Power Supply Diagram
What are the effects when increasing the size of filter capacitors?
    Top Expert:
  • Televison & ... Master
  • 74,185 Answers
The power supply system will become more stable in case of ripple. That is all. No other effects.
Posted on May 02, 2013
I recently bought a 100uf 450v capacitor to replace a 68uf 450v capacitor. Unfortunately there is no power being fed to the TV when plugged in. I was told by a local TV repairman that the uf rating...
The fault to your TV might not due to a defective capacitor. A higher capacitance valued capacitor, won't do nothing wrong. But as the capacitance value increases, the size of the capacitor will too increase. That's all. Check the fuse at the power supply regulator board. If it is found opened, make sure that something wrong with the power supply regulator board. Without rectifying the fault, never replace a fuse, as it will make things worse. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 17, 2013 | Akai LCT3201AD 32 in. LCD Television
ST-A-090-002U002AAT
  • this adapter there are NOT suppose to fix it. only replace. However you must the same capacitor or use another capacitor with more faradios.NOT less. . Please test the i.c for regultated power supply can be shorted.
God bless you
May 21, 2013 | Computers & Internet
Start up red light flash to green and back to red,will start after 5min of trying
Hello, how you describe it hits of the power supply voltage, usually indicates that capacitor electrolytes broken, their job to filter the port voltages of power supply. Sometimes the swelling can be seen at the top of capacitors. To remove them from the board soldering equipment is required. Absorbing tin, tin. While replacing the capacitors is important bring them to table under the correct polarity. Make sure the correct value of the container and size of voltage that marked on the capacitors . If its too complex to repair the power supply. Should replace the entire power supply. Worthwhile to review the level and stability of the exit voltage of the power supply before buying. Good luck!
Apr 27, 2011 | Panasonic TC-32LX20 32 in. HD-Ready LCD...
Tv want come on but before that happen tv had a sound but no picture
Hmm dont know what model or tv you have but generally i would say on a lcd television I would suspect filter capacitors in power supply first. next would be a defective inverter board. Depending on size and brand the inverter board and power supply board maybe combined. If its a plasma then power supply filter capacitors or possible z sustain board failure.
Oct 17, 2010 | Televison & Video
Every time i turn on the tv it makes the click noise it is suppose to and the little red power indicater bulb flashes for about 5 to 7 secs like always but right about the time the screen usually kicks on...
Please check the horizontal output transistor for leak, base-emitter. Change it.If there is any kind of short in the board, the power supply will sense int and will shuts down. Line out put transformer [LOT] may also suspect. On the secondary supply stage from LOT, the secondary power supply section, check all the rectifier diodes, and its filter capacitors for leak. Even a slight leak will effect the proper function of the set. Check it with good qulaity analongue multimeter, with setting it to meg ohms range; check the suspected componets off board. Likewise check the primary rectified DC voltage at SMPS stage. It should be aroung 380V DC accross main filter capacitor. If it is not check the main filter capacitor [usually 330Mfd 450V] for low capacity. and check the four main rectifier diodes.
Oct 14, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a pltv 3750 the power light comes on but no picture or sound what could be the problem
It could be a blown filter capacitor in the power supply. It's a pretty common occurrence with TVs and video game consoles. If you wish, you can open up the power supply (assuming it's outside of the unit. If not, then open the set and follow the power cord until it meets a board.) . Check the capacitors (if you don't know what they are, they look mostly like a silo. A cylinder that's usually around the size of your thumb or even larger, for filters.); if you notice any visible holes or any puddle of black-ish brown-ish stuff around it, then it's blown and needs to be replaced.
Jun 08, 2010 | Protron PLTV-32 Television
Shrinking horizontal screen image appears with black border approx 1/2" on both sides
The most likely cause is a dried up main filter capacitor. Once the effective capacitance drops low enough, 120 Hz (or 100 Hz in countries with 50 Hz power) ripple will make its way into the regulated DC supply (assuming full wave rectification).
Another likely cause of similar symptoms is a defective low voltage regulator allowing excessive ripple. The regulator IC could be bad or filter capacitor following the IC could be dried up.
The best approach to testing the capacitors is to clip a good capacitor of approximately the same uF rating and at least the same voltage rating across the suspect capacitor (with the power off). A capacitor meter can also be used but the capacitor may need to be removed from the circuit.
Once the capacitors have been confirmed to be good, voltage measurements on the regulator should be able to narrow down the problem to a bad IC or other component.
Feb 21, 2010 | Dell E551 15" CRT Monitor
I turned on my LG flat screen tv and it went on and then the picture immediately disappeared but it still has full volume, however, no picture
these have been known to have leaky caps in the power supply to cause this problem, this is a difficult repair so i would call for a lg serviceman
Jul 09, 2009 | LG 42LC2D 42 in. LCD HDTV
Boss psa 120s automatically shuts down and does not turn on
I'm going through here just to share the circuit diagram (schematic) for Boss PSA adapter because I know that many people need to repair their damaged fonts but can not get the original wiring diagram.
Savio
Jul 08, 2009 | Boss PSA-120 (761294015735) Power Supply
27"tv sharp analog
Good day.
Refering to to mr walts inquiry and if it is, maybe you are having some issues in your vertical circuitry. It may be loose that it needs to be resoldered and other filter capacitors within the vertical section.
chris
Mar 22, 2008 | Sharp 27C-240 27" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
