Clean screen Clean greasy fingerprints
    Top Expert:
  • Televison & ... Master
  • 74,243 Answers
Check and replace its T'Con board. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center. If you wish to get more details, check the site linked below. Pull up older posts there. Check the site with patience, as it has over 2400 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Posted on May 02, 2013
Technics CD player stops playing after 30 seconds
Your explanation is vague, so start with the basics:Check your CD's for scratches and foreign materials stuck or spilled on them, including greasy fingerprints. Try to run a cleaner if you have one, and visually check the inside for any foreign objects that could have accidentally gotten in there. More specific details would help a ton more. thanks
Apr 13, 2014 | Technics Audio Players & Recorders
I have a Samsung DLP-TV, HL-T5055W. The instructions say to clean it only with a clean dry cloth, well my dog made nose prints on the screen. Is there anything I can use to clean them off, since a...
How Can I Clean The Fingerprints Off The Screen On My TV? spacer.gif To clean fingerprints and greasy smudges off your TV screen, first try using a dry, anti-static cloth and rubbing gently.
Note: Many Samsung TVs come with a screen cleaning cloth. Use that cloth and follow the directions on the package.
If that does not work, get a bottle of ScreenClean screen cleaning solution or similar screen cleaner. You should be able to get it at most regular and on-line stores that sell monitors or TVs. Put a small amount of ScreenClean on a clean, soft, dry cloth, and then rub the screen gently.
WARNING: Never use any type of window cleaner, soap, scouring powder, or any cleanser with solvents such as alcohol, benzene, ammonia, or paint thinner. Never use abrasive pads or paper towels. If you do, you can scratch the screen or strip the anti-glare coating off the screen and cause permanent damage.
Cleaning It Right There are four steps you must take to do the job right:
  • Unplug your TV before you begin to eliminate the risk of electric shock.
  • If you use ScreenClean or a similar screen cleaner, put or spray the ScreenClean onto the cloth. Never put or spray it directly onto your TV screen.
  • Wipe as gently as possible. LCD, Plasma, and DLP screens in particular are fragile and can be damaged if you press too hard.
  • Let the screen dry completely before you plug the TV back in.
Food and DLP Screens Getting sticky food such as peanut butter or jelly off the screen of a DLP TV is especially difficult because the tiny grooves in the screen's surface trap small food particles. In fact, you probably will not be able to remove the food entirely. If you need to remove sticky food from your DLP TV screen, follow the directions above, be patient, wipe gently, take additional time, and understand that you will almost certainly leave some food residue on the screen.
Jun 28, 2008 | Televison & Video
Tip
How To Clean Laptop Screen With Household Products?
<p><b>Cloth</b> - Only use a 100%-cotton cloth that is soft and absorbent, either an old T-shirt, sock, or Turkish towel. Make sure you're not using a cotton/polyester blend that contains stiff filaments which can scratch an LCD's surface.<br /> <p><b>Note:</b> Paper towel or facial tissue should never be used because they contain wood fibers, also hazardous to LCDs, and definitely are not how to clean a laptop screen. Also remember to never use a dry cloth on your LCD monitor. Dust particles moved around with even the softest cloth could create scratches.<br /> <p><b>Liquid</b> - The best way to get a really clean laptop screen is to use isopropyl alcohol, containing 91% pure alcohol, with 9% de-ionized water, readily available at any drugstore or supermarket. It's perfectly safe for use on electronic equipment and LCD screens because it evaporates quickly and does not leave a residue. The lesser strength isopropyl alcohol 70% is used primarily for massage and muscle pain.<br /> <p>A 1:1 solution of distilled water and isopropyl alcohol 91% can be used to clean a laptop screen that is not heavily dusty or soiled with greasy fingerprints. Vinegar and distilled water in a 1:1 solution can also be used for light cleaning.<br /> <p>Certain household liquids should never be used on LCD's. These include ammonia and tap or mineral water, which leave permanent white spots and streaks. Household window cleaners should be avoided because they might contain ammonia, or other harmful chemicals which also can cause irreparable damage.<br /> <p>Another caution is to never spray a solution directly onto an LCD. Always spray the liquid on a cloth, only enough to moisten it slightly, and then apply to the screen in gentle, counter-clockwise motions.<br /> <p><b>How To Clean Laptop Screen With Special Cleaners?</b><br /> <p><b>Kits</b> - Micro-fiber cloths and anti-static solutions are packaged together and sold at office supply or electronics stores. The special solution leaves a slight film that protects a clean laptop screen, repels dust and smudges, and keeps it clean longer. The liquid should be sprayed onto the cloth, which only needs to be slightly wet, not dripping, when applied to the screen. There's a slight disadvantage to these kits. Certain solutions cause streaking, so it's best to do a little research before investing in this method.<br /> <p><b>Micro-fiber</b> cloths can be purchased separately and used with isopropyl alcohol 91%, and/or distilled water. Whether using the complete kit or the cloths alone, make sure the packaging designates the product is ''safe for laptops and LCD screens."<br /> <p><b>Anti-Static Cloths</b> - Many computer manufacturers, when asked how to clean a laptop screen, recommend anti-static cloths made specifically for cleaning without liquid of any kind. These cloths are formulated for advanced optical technology and are considered the best way to clean, polish and protect a laptop screen. Even greasy fingerprints can be buffed off using these cloths, readily available at electronics or office supply stores.<br /> <p>Similar cloths are made for cleaning camera or eyeglass lenses, and these can be found at any drugstore, optometrist or camera shop. Anti-static cloths are the quickest and easiest solution when you want the most advanced and easiest method to both protect and clean a laptop screen.<br /> <p>The above options offer a variety of easy and safe ways to care for your LCD monitor. With simple maintenance on a regular basis, a laptop screen will last for many years.<br />
on Mar 14, 2011 | Computers & Internet
When I load a dvd into the player, after a while it says "no disc" and nothing plays.
Do the "bad" disks work on some other DVD player?
Or, do the "bad" disks work on some computer with a DVD drive?
Dirty disks with lots of greasy fingerprints?
Feb 16, 2014 | Sanyo Televison & Video
Fingerprints on the screen of the computer that does not come off. Any suggestions on how to clean this? Thank you. "
You could get a soft cloth (make sure its clean so it will not scratch the screen) and put a little amount of water at one corner and rub it on the screen. Don't be afraid to apply pressure but do not over do it. Afterwards, the fingerprints would be gone.
Feb 25, 2011 | E-Machines eMachines Desktop PC
Cleaned plastic cups and bowls have a greasy film on them
water heater temp to low maybe new elements clean internal unit screens cascade complete jel
Feb 04, 2010 | KitchenAid Dishwashers
While playing a DVD, the movie will freeze on screen. If I push FF or rewind sometimes it will "un-stick". However, the problem will repeat. Is this worth fixing? If so, where do send it? Should I...
It probably is laser related and will cost major repair dollars to fix. You did carefully clean the troubled disk of greasy fingerprints? I would there for recommend replacement and a nice new 1yr. warranty. Plenty of good prices out there, thank goodness.
Jun 24, 2009 | InsigniaT Portable DVD Player with 10"...
Cleaner left behind a haze on the screen
You're absolutely correct with the no cleaners thing, however if you dampen a lint-free cloth with water it will help to get those fingerprints off. Wipe dry, and you should be good.
Mar 28, 2009 | Toshiba REGZA 47HL167 TV
Does this camera show fingerprints?
Hey 1597,
Being that this camera looks to be brushed aluminum look it probably will show some fingerprints but not nearly as pronounced as a camera that has a polished surface would. One suggestion I would have is invest in a micro fiber cloth. This cloth not only could be used to clean the outside of your camera it can also be used to clean the lens, and the LCD screen. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 19, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
