Question about Pool & Spa
How do I fit a new pump to a ppw55 - Pool & Spa
  • 717 Answers
New pump wet ends have an impeller inside the housing and the impeller is threaded onto the shaft of the motor.
the four bolts go all the way through the motor and thread into the four little fingers on the wet end to hold it onto the motor.
Rod
US Parts Center
Posted on May 13, 2013
Why a new fitted oil pump is failing to raise pressure
Suggestion The drive of the oil pump, there is may be a possible missed pin between the balance shaft and the oil pump ?
Jul 01, 2016 | Cars & Trucks
Instructions on replacing a fuel pump on sst15?
John Deere Spin Steer 15 with Kohler CV15 engine.
Removal
1. Disconnect the fuel lines from the inlet and outlet fittings of the pump.
2. Remove the hex. flange screws, fuel pump, and gasket.
3. If necessary, remove the fittings from the pump body.
Installation
1. Fittings - Apply a small amount of Permatex® Aviation Perm-A-Gasket (or equivalent) gasoline resistant thread sealant to the threads of the fittings. Turn the fittings into the pump 5 full
turns; continue turning the fittings in the same direction until the desired position is reached.
2. Install new gasket, fuel pump, and hex. flange screws.
NOTE: Make sure the fuel pump lever is positioned to the right of the camshaft (when looking at fuel pump mounting pad). Damage to the fuel pump, and severe engine damage, could result if the lever is positioned to the left of the camshaft.
3. Torque the hex. flange screws as follows:
Into new as-cast hole-9.0 N·m (80 in. lb.).
Into used hole-4.2-5.1 N·m (37-45 in. lb.).
4. Connect the fuel lines to the inlet and outlet fittings.
Mar 29, 2015 | Garden
How to change powerstering pump chevy uplander
I just finished replacing mine.
It is much easier if you do these steps:
1. Remove the serpentine belt.
2. Remove the nuts holding the main fuse box over the battery.
3. Remove the reinforcing bar over the battery.
4. Remove the battery.
5. Remove the windsheild washer tank.
6. Now you have access to remove the pump pulley. Without removing the stuff, it may be possible, but it will be extremely difficult.
7. Remove the pump pulley.
8. Loosen the high pressure hose fitting.
9. Remove the return line clamp.
10. Remove the power steering pump mounting bolts.
11. Remove the high pressure hose fitting.
12. Remove the power steering pump while sliding off the low pressure hose.
13. Remove the clips holding the reservoir on the pump.
14. Remove the reservoir.
15. Install new o-ring on the reservoir.
16. Install reservoir on new pump.
17. Install clips to hold reservoir on pump.
18. Install new o-ring on high pressure fitting.
19. Place new pump in position while sliding on low pressure hose.
20. Loosely attache high pressure fitting.
21. Tighten pump to mounts.
22. Tighten high pressure fitting.
23. Install clamp on low pressure hose.
24. Install power steering pulley.
25. Install washer reservoir.
26. Install battery.
27. Install reinforcing cross member.
28. Install fuse panel.
29. Install serpentine belt.
30. Bleed the power steering system.
Dec 13, 2012 | 2008 Chevrolet Uplander
Replace power steering pump on 06 chevy uplander
Jul 08, 2012 | 2006 Chevrolet Uplander
Bmw powersteering fault still no powersteering with new pump fitted
Who fitted the pump?
If the pump was fitted wrong it may have air in the pipes, it might need bleeding through, alternatively the fault could be the power steering rack and not the pump.
Hope this helps,
Regards
Dan
Nov 07, 2010 | 2006 BMW Mini
How to replace water pump on 2003 landrover freelander
DRAIN COOLING SYSTEM.REMOVE CAMSHAFT TIMING BELT.REMOVE AND DISCARD 7 BOLTS SECURING COOLANT PUMP TO CYLINDER BLOCK.RELEASE COOLANT PUMP FROM CYLINDER BLOCK AND REMOVE.REMOVE DISCARD O RING FROM COOLANT PUMP.BEFORE INSTALLING NEW WATER PUMP.CLEAN COOLANT PUMP AND MATING FACE OF CYLINDER BLOCK.LUBRICATE NEW O RING WITH RUBBER GREASE,AND FIT TO COOLANT PUMP.FIT COOLANT PUMP TO CYLINDER BLOCK .FIT NEW BOLTS TIGHTEN IN SEQUENCE TO 7 FT LBS. SEQUENCE BOLT 1 AT 11OCLOCK BOLT 2 AT 5 OCLOCK. BOLT 3 AT 1 -OCLOCK BOLT 4 AT 7 OCLOCK BOLT 5 AT 3 OCLOCK BOLT 6 AT 10- OCLOCK BOLT 7 AT 8 OCLOCK.
Sep 16, 2010 | 2003 Land Rover Freelander
I am looking for the instructions manual for a Pro User Petrol Pressure Washer PPW55 5.5HP, do you know where I can get this? Thanks
Try phoning there technical helpline, they helped me out when i had problems with a similar machine, the number is 01473 747084
May 03, 2010 | Garden
Machine does not empty new pump fitted
Check the drain outlet hose for a possible blockage, also check the filter located inside the large black hose fitted to bottom of drum.
Please rate my solution.
Thanks.
Nov 05, 2009 | Hotpoint WMA30 Front Load Washer
Power sterring hose leaks. how is hose connected to pump
Most of the PS pressure hoses are Compression Fittings. If the fitting is straight on and is clean on the inside before you seated the hose, there may be a burr of the pump side where the fitting sits. Some of these fittings are replaceable and others require a new pump. Check your new hose also for cracks where the pipe section of the hose is that looks sort of like a trumpet end. If the fitting is in good shape, the pump fitting is clean and unmarred, you may need to tighten the hose a little more.
Jul 22, 2009 | 1989 Toyota Celica Liftback
Need to fit new pump on a hotpoint aquarius 1000 deluxe wm25
I assume you want to know how to fit pump.Remove the lower back panel, in the lower left hand corner you will see the pump, it has an inlet and outlet hose going to it.
Remove these two hoses and disconnect the 2-wire plug to the pump.
Tilt the m/c forward and remove the 2 screws securing the pump to the washer base
Remove punp.
Fit new pump in reverse order, very straight forward job.
Plz leave feedback.Thanks.
Dec 11, 2008 | Hotpoint Washing Machines
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
