic SC-HT65 System Logo
55 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
