Question about HP LaserJet 2300 Printer
I have the same situation I also checked the scanner but did not clean the mirror not only i checked the scanner but also recheked all the catridge of Hp-2300 but the position is still half page poor. Can any one tell me what to do now?
  • 138 Answers
SOURCE: Hp 2300dtn Poor quality printing
Well lets start with DISREGARD ALL THE ABOVE BULL in the above brainless clarification request first noted. Here's a little good advice for you from a 14 year veteran printer tech.
Lets start with the cheapest and easiest moving to the more difficult or more expensive. Your problem can be caused by a few differnt things.
Print a configuration page (on the printer menu press check button, scroll to info menu, press check, scroll to print configuration, press check. Once you have the look for the page count on the page.
Try fresh good paper from a sealed ****. If your paper has picked up moisture this will show up as light or uneven print.
Next if the printer is over 100K page count, replace the transfer roller (foam roller inside printer under the toner cartridge). Lets try cleaning it first if your under 100K or to see if it improves at all. Any improvement will verify the transfer roller as bad. Review the photo below as it shows the transfer roller end inside the printer. The screwdriver is showing where the release white clips are (two). Press the tabs and lift the left side. The right will come out of the hole socket on its own but note where the hole on the right is for replacement. Try not handling the roller with your bare hands any more than you must as oil from your hands can cause slight imaging defects if your hands are sweaty or damp.
Using a clean rag (like t-shirt material) dampened (not soaking) with 99% alcohol (not 70%) lets clean the roller. Gently but firmly scrub the talc and paper dust buil-up from the roller. Once you've removed the build up it should return to a dark grey color. Let the 99% alcohol dry (5 minutes or so)and reinstall.
Try printing again. If the problem is solved your done. If not and it has improved, you will need a new transfer roller. They are available on Ebay much cheaper than from a dealer. The part number to search for is RM1-0343. Here's a link to ebay for one at around $20.00 landed.
http://cgi.ebay.com/LJ-2300-Transfer-Roller-New-OEM-RM1-0343-Unopened_W0QQitemZ270247145853QQcmdZViewItem?_trksid=p3286.m20.l1116
If the problem is the same, your problem is more than likely a dirty laser scanner lense. You'll need to remove the covers from the printer to accomplish this. The laser scanner can be located under the top cover. It's the larger black box on the top side of the printer. Once the scanner has been located, remove the top cover. DO NOT TOUCH THE MULTI SIDED SPINNING MIRROR TO THE REAR OF THE SCANNER. You will be cleaning the clear lenses and mirror towards the front. You clean this gently with a CLEAN and DRY Q-tip. Use a few Q-tips rather than re-applying a dirty one. Heck they are cheap!
Re-assemble the printer and try printing again. One of the steps above should resolve your issue. I am enclosing a link to a free service manual for your printer to help you through the disassembly and in the rare case that your issue remains.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%202300%20Service%20Manual.pdf
Hope this helps you a lot more than the first response you receved. If so rate me with a FIXYA!
Thanks.
Posted on Oct 02, 2008
  • 27 Answers
SOURCE: new problem with hp 3380
hiii...
change the fixing unit....film inside fuser.....
Posted on Nov 11, 2008
yboyandrei
  • 828 Answers
SOURCE: I have refilled my black ink catridge in HP PSC
please cover properly the whole you get refilled with it the pressure on that cartridge push out the ink inside and get print...
Posted on Jun 16, 2009
SOURCE: HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Posted on Jun 02, 2010
  • 121 Answers
SOURCE: my hp deskjet d1460 only prints half a page when i
are you able to print any document from your local computer if so your driver and your print are both fine, check print preview before printing your hotmail mails, if still not coming alright try high content to be printed only
Posted on Oct 20, 2010
Sc 101 ricoh mpc305
1. Check and clean the scanner mirror(s) and scanner lens.
2. Check and clean the shading plate.
3. Replace the exposure lamp.
4. Replace the lamp stabilizer.
5. Replace the scanner mirror(s) or scanner lens.
6. Replace the SBU.
Mar 03, 2017 | Ricoh Office Equipment & Supplies
In my ir3300 xerox in very light if any setting is there make to dark print?.... what is the setting can u help me ?plz
Check your drum. if drum is ok clean the laser unit and clean the drum unit and chraging roller.
And clean the laser scanner lamp and the Mirror.
You must alert while cleaning the mirrors(Reflectors) don't use thinner, alcohol and stain removers for cleaning scanner lamp and mirror don't do that to movements the reflectors just open the copy board glass and clean with a cotton.
Jun 26, 2016 | Canon Ir 3300 Black & White Copier
The printings in my hp laserjet 1010 keep appearing with a white band at the right side of the page, i've tried to reinstall the toner but still appears...can you help me guys? please!
Go to paint shoot black colord print page, while printing half page switch off the printer remove cartrige gently, check on catridge drum surface is there any while patch in black image on drum ? if yes *** open laser scanner assembly clean the reflect mirror with ear buds gently fix it back then try once..****check image on paper is there any white band? id no replace teflon sleeve/fuser.*****If white patch is not in image clean/replace the transfer roller. best of luck..
Sep 12, 2011 | HP LaserJet 1012 Printer
I had refilled my canon 831 color cartrige but it is not working and it is also blocked non of the color is printed in pattern check. how can i resolve cartrige blocking problem????????//
Open the printer and remove the catridge
Use a tissue paper and clean the nozzle where the ink comes out from
After you have cleaned the nozzle, press the catridge on the tissue and see if the color stains the tissue
If it does, you put the catridge back into the printer and then try to print.
Jul 06, 2011 | Computers & Internet
Printing not clear & disabling alignment
h o this is because of the catridge problem. check the outlet of the ink....and clean the area with proper clean cloth and check t. may be the catridge got over . so check the level and try printing.
Jul 05, 2010 | Office Equipment & Supplies
Mustek 1248ub image is not clear
Hi
You clean this scanner all mirror by soft cloth.When this mirror is dirty then all emage are not clear,so you need clean it.If you are a technician open your scanner Platen glass very carefully and clean all mirror then fix it.
Dec 27, 2009 | Mustek Scan Express 1248UB Flatbed Scanner
My espon stylus sx200 will not print any text, the pictures will print but it just prints blank pages when trying to print paragraphs.
just remove test print and check is that proper . also check the black catridge must be catridge is over. just replace it and try.
Dec 18, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I have opened the above door and have cleaned the mirrors front
check the cables connected to scanner pcb monted left side of the machine. there is a flat cable connected to the pcb from scanner unit. layer of contacts may not be correct. check, clean and re-inatall the cable.
Dec 24, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Scanner makes whites lines in all scans
u clean ur catridge,
in printer setting  only, u will have an option called, clean catridge, then, u select tat option and it will clean, n finally give print test page, and check if u r prob is solved
Jul 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 2300 Printer Logo
Seeker5211
Seeker5211
