Question about Honda 8 HP Engine
Oil i have an 8hp motor needs oil change what type of oil
  • Honda Master
  • 15,950 Answers
10 W 30
Posted on May 06, 2013
Where do you put the oil in a fradan honda 8HP leaf blower?
you will need to check the owners manul to see where and what type of oil it takes or if it takes mixed oil and gas and then there should be a gas/oil mixture ratio you will need.
May 06, 2011 | Honda Garden
We have a Intertherm Furnace Model # MGHA-056ABCFC-01 Serial # MGH9205-01793 115va 60hz 1ph 5.9amps 1/8hp rpm 1050 We need to find a blower motor and a blower wheel for our furnace. Can you help...
Phone book, refrigeration distributors, call and give unit make model # serial # 1ph 1050rpm 1/8hp and frame type of motor. Usually a belly band. Though any good parts house can get all needed info off of make model serial. You might need to call a few since many will not sell to you if you are not licensed.
Feb 26, 2011 | Heating & Cooling
What kind of oil does a honda 8hp motor take?
Not knowing the specific model, most Honda engines use a 10w30 oil.
Feb 13, 2011 | Honda Electrical Supplies
How much oil does an 8hp honda engine take ?
Honda gx240 oil capacity
1 .I6 US qt
Use Honda 4-stroke oil, or an equivalent
high-detergent, premiumquality
motor oil certified to meet or
exceed U.S. automobile manufacturer's
requirements for Service Classification
SE or SF. (Motor oils classified
SE or SF will show this designation
on the container.)
SAE low-40 is recommended for
general, all-temperature use.
Feb 10, 2011 | Honda 8 HP Engine
I have a 8hp b&s motor it gets oil in the carburettor from the motor
Eighter you have no crank case ventilation or you have a problem with the rings worn out rings will push oil back through the intake valves into the carb
Nov 29, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
I need to top up with oil, but do not have a manual to describe this
You did not list your specific make and model. However for most reciprocating type air compressors 1/2 to 8hp (without oil check window) you use the filling port as the level. The oil level is considered full when it reaches the bottom edge of the filling port. Just before it would begin to spill out. If it has a window then it will be full about halfway up.
As far as oil type there is oil specifically made for air compressors but just about any 30 weight will work.
Hope this helps
Oct 01, 2009 | Air Tools & Compressors
Won't start, new coil, weak spark,
if i remember correctly these have electronic ignition the module may need replacing but beforedoing any thing drastic try disconecting the oil alert wire that sometimes gives a bit of pain youdoit
Jul 20, 2009 | Honda 8 HP Engine
Honda 8 HP Engine Logo
63 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
