Apple iPad (16 GB) WiFi Tablet PC Logo
Anonymous Posted on May 02, 2013
Forgot password & security questions to access my myspace account
Can I be emailed a solution to my problem? I need to log into my myspace account but have forgotten password & security questions.
How can I reset my password for facebook
you may be able to get back into your Facebook account by answering a security question, using an alternate email address listed on your account or getting help from friends. Keep in mind that you'll only see these options if you set them up.To see if you have these options:
  1. Go to the Facebook login page and click Forgot your password? or Can't login? in the top right.
  2. Fill out the form to identify your account.
  3. Select I forgot my password on the next page if prompted.
  4. Look at the list of email addresses listed on your account. If you don't have access to any of these, click No longer have access to these?
  5. Follow the instructions provided to answer your security question or get help from friends, if you see these options, or contact your email service provider.
Once you get back into your account you can change your login email address at any time from your account settings. You can also log into Facebook with any email address you've added to your account.
How can I reset password for my Apple ID to get into ITunes?
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad
This is all done on an iOS device and is often the simplest way to log back into an Apple account:
  1. Open the Settings app and scroll down and tap on "iCloud"
  2. Tap on the email address at the very top of the iCloud settings screen
  3. Tap on the blue text underneath the password entry that says "Forgot Apple ID or Password?" where you'll have two choices:
    • If you know your Apple ID and don't remember the password, type in your email address and click "Next" to start the reset process
    • If you don't know your Apple ID, tap on "Forgot your Apple ID?" and fill out your full name and email address to recover the Apple ID login (yes, you can then do the password reset after you have the Apple ID)
  4. Answer the security questions pertaining to that Apple ID, and follow the onscreen directions to complete the process
At this point you should be good to go, you can reset the password for the account and then login as usual.
Forgot password. How can I reset my Apple account?
From Apple:
If you forgot your Apple ID password If you're having issues signing in with your Apple ID password, use these steps to reset it and regain access to your account.
Your Apple ID is the account you use for everything you do with Apple, like shopping the iTunes Store, signing in to iCloud, buying an app, and more. To reset your password, you'll need to know the email address for your Apple ID. If you're not sure which email address it is, there are a few ways you can find your Apple ID.
Reset your password
After you reset your password
Get more help Reset your password You can reset your password when you go to your Apple ID account page and click Forgot Apple ID or password. Enter your Apple ID, then click Next.
After you enter your Apple ID, there are a few ways you can change your password:
Answer your security questions
If you know the answers to your security questions, select "Answer security questions" and follow the steps to reset your password.
Use email authentication
If you select "Get an email," we'll send an email to your primary or rescue email address that you can use to reset your password. Didn't get the email?
If you use two-step verification
If you set up two-step verification, you can use it to change your password. You just need a recovery key and a trusted device. Follow these steps:
  1. Enter your Recovery Key.
  1. Choose a trusted device. We'll send your device a verification code.
  2. Enter the verification code.
  3. Set a new password and select Reset Password.
If you permanently lost your recovery key or access to your trusted device, you can't change your password.
If you use two-factor authentication
If you have two-factor authentication, you can reset or change your password from your trusted iPhone, iPad, or iPod touch when you follow these steps:
  1. Go to Settings > iCloud.
  2. Tap your name.
  3. Tap Password & Security.
  4. Tap Change Password.
  5. Enter a new password.
These steps will work only from a trusted device with a device passcode enabled. If you don't have access to a trusted device, you can reset your password when you follow these steps:
  1. Go to iforgot.apple.com and enter your Apple ID.
  2. Enter your trusted phone number and click Continue.
  3. Enter the verification code that we send to your trusted phone number.
  4. Provide any additional account information requested.
  5. Choose your new password.
If you can't sign in, reset your password, or receive verification codes, you can request account recovery to regain access to your account. Account recovery will take a few days, depending on what account information you can give. After you reset your password After you reset your password, you'll be prompted to sign in again with your new password. You also might need to update your password in Apple services and on your devices. Get more help If you're still having issues signing in with your Apple ID and password, make sure that you're entering the correct Apple ID. In most cases, your Apple ID is also the primary email address of your Apple ID account. If these steps didn't help you change your password, contact Apple Support.Last Modified: Feb 19, 2016
2answers
I had to change sign ins for apple,google Facebook and messanger. Passwords are mixed up and don't know what to do?
Easiest thing? log out and try to log in from a computer. Click on the "Forgot password" link, enter your ID email for whichever location (FB, etc) you're trying to get back to and follow the directions on the email they send you. Everybody has a provision for this because it is rather common. You just need to remember your answers if they had security questions or have access to the email address you used to sign up.
How Do I reset email password
  1. Visit the email Forgot Password page.
  2. Select Password.
  3. Enter your full email address and your last name.
  4. Select Continue.
  5. From the drop-down menu, select I'll answer my security questions.
  6. Answer the security questions that you set for your account.
  7. Select Continue.
  8. Add a new password
  9. Select Enter
  10. Done. Your password will be reset successfully.
For email related errors and issues, the easiest way is to reach Email technical support service. Their experienced support team offers an instant solution and help for email setup and password related issues.
Dial directly toll-free number 1888-315-9712
email technical support number
1helpful
How do I unlock
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here...
http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
My big lots tablet is lockedand i cant remember the pin itsa d2 7in.what can i do ?
also, see here...
5helpful
2answers
I forgot password & security questions for my myspace account
On the myspace login screen click the "Forgot password?" link.
2helpful
2answers
How to reset my password on my google account
Occasionally Google Gmail user may want to reset the password which used to login into the Gmail account via web, POP3 and IMAP as the original password has been forgotten, or misplaced. Gmail credentials integrates and bases on Google Account. So changing the password for Gmail will also change the password for the associated Google Account.
In order to reset and change the password of Gmail and corresponding Google Account with the affected Gmail email address, follow these steps:
  1. Go to https://mail.google.com/ (related: other Gmail URLs).
  2. Click on I cannot access my account link.
  3. Click on radio button of I forgot my password, and then click on password recovery page link (or you can go directly to the link above).
  4. Enter the username for the Gmail or Google Account in the field provided.
  5. Enter the captcha letters as shown in the image on screen.
  6. If you never login to the Gmail for the previous 24 hours, a secret question as set in the Google Account will be presented. Answer the question with a correct answer in order to be able to reset the password.
    If you're unable to answer your security question and the account has a secondary email address configured, a link will appear at the bottom of the secret question results page. Clicking on the link will has a password reset email message sent to the secondary email mailbox. After receiving the email, follow the link to reset the password.
    If you have login to Gmail in the preceding 24 hours period, the password reset email will be sent immediately instead. Follow the link to reset the password. If you don't have a secondary email address, or if you no longer have access to that account, repeat the steps above after 5 days. At that point, you'll be able to reset your password by answering the security question you provided when you created your account.
  7. If you cannot remember the answer to secret question, cannot answer the secret question correctly and do not receive password reset email in secondary email account, try to contact Google for help.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
