Does any know where i can buy a heating element for an Adam Helios electric fire
My adam helios electric fire is now only blowing out cold air need to where i can buy a new element for it so i can replace it if it can be replaced.
hotuna
  • 288 Answers
SOURCE: heat pump thermostat replacement
It sounds like your reversing valve energizes the opposite from how you wired it at the thermostat. Check the instructions.
Posted on Nov 05, 2007
SOURCE: Rewiring Fireplace Electrical Insert
I looked up regular electral diagram for the different elements.
Posted on Dec 16, 2008
djz83
  • 88 Answers
SOURCE: ELCTRIC DRYER NO HEAT JUST COLD AIR
There is a thermal fuse its location depends on the dryer if the filter is on the top then you have to take off the back panel and check the white fuse. If the filter is inside the dryer you have to take off the bottom panel. a flathead screw driver for the 2 clips the check the white fuse behind the lint trap (where the filter goes).
Posted on Jan 08, 2009
  • 15 Answers
SOURCE: my kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Posted on Jul 20, 2009
SOURCE: Dust and dirt removal from Helios objective lens
You will need to remove the mirror and clean it according to these instructions. Then you will need to collimate the scope after you put it back together.
See these two web sites:
http://www.astro-tom.com/tips_and_advice/cleaning_optics.htm#article1
http://www.andysshotglass.com/Collimating.html
Posted on Sep 04, 2009
I have recently bought a second-hand electric fire which looks exactly like The Adam Ribbon chrome Electric Fire. It has three switches for flame only and then two heat settings. What i don't understand is...
The dial, numbered 1-9, is probably the heater fan speed control. Or it also could be the flame effect control (speeds the flames up or slows them down). But, I suspect its the heater fan speed control. Either way, it works like a rheostat. As far as efficiency is concerned, despite what the manufacturer may say, electric fireplace effect heaters are not that efficient in the long term. Nor, are they that reliable. They do require routine maintenance to increase their longevity.
Hope this answered your questions.
Apr 13, 2011 | Heating & Cooling
Heater only blows cold air. I have a Weather King Heater and it only blows cold air the burners will fire for about 2-10 seconds and then it goes . ...
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 09, 2011 | Weather King 10AJA3001AH Air Conditioner
Hello where can I buy a Helios Violet Laptop in
Try here:
http://www.prix-malin.fr/search?q=Toshiba
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 27, 2010 | Toshiba Helios Violet 140 Satellite...
Sep 03, 2009 | Optics
Blows only cold air
Check connection to heating elements. My have bad heating elements
Jan 19, 2009 | Maytag Neptune MDE6800 Electric Dryer
Helios h4000
While this was posted 2 years ago, I found a company that does repairs on the Helios, in fact I have used them twice so far for repairs on my unit. The first time for the power supply problem and the second time for a jammed tray door in March of this year; it would not open.
ECP Repair and Service in Eagleville, Pa.
Nov 10, 2008 | Neodigits Helios H4000 DVD Player
95 toyota camry coolant problem
adam, if you want your fans to turn on, add a switch in your dash panel. there is a firewall break behind the driver side front wheel, so all wiring can be run through there. to solve the over heating, check fluid levels, replace the water pump, and just for kicks, replace the fluid and hoses. make sure there is 50/50 mixture in the coolant system that really does make a diffrence. good luck!
Jul 30, 2008 | 1995 Toyota Camry
Candy Dishwasher Power Trip Problem...........................
Hi Adam,
Those are tough questions, it depends on accessibility of the parts in question, and the tools you have available to you.
It’s worth remembering that 80% of d/washer faults are mechanical in nature (even the electrical ones). I know that sounds like a contradiction in terms, however I am referring to things like loose connections, broken wires worn parts etc.
First thing to do is have a good look and weigh the job up (English colloquialism) A bad Neutral connection to the heater element would give you these symptoms. An open circuit heater would likely do the same. Moisture in an inappropriate place could also give similar problems.
After gaining access to the business end of the element, check for corroded connectors. If all seems well, and you have access to a multimeter, set it to ohms and measure across the two heater terminals with the wires disconnected. If you get no reading, then the heater element is open circuit and requires replacing. If you do get a reading, and still think the element is suspect, you could try disconnecting both feeds to the heater (not the earth) taping them up with good quality electrical tape so as to isolate them, then try your dishwasher on a cycle where the water would normally be heated. If it doesn’t trip the RCBs then heater is suspect.
This is a good starting point, and will enable you to assess weather you feel comfortable tackling replacing it or not (assuming it is faulty). If you don’t feel comfortable, may I suggest that you purchase the element from a spares supplier yourself, there are many good suppliers on line. Then have a service engineer fit it. This prevents your friendly repair man charging you $90.00 for a $20.00 part.
Of course, it goes without saying, that all these tests should be carried out with the appliance disconnected from the mains supply.
Good Hunting!
Regards……..Dave
Mar 11, 2008 | Dishwashers
Heating & Cooling Logo
304 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
